Go to Post Yes, the real world is like that. Let's operate on a higher plane. - Taylor [more]
Unread 21-06-2005, 08:33
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Need assistance for a -40 degree cold chamber
Since there are a lot of very smart people from all sorts of industries on here, I thought I would throw this out.
We are trying to design a flexible cold chamber to go over a test article connected to a dynamometer. The chamber will be feed with 150,000 btu/hr and needs to be able to go down to -40 degrees. It also needs to be flexible at that temperature. And fire resistant. The chamber will be about 3 m x 3m x 3m in size.
I was thinking that maybe some of you space guys might have some ideas... Thanks.
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 21-06-2005, 09:15
Erin Rapacki's Avatar
Erin Rapacki Erin Rapacki is offline
General Manager
Erin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond repute
Send a message via AIM to Erin Rapacki
Re: Need assistance for a -40 degree cold chamber
Have you searched your area for environmental test facilities? Last year I worked with a test facility who had about twenty, very durable, hot and cold chambers for testing electrical and mechanical hardware. Some were large, some were small, but all of them were so expensive that it was a better idea to contract the work out to the company who manages these chambers instead of building/buying our own.
http://www.linkedin.com/in/erapacki
BUZZ 175 (01, 02) - NUTRONS 125 (03, 04) - QUEEN 1975 (06)
Beantown Blitz Founder (04) - FIRST Robotics Conferences (04) - Boston Regional Volunteer Coordinator (06)
Unread 21-06-2005, 10:31
Don Wright's Avatar
FRC #0469
While that would be a good idea, it won't work for us in this case since we are delivering the dyno system and it needs the chamber with it. Do you by any chance remember the manufacturer of the chambers you spoke of?
Product Manager
Unread 21-06-2005, 11:15
Jimmy Holmes Jimmy Holmes is offline
It's not all about the robots
FRC #0027 (Team Rush)
Jimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of light
We use a chamber made by Envirotronics. They make a wide variety of chambers for many uses. Try this link for some products...http://www.envirotronics.com/products.html
Unread 21-06-2005, 11:23
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Don,
At Delphi in Kokomo, we use many chambers from Cincinnati Sub Zero. I think that they can do what you are looking for.
Andy B.
Unread 21-06-2005, 13:00
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
We use chambers from all of the already mentioned vendors, along with Thermomtron http://www.thermotron.com
Also, check out Scientific Climate Systems http://www.dryrooms.com/environ/index.html
The combination of -40, flexible, fire resistant, and 150,000 btu/hour heat load is going to be a tough combination. There are not many materials that stay flexible at that temp. The heat load is going to require multi-stage cascade cooling, or liquid nitrogen (or CO2) assist. It also will need to be purged out with some sort of dry gas, or everything inside will suffer the "popsicle effect".
Does the entire chamber need to be flexible, or just one side? We have several chambers that are set up with rubber floors to allow vibration testing to be performed. The other 5 surfaces are stainless steel and insulated.
-jeff
Unread 21-06-2005, 13:28
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
One more link to throw out: Russells Technical Products. They make test chambers and we use them here at Motorola. They do a lot of custom chamber work for lots of different applications, and as a bonus they have engineers that are involved with FIRST.
Unread 21-06-2005, 22:08
We use chambers from Screening Systems. We also have an old Thermotron. The Thermotron is from the good old town of Holland, Michigan.
Unread 22-06-2005, 00:24
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
I would go searching on mcmaster looking for the material specs you need and then make it. But then again, i like to build my solutions instead of buying them
Hows my searching? Call 1-800-Green-Dots
Unread 23-06-2005, 13:38
Don Wright's Avatar
FRC #0469
Thank you for all your assistance.
I may have mis-wrote or spoke when I mentioned the 150,000 Btu. The chamber will be fed with cold air at -50 degrees C at a rate of 150,000 Btu/hr.
Maybe I'm still saying it wrong... I'm an EE...
Product Manager
Unread 23-06-2005, 18:24
Did you think about using a platinum cured silicone?
its properties are -100F to 475F operating
Unread 24-06-2005, 01:01
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
WOO HOO ( live there )
-Mike
Unread 24-06-2005, 10:29
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
I'm sure you have your own methods of keeping the chamber cold, but have you looked into Peltier cooling? It is really quite ingenious, and these things can get really cold or really hot.
Check it out:
http://www.peltier-info.com/
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 24-06-2005, 20:00
sounds like cooling isn't a problem, problem is getting materials to work with the requested properties at the range of temperatures
45 degree PVC angle fittings: which? archiver 2001 2 23-06-2002 22:53
