Go to Post When we got it tuned to the point where we were (reasonably) confident it wouldn't slam into Dave's ankle, we quit for the evening. - Kevin Watson [more]
Unread 22-06-2005, 14:18
ImmortalAres ImmortalAres is offline
ImmortalAres is an unknown quantity at this point
Question about kevin's code
the code found here: http://kevin.org/frc/edu_accel_lcd.zip
contains the following
// initialize CCP modules 2 & 3
	TRISEbits.TRISE7 = 1;		// set CCP pins to inputs
	TRISGbits.TRISG0 = 1;
	PIE2bits.CCP2IE = 0;		// disable the CCP interrupts
	PIE3bits.CCP3IE = 0;
	T3CONbits.T3CCP1 = 0;		// CCP 2 captures timer 1, CCP 3 captures timer 3
	T3CONbits.T3CCP2 = 1;
	CCP2CON = 0x05;				// initialize CCP modules to capture on each rising edge
	CCP3CON = 0x05;
	IPR2bits.CCP2IP = 0;		// CCP modules use the low priority interrupt
	IPR3bits.CCP3IP = 0;		//
	PIR2bits.CCP2IF = 0;		// make sure the interrupt flags are zero before...
	PIR3bits.CCP3IF = 0;		//
	PIE2bits.CCP2IE = 1;		// enable the CCP interrupts
	PIE3bits.CCP3IE = 1;		//
my question is about the 2 lines
this doesn't make sense to me. can someone please explain what's going on, the comment doesn't seem to match the code or does it and i'm jsut missing it
Thanks
Unread 22-06-2005, 16:11
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Question about kevin's code
I think that it means that whichever one you set to 1 will be the one that works.
That help any?
Unread 22-06-2005, 17:24
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Take a look at the datasheet, page 152, specifically figure 16-1. Notice Kevin is setting T3CCP1 to 0 and T3CCP2 to 1, which corresponds to T3CCP<2:1> = 10 in that figure. This shows that timers 1 and 2 are connected to CCP1 and CCP2, and timers 3 and 4 are connected to CCP3, 4, and 5. Then look at table 16-1 in the upper right corner, which says that in capture mode, timers 1 and 3 are available. You can check the settings of CCP2CON and CCP3CON to see that they are being set to capture mode, so you can conclude from all this that CCP2 captures timer 1 and CCP3 captures timer 3, just like the comment says.
Unread 23-06-2005, 11:13
i didn't realize that was what occurred. If i reversed it, T3CCP1 to 1 and T3CCP2 to 0 i should get the T3CCP<2:1> = 01 configuration correct?
Can we load 2004 code? colt527 Programming 5 15-02-2005 19:48
Need Advice On Code Out Of Box...New To This gemccnp Programming 4 30-01-2005 18:57
Operator Interface code RiotingNerd Programming 5 07-02-2004 21:13
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
