Go to Post Teams rarely win FIRST events because they can complete actions that nobody else can; they win because they do things faster than others. - Madison [more]
Unread 17-06-2005, 15:38
foobert foobert is offline
foobert is a jewel in the roughfoobert is a jewel in the roughfoobert is a jewel in the rough
Re: Alternate Controller
oops, sorry, dude. i meant a picture of the 'scope screen, though i guess if the signal's changing too fast that might not be possible. but it seems like it should be possible with a reasonably fast shutter speed. say 1/1000 sec, if your camera has a manual or shutter priority setting.
ah, lunch time's over. must get back to the grind...
Unread 28-06-2005, 08:12
No guarantees, but i'd guess this guy is describing what comes out of the r/c unit. He also describes a pic based circuit to generate the signal under the control of a pc. Unless you're dead set against programming the vex, though, i'd still say use the serial port.
Speed controllers won't communicate w/robot controller steven114 Control System 12 03-02-2005 21:26
Program error after controller reset randomperson Programming 6 04-01-2005 23:31
not quite sure...speed controller...spike. tophq Programming 8 26-03-2004 13:43
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
