Go to Post if you put 3 controls engineers in a room you will get 4 different way to do tuning. - FrankJ [more]
Unread 16-06-2005, 11:46
fowlerm's Avatar
fowlerm fowlerm is offline
Bringing .NET to Robots
AKA: Matthew Fowler
FRC #0312 (Heatwave); FRC #1369 (Minotaur)
fowlerm has a spectacular aura aboutfowlerm has a spectacular aura aboutfowlerm has a spectacular aura about
Re: Programming a 2nd PIC
I believe RCD8:1 means RCD8 is defined as an alias for the first bit of the structure, and the :5 is a placeholder so the next 5 bits are not aliased as anything, and then RC9 is defined as an alias for the 7th bit of the structure.
Unread 16-06-2005, 12:13
ImmortalAres ImmortalAres is offline
ImmortalAres is an unknown quantity at this point
wow, so that .h file just saved me 3 days thanks for the heads up on that. that's exactly what i needed
VEX programming Gene F Programming 14 08-08-2006 22:21
Organizing a programming team. scitobor 617 Programming 7 28-01-2005 19:18
'Fix It Window' and Programming.... JMac Programming 19 25-01-2005 18:57
Programming and Electronics — Getting Started Sidney San Martín Technical Discussion 7 12-01-2005 15:25
pic: Match 0105: 2nd highest score in the nation CD47-Bot Extra Discussion 6 31-03-2003 11:14
