Go to Post It is not your banners that make you nor the trophies that line your walls. It is the willingness to be brave in the face of defeat and compassionate in the winds of victory that create you. - MysterE [more]
Unread 22-05-2002, 11:27
Ashley Weed Ashley Weed is offline
Rookie Year: 1995
Ashley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond repute
Angry changing radio contact
For the first time ever, my team will be running two robots. We usually can not keep a robot functional for over a year. However, we found a problem when running them at the same time. It doesn't work!!! Would someone please assist me in getting our robots to run at the same time on different channels for community events. Thank you!
Unread 22-05-2002, 11:41
FRC Key Volunteer Trainer
AKA: CrazyNate
See the white papers on this site for the "Yellow Dongle". This includes a jumper which allows you to use the channel DIP switches on the Operator Interface to choose from 1 of 4 additional channels.
The Issue you're running into with running multiple robots at the same time is that two machines cannot operate on the same channel simultaneously, even if you have the team numbers set differently, which you WILL want to do.
Nate Smith
nsmith@smythsoft.com
Unread 22-05-2002, 13:09
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Use it with last year controller
You'll want to use the Yellow Dongle with your old controller, since Innovation First changed the pinout for the competition port in this years controller, and they didn't update the manual to include that.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 22-05-2002, 15:07
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
whats the website for those jumper settings?
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 22-05-2002, 16:04
AKA: CrazyNate
Check out Innovation First's web site.
Nate Smith
Unread 22-05-2002, 16:20
Rookie Year: 1995
Talking more help
Thanks for all the help. I found the info. in the White Papers. However, is this something that our team should have, or are we going to have to get one of these? If so, where would we get it?
Unread 22-05-2002, 19:55
Jim Giacchi's Avatar
Jim Giacchi Jim Giacchi is offline
FRC #0041 (Robo-Warriors)
Jim Giacchi will become famous soon enoughJim Giacchi will become famous soon enough
Send a message via AIM to Jim Giacchi
Re: Use it with last year controller
Could you clarify this?
What changes
Build first ask questions later.
Unread 22-05-2002, 21:17
AKA: CrazyNate
Re: more help
Use the instructions in the white paper to make one of your own...you might need to contact Innovation First (see their web site link above) to find out how the pinout was changed on the competition port for this year...
Nate Smith
Unread 23-05-2002, 09:33
The Yellow Dongle paper, and the Control Sytem Users Manual V1.0 (p 18 + 19) both tell you to connect pin 12 to pin 15 to allow access to the channel change feature. They also tell you to connect a switch from 6 to 8 to disable the robot outputs (killl switch), and this does not change.
Innovation First told me in an email this season, that pin 15 may be required for something else in future, and to use pin 8 for grounding pin 12. This works on all previous years' OIs as well.
BTW, I found that the Dongle's power light, which goes on when the robot is active, does not work when the robot is on tether. The light being out, although the switch is not in "kill", might lead you to think that the tethered robot is disabled and safe to work on, but if someone toys with the controls, also relying on the light and thinking it safe, dangerous motion could occur.
Note that the robot looks the same enabled or disabled, with all those lights lit up and blinking. Only old hands who are familiar with how the dongle works, and know what the light means when running on a "Wall Wart" power supply, will get, or give, hurt, with this tether power quirk.
Unread 23-05-2002, 16:08
Don's Avatar
Don Don is offline
#0288 (the RoboDawgs)
Don is an unknown quantity at this point
Send a message via AIM to Don
Be Safe. Shut off the robot's main breaker before doing any work on the robot. Who knows if the little wire grounding the disable pins is worn out or not.
Unread 23-05-2002, 21:03
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Re: more help
...Just use a piece of 24 gauge wire (stripped at the ends of course) or a paper clip... that works just as well.
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
What is incidental contact? Ken Loyd General Forum 16 24-02-2003 11:10
need to contact team 1204 dan2003 Scouting 1 04-02-2003 21:53
radio transmitters Arin Technical Discussion 2 18-12-2002 01:59
I'm trying to contact Teams 234 and 269... archiver 2001 1 24-06-2002 03:23
radio meetings all star archiver 2001 9 24-06-2002 03:10
