Go to Post While many teams like to go fast, only a select few do it well. - Al Skierkiewicz [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 15-06-2005, 16:03
dradius's Avatar
dradius dradius is offline
breakdancaz
AKA: ryan
FRC #0624 (CRyptonite)
dradius will become famous soon enough
Send a message via AIM to dradius Send a message via MSN to dradius
belt drive/tank treads
hey guys, got a question.
for all of the teams that have utilized a tank tread design on their robots, where did you get the tread? did you have to order it, or make it yourself? i'm finding that it is INCREDIBLY hard to find decent rubber treads (or anything for that matter). im looking for something like 980 had two seasons ago (i'd give a picture but i can't scan my brain. sory guys).
thanks
pessimist: glass is half empty
optimist: glass is half full
engineer: glass is twice the size it needs to be
--bringing green spikes and fishnets back in to style, baby--
Unread 15-06-2005, 16:19
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: belt drive/tank treads
thanks
980 didn't use treads in 2003. Perhaps you're thinking of another team?
You can buy timing belts with numerous different backings from www.brecoflex.com Lead time can be quite long, and they are very expensive.
The stuff 980 and countless other teams have used on their wheels is wedgetop conveyor belting, available from McMaster.com. It's not going to work as an actual tank tread though--just a traction material for your wheels.
2001-2004: Team 100
2006-Present: Team 254
Unread 15-06-2005, 16:57
dradius's Avatar
breakdancaz
AKA: ryan
ah. i see. maybe 981? honestly, i cant remember anymore. still, im talking 2004 though, two seasons ago.
im familiar with the compresed neoprene and rubber strips used for traction on wheels, but tank treads? i swear ive seen teams use them. any idea where to get anything similar (and please dont say synchronous or double sided timing belts. ill go crazy. i promise).
Unread 15-06-2005, 17:20
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Two words: Breco flex. There Belts are amazing a little expensive but you can't beat them. Another thing I would like to add if you doing a belt drive spend the money on good belts it's worth it trust me, Bad belts are the worst thing. Breco Flex has many models of belts that you can chose from. www.Breco Flex .com My Team 1251 used belts not breco flex but we got a pretty good system going so check our bot out. http://www.chiefdelphi.com/forums/sh...techtigers+bot
My two cents,
-Drew
1251 The Tech Tigers
"We even bleed Orange"
Unread 15-06-2005, 17:33
David Hoff's Avatar
David Hoff David Hoff is offline
FRC #4050 (Biohazard)
David Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to all
This is a picture of the best close up of our treads from 2004 and then Cyber Blue 234's finished robot. We found these treads at http://www.thistle.uk.com. They worked amazingly well for us. We could shoot up the 6 inch step without any problems.
Cyber Blue Team 234: Indianapolis, IN 2002-2006
Purdue FIRST Programs: West Lafayette, IN 2006 - 2010
Cyber Titans Team 3793: Frederick, MD 2012
Biohazard Team 4050: Chambersburg, PA 2014
Unread 15-06-2005, 17:59
techtiger1's Avatar
Coach Drew?!?!
AKA: Drew Disbury
Dave that my man is how you do treads right there. Thanks for posting the great pictures. One of my favorite all time bots right there. Cyber blue rocks a model bot and model team right there. Definitely study that example right there for tank treads. The v belt system is awesome definitely use it, the belts will tend to track off if you don't. We learned that from experience.
Well done,
-Drew
Tech tigers 1251
Unread 16-06-2005, 12:39
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
Team 180 has used treads for most of it's existence.
Brecoflex is the way to go, if you want treads.
They aren't cheap, but they can be made to any length that you want.
We have tried several different backings, but the green and blue diamond patterns (I have no idea what they are really called) give very good traction.
On our 2002 robot, Fluffy, we saw a 2.0 coefficient of traction. In other words, our little 130 lb robot pushed with 260 lbs of force. It worked quite well at dragging opponents and goals around the field.
Warren B
Pool Noodles. They're not just for bumpers anymore.
Unread 16-06-2005, 12:48
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Having gone against Fluffy at Nationals that year, with my old team (201), I can testify to its toughness. They were the only team that could outpush mine, and they did it not once, not twice, but 3 times. That tread was the best stuff I've ever seen.
Jeff Waegelin
Unread 16-06-2005, 17:09
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
The other nice thing about the brecoflex belts is that they dont tear easily. They can really take a beating because inside of some the belts there is a steal ribbon. This gives them a very long service life on the field. In 2004 we made it through one regional and four offseason competition's on the same set of belts.
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 16-06-2005, 17:37
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Brecoflex has Team 48's vote!
Unread 16-06-2005, 19:25
Cory's Avatar
AKA: Cory McBride
-Pat
I seem to remember 226 tearing a whole ton of belts in 2003(?), even the reinforced ones, which I believe they said they paid something like $400 a pop for.
2001-2004: Team 100
Unread 16-06-2005, 20:43
BillyGoats BillyGoats is offline
Paper Eater
None #0061 (Intimidators)
BillyGoats can only hope to improve
Send a message via AIM to BillyGoats
We(team 61) have had great success with treads from brecoflex.. the past 3 years we have not ripped more then 2 all season… which is awesome. brecoflex is the best way to go.. if you have questions drop Mike Norton a PM he has all the answers when it comes to brecoflex
Feel free to stop by out web site http://www.valleytech.k12.ma.us/Robotics
Lots of pictures
Keep It Simple - Team 61's Motto
Any Thing on out Robot Can be Fixed in 5 Mins!
2005 Motorola Quality Award
2004 Battle Cry 5 @ WPI Eighth Finalists...4th Seed! 6-3 Record! Thx 237 & 830!
2004 Mayhem on the Merrimack Champions! 4th Seed! 9-2 Record! Thx 562 & 1289!
2004 Mayhem on the Merrimack Fastest Robot Award!
2004 Beantown Blitz Champions! 4th Seed! 11-1 Record! Thx 571 & 1100!
2004 National Semi Finalists
2004 Florida Regional Judges Award
2004 Florida Regional Champions! Thx 945 & 386!
Unread 16-06-2005, 22:07
Mechanical Engineer
Hmm interesting...from my experiences with brecoflex(reinforced only) it is quite strechty because of the pvc like material and steel reinforcement that its made of...I wonder if the belts were too tight or if the grating ripped them...very interesting, I'd def like to hear more about this problem they had.
I guess i should say that under normal carpet driving conditions they are extremely durable. Good catch.
-Pat
2010 and Beyond
Unread 17-06-2005, 02:03
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
http://www.fnsheppard.com/index.htm
offers the same things as brecoflex, but their lead time is significantly shorter for machining the pulleys. They are slightly more expensive, but time is money.
Unread 19-06-2005, 23:16
Paper Eater
these are not the "re-enforced ones" and this is what we do to them.. we did not rip one re-enforced one this year...
Has 6 wheeled designs surpased tank treads Andrew Schuetze Technical Discussion 60 27-04-2005 17:29
How do you Calculate Belt Length? Gabriel Technical Discussion 7 08-11-2004 14:54
Connect Conveyer Belt to self santyclaz Technical Discussion 7 06-02-2004 01:45
vertical conveyor belt ahecht Technical Discussion 3 15-02-2002 16:16
What problems have you encountered using treads? M.I. Technical Discussion 8 15-01-2002 22:13
