Go to Post I really think we need to keep our pitchforks sheathed and torches unlit until we here more news and get more details. - IndySam [more]
Unread 14-06-2005, 06:52
Gal Longin's Avatar
Gal Longin Gal Longin is offline
Gal L.
#1578 (IsraBot)
Gal Longin is an unknown quantity at this point
Send a message via ICQ to Gal Longin Send a message via AIM to Gal Longin Send a message via MSN to Gal Longin Send a message via Yahoo to Gal Longin
interrupt in default code
I'm sorry if such a topic already exists but i couldn't find anything about it(and i have read "Interrupts for Dummies" ).
i was trying to understand the default code and i have a few questions about using interrupts.
in the user_routines_fast.c there's a function called interrupt handler, but i can't seem to find what triggers it within the code. is there some section of the code that interrupts the regular processor activity and calls this function or does the processor do it itself. if so, is it the master processor or the user processor?
"Only two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." -Albert Einstein.
2005 Israel regional Finalist
2005 Israel regional Johnson & Johnson Sportmanship Award
2005 Israel regional Website Award
Unread 14-06-2005, 07:05
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: interrupt in default code
The interrupt function is never directly called in the default code (and shouldn't really be in your code). In fact, it never even runs with the default code.
If you want to use the interrupt, you must enable it in user_intialization(). When the interrupt(s) you specify are triggered (such as a digital IO going high), the interrupt handler is run.
Of course, I never got them to work, so...
Unread 14-06-2005, 09:01
Electrical Engineer
Rookie Year: 1995
Gal,
I strongly suggest that you download http://kevin.org/frc/frc_interrupts.zip to get a fast understanding of interrupts.
Mike
Mike Betts
As easy as 355/113...
Unread 04-02-2006, 13:55
Athena Athena is offline
FRC #1676 (Pi-oneers)
Athena is on a distinguished road
Uhhh....the hyperlink isnt working. anyways. We are having problems with our interrupts as well. i just tried to enable them, and nothing happens. does somebody have any suggestions?
Unread 04-02-2006, 19:49
Electrical Engineer
Rookie Year: 1995
Athena,
Kevin moved that file here to make room for the 2006 stuff. Although you can not compile and run directly on the 2006 RC (the uP changed) the basics have not changed and certainly you can cut and paste into your 2006 code.
After looking it over, please post any specific questions and I will try and answer them.
Mike
Mike Betts
Unread 04-02-2006, 20:10
Andrew Blair's Avatar
FRC #0306 (CRT)
Kevin's code really is wonderful. Its really well commented. In fact, I'm using it right now to write our code. I can't recommend it enough.
-Sir Francis Bacon
-Albert Einstein
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Best Way To Insert Autonomous Code Into Default then load help.? :-)? gemccnp Programming 2 05-02-2005 18:58
default code vs. 2.4 stephenthe1 Programming 2 05-02-2005 18:02
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
