Go to Post I give props to your programmers and programming mentors. - Sgraff_SRHS06 [more]
Unread 13-06-2005, 13:24
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Which shaft encoder to use?
I'm currently designing a holonomic drive system, and I want to use shaft encoders to measure wheel speeds. What kind of encoders should I use for this purpose? I tried looking in the DigiKey catalog, but I don't know much of anything about sensors (I'm an ME student), so I couldn't decide which type of encoder I should use.
Also, how does one mount an encoder on a shaft? I know some people use gearing for potentiometers, to increase resolution, but would you do the same thing to an encoder (if it were running at too many RPMs, perhaps)? The shaft I'd be measuring is 1/2", and spinning at 150-470 RPMs, depending on which gear the transmission is in.
Anyways, I'd appreciate any help I can get on either question (which to buy, and how to mount). Thanks!
Jeff Waegelin
Unread 13-06-2005, 13:45
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Which shaft encoder to use?
This year we used 4 Bourns quadrature encoders on our robot and were very pleased with them. The model number is ENA1J-B28-L00064 and they are available from Digikey. They give 64 pulses per revolution (per channel). So, if you decode the quadrature output and count both rising and falling edges on both channels, you get 256 ticks per revolution (but that's tough to do using the RC hardware). We used them geared 1:1 on our drive wheels and the winches for our lift height and tilt. They come in variations with other counts per revolution as well. They're quite pricey at $50 each but they are high quality and durable. These encoders were originally recommended to us by the Thunderchickens and as far as I know they were quite happy with them as well.
Also, make sure to get an optical encoder rather than a mechanical one, and don't get any with detents (detents are spots where the encoder "clicks" into position, often used with knobs on stereo controls or whatnot).
Unread 13-06-2005, 14:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
A good way to couple it to the shaft is to drill and tap a hole in the shaft for a socket head cap screw, something like #10 would be good if your shaft it big enough. Then, heat shrink the head of the screw to the shaft of the encoder leaving a little space in between. The ridges on the head of the screw and the surface area of the relatively long shaft encoder shaft will prevent slippage. Now you have a very cheap flexible coupling. I would recommend mounting the encoder with a rather thin piece of sheet metal so that has some flex too. Rigidly mounting/coupling encoders can cause them to wear and/or break.
Unread 13-06-2005, 14:42
El Jefe de 148
I don't have a huge budget for sensors for my summer project. Is there something less expensive you (or someone else) could recommend? Or will I be disappointed with the performance from lesser components?
Also, what did you use to attach the encoders with your 1:1 gearing?
Jeff Waegelin
Unread 13-06-2005, 15:28
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
We did this in 2004, and had some problems with it. The biggest being since your putting the wheels out at angles on the edges it leaves little room to mount the encoder, if you cant get the encoder inline with the shaft then it doesnt work very well, also the tubing we used to make the couplers would load sometimes when we changed directions. Also, since they were mounted outside the wheel they were very prone to breaking in a hit, even with lexan convering.
This year we devised a much better plan that gave us no issues except when the encoders were shimmed wrong and hit the rollers on the wheel and snapped the encoder shaft. We bought small timing belt and pullies from sdp-si and mounted the encoder to the side of the gearbox. You can see it in this picture, near the middle.
I dont remeber any of the info on the encoders, they were quadrature and cost like 25 dollars each i think.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 13-06-2005, 15:33
Dave.Norton Dave.Norton is offline
FRC #1157
Dave.Norton is an unknown quantity at this point
[quote=Jeff Waegelin]I'm currently designing a holonomic drive system, and I want to use shaft encoders to measure wheel speeds.QUOTE]
One remark if I may; we did a holonomic drive this year and there was so much slip in the wheel to the surface that indexing the drive motors wasn't going to be useful. This was because all of the wheels were running in crab and any little imperfection in the drive surface would make the wheels skip. Anyway the solution was to lock all four motors into a loop using a yaw sensor, after which we didn't care about the individual speed of each motor. The downside is there is enough slip in the absolute direction gained from integrating the yaw sensor that we couldn't keep the field oriented steering, maybe we can solve that for next year.
Unread 13-06-2005, 15:39
Git 'em!
We have found that the hardest part of making the holonomic drive base was getting the wheels to have traction, pretty much all of our experimentation went into the rollers to get the most traction while having the rollers roll. So tracking the wheels is a very viable system.
