Go to Post There are a maximum of 80 balls in play . If all the balls are in the goals or out of play and the human players won't throw them back in, I guess the robots might try line dancing or doing the cha-cha. - Rick TYler [more]
Unread 06-19-2005, 04:24 PM
Best Available Data
FRC #1778 (Chill Out!)
pic: Kaizen at BattleCry
Unread 06-19-2005, 04:27 PM
Winged Globe Winged Globe is offline
Don't Panic
AKA: Xiao-Yu Fu
FRC #0481 (The Hitchhikers)
Winged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of light
Send a message via AIM to Winged Globe
Re: pic: Kaizen at BattleCry
So... was the single blue tetra on the yellow triangle of the toppled goal "contained" and scored? Was the other blue tetra seemingly on the toppled goal "stacked"?
Team 2B0
~O~
Unread 06-19-2005, 07:59 PM
evelyn1503's Avatar
evelyn1503 evelyn1503 is offline
AKA: supper sister fix-it
AKA: evelyn palleschi
FRC #1503 (Spartonics)
evelyn1503 is on a distinguished road
OMG how did they do that.... thet is the coolest thing i have seen but thet must have cose someone some points
Evelyn Palleschi
2005 Pit Captain
2005 Waterloo Regonal--Semifinalist
2005 Grater Toronto Regonal-- Finalist
2005 World Finals(Atlanta- Curie)--Quarterfinalist
2005 Canada's Wonderland( Off Season)--Champions
Cheering takes spirit, spirit sparks dreams, dreams become possibilities, possibilities become realities....NEVER STOP CHEERING
Unread 06-19-2005, 08:16 PM
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
Although I was not on that side of the field, I have an idea as to how it might have been scored. SOme of you may recall the center goal being tipped over at Mayhem, this is similar. When a goal is tipped, the opposing alliance owns that goal. So, if a red robot tipped that goal over, it would belong to blue.
I do not know about the tetras that would have been in. Rules allow removal of contained tetras, so the one on the ground probably wouldnt count. The one in the goal might, but it isnt stacked. Look closely, you will see that the one in the corner of the tipped goal is sitting in the apex of the goal. You can tell because 1) if it was stacked, the metal pipes would be inside the blue tetra, and 2) the apex resting against the neighboring goal was probably because the goal was probably dislodged first, and then tipped, with the pipe that is currently flat on the ground on the axis, and 3) for that side to be the top, the face of the goal that is close to the alliance station would have velcro on it, which by looking at the reflection in the diamond plate, it does not.
However, if the goal did have a tetra that was stacked on it which came off in the tip, it would probably be ruled as a descoring, so the opposing alliances's tetras would be scored (and the opposing alliance owns the goal already since it was tipped).
Any other refs have an opinion? This was only my second time reffing so I could be wrong.
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 06-19-2005, 08:47 PM
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Here's another camera angle of the same incident.
I was sitting in the first few rows of stands near the center of the field.
I did not see what happened during the match at all. I was looking at the other side of the field when I heard their robot hit the ground. I looked over and this is what I saw.
1276, did the fall bend your arm at all? It looks very slightly bent in the picture I took.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 06-19-2005, 08:58 PM
tckma's Avatar
tckma tckma is offline
AKA: Tom C.
FRC #2199 (Robo-Lions)
tckma has a spectacular aura abouttckma has a spectacular aura abouttckma has a spectacular aura about
Send a message via ICQ to tckma Send a message via AIM to tckma Send a message via Yahoo to tckma
I can't believe I didn't see that! I must have been in the pit at the time!
Tom C.
Software and Controls Mentor
Team 2849
Prior team associations: 1418 ('08-'09), 1100 ('05-'08), 811 ('02, '04-'05), 246 ('03)
Unread 06-19-2005, 10:19 PM
Best Available Data
It was not bent but that fall snapped our arm pulley causing us to lose the use of our extension for two matches before it was fixed.
pic: BattleCry Action KathieK Extra Discussion 1 06-19-2005 04:16 PM
Programming a 2nd PIC ImmortalAres Programming 8 06-16-2005 12:13 PM
pic: #383 Brazilian Buddy VI - Pic 1 Manoel Robot Showcase 2 03-07-2005 11:03 PM
Battlecry 2(k1) Jon Abad Rumor Mill 3 06-06-2001 08:28 PM
