Re: belt drive/tank treads
You can buy timing belts with numerous different backings from www.brecoflex.com Lead time can be quite long, and they are very expensive. The stuff 980 and countless other teams have used on their wheels is wedgetop conveyor belting, available from McMaster.com. It's not going to work as an actual tank tread though--just a traction material for your wheels. |
im familiar with the compresed neoprene and rubber strips used for traction on wheels, but tank treads? i swear ive seen teams use them. any idea where to get anything similar (and please dont say synchronous or double sided timing belts. ill go crazy. i promise). |
Two words: Breco flex. There Belts are amazing a little expensive but you can't beat them. Another thing I would like to add if you doing a belt drive spend the money on good belts it's worth it trust me, Bad belts are the worst thing. Breco Flex has many models of belts that you can chose from. www.Breco Flex .com
My Team 1251 used belts not breco flex but we got a pretty good system going so check our bot out. http://www.chiefdelphi.com/forums/sh...techtigers+botMy two cents, -Drew 1251 The Tech Tigers "We even bleed Orange" Last edited by techtiger1 : 15-06-2005 at 17:53. |
This is a picture of the best close up of our treads from 2004 and then Cyber Blue 234's finished robot. We found these treads at http://www.thistle.uk.com. They worked amazingly well for us. We could shoot up the 6 inch step without any problems.
Dave that my man is how you do treads right there. Thanks for posting the great pictures.
One of my favorite all time bots right there. Cyber blue rocks a model bot and model team right there. Definitely study that example right there for tank treads. The v belt system is awesome definitely use it, the belts will tend to track off if you don't. We learned that from experience. Well done, -Drew Tech tigers 1251 |
Team 180 has used treads for most of it's existence.
Brecoflex is the way to go, if you want treads. They aren't cheap, but they can be made to any length that you want. We have tried several different backings, but the green and blue diamond patterns (I have no idea what they are really called) give very good traction. On our 2002 robot, Fluffy, we saw a 2.0 coefficient of traction. In other words, our little 130 lb robot pushed with 260 lbs of force. It worked quite well at dragging opponents and goals around the field. |
#7
The other nice thing about the brecoflex belts is that they dont tear easily. They can really take a beating because inside of some the belts there is a steal ribbon. This gives them a very long service life on the field. In 2004 we made it through one regional and four offseason competition's on the same set of belts.
-Pat |
#9
Brecoflex has Team 48's vote!
#10
We(team 61) have had great success with treads from brecoflex.. the past 3 years we have not ripped more then 2 all season… which is awesome. brecoflex is the best way to go.. if you have questions drop Mike Norton a PM he has all the answers when it comes to brecoflex
Feel free to stop by out web site http://www.valleytech.k12.ma.us/Robotics Lots of pictures |
#12
Hmm interesting...from my experiences with brecoflex(reinforced only) it is quite strechty because of the pvc like material and steel reinforcement that its made of...I wonder if the belts were too tight or if the grating ripped them...very interesting, I'd def like to hear more about this problem they had. I guess i should say that under normal carpet driving conditions they are extremely durable. Good catch. -Pat |
#13
http://www.fnsheppard.com/index.htm
offers the same things as brecoflex, but their lead time is significantly shorter for machining the pulleys. They are slightly more expensive, but time is money. |
#14
| Has 6 wheeled designs surpased tank treads | Andrew Schuetze | Technical Discussion | 60 | 27-04-2005 17:29 |
| How do you Calculate Belt Length? | Gabriel | Technical Discussion | 7 | 08-11-2004 14:54 |
| Connect Conveyer Belt to self | santyclaz | Technical Discussion | 7 | 06-02-2004 01:45 |
| vertical conveyor belt | ahecht | Technical Discussion | 3 | 15-02-2002 16:16 |
| What problems have you encountered using treads? | M.I. | Technical Discussion | 8 | 15-01-2002 22:13 |