Robot in 3 Days
Unread 13-06-2005, 15:42
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
If you are going to use an actual coupling to isolate the encoders try the "Helical Beam Couplings" from mcmaster. may cost a little more (about $20 a pop), but will isolate your encoders from flexing and vibrations. That way if you get an expensive encoder you can be assured it won't be destroyed or give bad readings.
Unread 14-06-2005, 00:12
Gdeaver Gdeaver is offline
FRC #1640
I'll throw this out as something completely different. A good encoder will probably cost 50 to 60$. The problem with encoders is that they require the use of interrupts in programming. Two encoders isn't too bad. 4 gets a little tighter to implement. Add a couple timer routines and things get complicated. I've just started playing around with a hacked optical mouse as a alternative to an encoder. Basically an optical mouse can track movement of a surface. The Aligent 2610 chip that I'm using can track up to 10 inches per second, however I've found its better to keep the disk that the mouse is sensing to 6-8 inches per second max. Using 2 wire serial communications the mouse returns the number of counts since the last request. The 2610 resolution is 400 dpi. That's a high resolution non-contact tachometer for about 12$ and no interrupts to program and debug. The chip does the counting for you, just poll it often enough that the registers don't overflow. I've only just started playing but it looks good. There were some threads on here about optical mice. Note that the Aligent mice chips are optimized for an almond colored texture Formica surface. The mouse lens needs to be 2mm from the surface. At higher velocities it's critical. I'm looking to use it to track and log valve linkage movement.
Unread 14-06-2005, 07:15
Jeff,
The encoders look exactly like pots and have all the standard hardware and mounting bushing attached. The shaft is 1/4" dia. and about 1/2" long so a shaft coupler works well. If you are looking for something cheap and dirty, Digikey does sell some optical couplers that you could incorporate into a wheel encoder of your own. All you need to do is design a interupting wheel that can be attached to whatever shaft you are trying to count and position the opto coupler so that the wheel breaks the light path. This is the same design that a computer mouse uses. Open one up and you will get an idea how it all goes together, keeping in mind that the mouse is a higher resolution than you will need. Reflective opto couplers also work well. We have used the Banner sensors looking at alternating white and black patches on our wheels for many years.
Unread 14-06-2005, 09:34
El Jefe de 148
How has your experience with the Banner sensors been? Do you have any advice on how to make them work most effectively? They seem like a pretty cheap and simple solution, especially considering the massive quantities we have from past kits. Given the cost differential compared to encoders (free, vs. $40-$50 apiece), would you recommend I try the Banner sensors for my summer project?
Jeff Waegelin
Unread 14-06-2005, 09:47
Software Engineer
Rookie Year: 1995
The Banner sensors worked great, however there were some reasons we abandoned them. First, setting up an encoder based on Banner sensors takes up a lot of space (if you need to be able to measure direction as well as rotation, then you'll need 2 sensors per wheel). It's also important to note that different versions of the Banner sensors were included in the kit each year. There's 2 types: one that is designed for detecting retro-reflective tape, and the other which works for things like line following (looking at white tape, much closer to the sensor). To be honest though I don't think we had much trouble using either model with our wheel encoders. If you're using 2 sensors per wheel (to be able to determine direction), then you need to mount them carefully as the square waves generated by each encoder need to be 90 degrees out of phase. We used a pinwheel of alternating black and aluminum "pie slices" with the Banner sensor mounted about an inch away. Here's the best picture I could find that shows our Banner sensor wheel from 2003 and 2004:
Unread 14-06-2005, 13:23
Thanks for the pic, Dave.
Jeff, it is easy to see from the picture the rough resolution of this type of sensor. The wheel is about 6" dia.
Unread 14-06-2005, 15:36
Git 'em!
I know that our programmers found that with holonomic drive the higher resolution you have the better things work. And it takes quite a while to get 4 encoders running and not crashing the R/C
Robot in 3 Days
Unread 15-06-2005, 14:05
El Jefe de 148
I was looking at the Digikey catalog, and I found something that might work. It's made by Grayhill, and is part number 61C11-01-08-02, found on page 1262 of the Digikey catalog. Would these encoders work for my purpose? Bear in mind that this is a summer prototype project, so it doesn't necessarily have to go through a full season of use and abuse. If they aren't up to it, I can spend the extra money on the Bourns encoders, but I'd prefer not to, if don't need to.
Jeff Waegelin
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
shaft encoder help stephenthe1 Programming 2 03-12-2004 16:09
Wiring "3-pin" Shaft Encoder. Joel J Programming 7 27-02-2004 17:21
Problem with 5/8 in. shaft in this years kit echos Kit & Additional Hardware 5 14-01-2004 21:21
