Go to Post Because of the silly "What's the best 254 team" thread I recently found there is an Electric Sheep! 2546. TBA also says 2505 is The Electric Sheep But which team is the one androids dream of? - Katie_UPS [more]
Unread 14-06-2005, 08:12
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Socket programming in VC++ 2005
I recently downloaded the VC++ 2005 Beta 2 from MS. I haden't worked with it before, so this morning I set out to create a simple network app to check if my server is up and accessible from the outside world. (And yes, I'll give it to a friend, where he'll set it up as a scheduled task.) I could have finished it by now in VS.NET 2003, but it appears that sockets are somewhat different in 2005. I'm unable to find the proper header/library to use. Winsock as a direct library doesn't appear to exist anymore and I couldn't seem to find a non-.NET way of doing it.
Do you know how to create a socket in 2005? All it has to do is check if it can connect to a certain server on port 80, if that makes a difference. (but if you happen to know how to use the .NET version, I might have to.)
I'm stubborn, so don't even suggest I just use 2003.
Unread 14-06-2005, 15:35
FRC Key Volunteer Trainer
AKA: CrazyNate
Re: Socket programming in VC++ 2005
I haven't actually worked with it, but check this page out...
http://msdn2.microsoft.com/library/1...us,vs.80).aspx
BTW, if you didn't know this already, http://msdn2.microsoft.com is all of the documentation for VS2005...note that some parts are still incomplete, since it is still in beta...
Nate Smith
nsmith@smythsoft.com
Unread 14-06-2005, 15:47
Programming User
Yes, I did know that that was where the docs where, but I didn't find the first link. Thanks.
Now... how exactly do you include that in your C++ program? The System.[etc] syntax is used directly in C#, but in C++...?
Unread 15-06-2005, 20:03
fowlerm's Avatar
fowlerm fowlerm is offline
Bringing .NET to Robots
AKA: Matthew Fowler
FRC #0312 (Heatwave); FRC #1369 (Minotaur)
fowlerm has a spectacular aura aboutfowlerm has a spectacular aura aboutfowlerm has a spectacular aura about
This article covers simple network tasks with .NET 2.0, it uses all managed code though.
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
2005 Beantown Blitz Registration Notice Erin Rapacki Off-Season Events 9 30-04-2005 14:04
2005 St. Louis Regional Andrew Regional Competitions 6 14-03-2005 10:17
What should I put on my programming jump drive? IMDWalrus Programming 10 15-01-2005 13:37
