Go to Post And to think, a lot of students are planning parties and celebrations on their last day of school and you guys are recycling trash. - JaneYoung [more]
Unread 15-06-2005, 15:07
Re: Which shaft encoder to use?
Originally Posted by Jeff Waegelin
... Grayhill, and is part number 61C11-01-08-02, found on page 1262 of the Digikey catalog. Would these encoders work for my purpose?
It's rated for human hand turning speed. You can't spin the encoder shaft very fast.
So the question becomes how fast (rpm) do you plan on gearing it?
Unread 15-06-2005, 15:10
Jeff,
Go to the Grayhill site to be sure, but many of these encoders are not continuous rotation. The flag for me was the spec that an operational cycle was a full rotation through all positions and a return to zero. Since one application is for frequency set on a radio this may be only a 250-270 degree rotation with 32 detents. When checking devices be sure to find the spec on the maximum allowable rotational speed as well.
Unread 15-06-2005, 20:09
Gdeaver Gdeaver is offline
FRC #1640
Check out BG micro. They have a surpluss assemble that includes 2 encoders.
Real cheap. I don't think i would use these for a competition bot but, for some summer experimentation they would be fine.
http://www.bgmicro.com/lmad3.asp
8.95 plus shipping. There are also some goodies in the catalog. They have some tech docs online but they suck.
Unread 16-06-2005, 09:21
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Originally Posted by Al Skierkiewicz
Jeff,
I checked Grayhill, and it is a continuous-rotation encoder, but it's only rated for 16.6 RPM, and has detents on it. So, it looks like this one won't work, after all.
Jeff Waegelin
Unread 16-06-2005, 09:59
The variation offered for sale by Digikey does not have detents, but it is a slow turning shaft.
Unread 16-06-2005, 10:56
El Jefe de 148
So I'll pose another question: does anyone know where I could get acceptable encoders for less than $45-50? I have a limited budget, so I'd rather not have to spend that much if I don't have to.
Jeff Waegelin
Unread 16-06-2005, 12:50
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
This may be a really dumb suggestion, but.....
Would it make sense to try to salvage encoders out of something like an old copier or printer? You could use an oscilliscope to figure out the wiring of it. Would be cheap.
Unread 18-06-2005, 03:57
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Jeff, my limited experience with encoders is with the Grayhill 63R series, which would work great, but are a little above your price range.
HOWEVER, we did use the hall effect gear tooth counters that came in the 2005 kit with varying amounts of success. They are definitely affordable, however to determine direction, all we did was check what our PWM output was for the appropriate motor.
We actually didn't count gear teeth, but sprocket teeth. The sensors seem to be resilient enough to pick up just about any ferrous material that comes close enough to it.
It's not an encoder, but it might be an affordable option.
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
shaft encoder help stephenthe1 Programming 2 03-12-2004 16:09
Wiring "3-pin" Shaft Encoder. Joel J Programming 7 27-02-2004 17:21
Problem with 5/8 in. shaft in this years kit echos Kit & Additional Hardware 5 14-01-2004 21:21
