Go to Post FIRST isn't about the money. It is about the experience. - dubious elise [more]
Unread 13-06-2005, 10:14
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
Mechanical Desktop 2004 DX/AutoCAD 2004 and AutoCAD 2005
Do I need both Mechanical Deskop 2004 DX/AutoCAD 2004 and AutoCAD 2005 installed? If so, what are the differences?
Unread 13-06-2005, 13:12
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Mechanical Desktop 2004 DX/AutoCAD 2004 and AutoCAD 2005
I'm sure you don't need both AutoCAD 2004 and 2005. As for AutoCAD vs Mechanical desktop, I really haven't found any difference between them. (but then again I mostly just use Inventor) Maybe someone can enlighten the both of us.
Unread 13-06-2005, 14:57
AKA: Steve
When I open Mechanical Desktop it says AutoCAD 2004 at the top so they are probably the same. So I can uninstall it and all the other Autodesk stuff will still work?
Unread 13-06-2005, 15:26
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Think of Mechanical Desktop as a parametric add on package to regular AutoCad. So when you installed the 2004 Desktop - you installed AutoCad 2004 with the Mechanical Desktop add on package. Then you apparently also installed AutoCad 2005. So the Desktop package won't carry up to the 2005 installation. So you've really got 3 different things there. If you want to use all the extra features Desktop has then I'd stick with the 2004 installation.
Desktop comes with lots of 3d hardware, it does some FEA analysis. It allows much more capability in modeling that regular AutoCad can't do. Then formost it lets you constrain your detail and use parametric dimensioning. Plain AutoCad draws unintelligently. Also Desktop has some great features for detailing and drawing setup.
There weren't that many changes from 2004 until now (v2006). If I were you I'd play around with the Desktop. There's more to learn and it's a much more powerful tool. Here at work we just use regular AutoCad for the streamlined simplicity and commonality though. Most industry also keeps the standard AutoCad for drafting. It's unfortunate to see all the capability lost in appealing to the lowest denominators of industry. AFAIK the same applies to inventor. Industry isn't ready to switch over to Inventor no matter how hard Autodesk pushes. Autodesk wants to quit production of Mechanical Desktop and get us all on Inventor, but we love our Desktop too much. Inventor is a whole nother animal, and when you've been creating products from AutoCad for years and years, you can't just switch to another software that's not compatible without heavy refit and training costs.
That's too much info but a good lesson in the why's of what you're asking.
www.179swampthing.org
Unread 14-06-2005, 09:27
AKA: Steve
Ok, well the reason I was asking because both AutoCAD 2004/Mechanical Desktop and AutoCAD 2005 came in the Autodesk software package we got. I think most people use Inventor for robotics stuff so should I just keep AutoCAD 2005?
