Go to Post Andy sent me this message last year: "you go, Jenny." I'm still waiting for him to say it's ok to stop. - RoboMom [more]
Unread 23-06-2005, 00:58
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
pic: Planetary...Wheel?
Matt Krass
Unread 23-06-2005, 00:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: Planetary...Wheel?
Can we get a view without that outermost plate and bearings so we can see the gears inside?
Unread 23-06-2005, 01:10
CraigHickman
Posts: n/a
Is a 10 inch wheel too big? (I don't know, so I ask), and as big, I mean overly large for the size of a robot that would be made for a FIRST competition....
Also- would it be possible to make this a 2 speed?
Unread 23-06-2005, 01:30
Matt Krass's Avatar
AKA: Dark Ages
Sanddrag, I'll post an exploded view tomorrow showing the planetary gearset.
Craig, my team has used 10" wheels with much success since the 2002 season. Also, I suppose you could replace the first stage with a shifter but that would defeat the point somewhat, this is meant to be simple and compact.
Matt Krass
Unread 23-06-2005, 03:28
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
I have been thinking about an in wheel transmission/gearbox like this, but the thing that worries me most is impacts and side loads.
I suppose if you can find a solution to that it would be great.
Keep the ideas flowing.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 23-06-2005, 11:51
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Matt,
Is the ring gear attached to the wheel? If so, what forces the wheel to turn? Most planetaries will allow the moons to spin around the sun when the outer ring is stationary.
I suppose this will be cleared up when you post the exploded view. I believe you want the moons attached to the wheel with the outer ring fixed to the frame.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 23-06-2005, 13:04
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Originally Posted by Andy Brockway
Matt,
As I understand it, having seen the exploded view, the sun gear is on the motor output, the planets are stationary, and the ring gear is locked to the wheel. If I'm not mistaken, this setup will cause the ring gear to spin in the opposite direction as the motor, with a reduction equal to the number of teeth on the ring, divided by the number of teeth on the sun gear. Is this correct?
Over all, I was pretty impressed with this design. Matt showed it to me a few weeks ago, and I was considering using it in a summer project, though I ended up going in a slightly different direction. It seemed to me like a pretty easy, compact way to do a direct-drive gear reduction.
Jeff Waegelin
Unread 23-06-2005, 13:09
Matt Krass's Avatar
AKA: Dark Ages
Matt,
It's not shown in the picture (yet) but six bolts will hold the ring gear to wheel, it's actually 1/8" thick, while the wheel has an 1/8" flange, total wheel thickness 1/4". The Sun and Moon gears are all idling on shafts (see those bearings in the plate? those are for the Sun and four Moon gears) while the ring will spin, and in turn the wheel. I will post the exploded later today, for now I need to clean my room before my parents yell .
Matt Krass
Unread 23-06-2005, 15:40
Matt Krass's Avatar
AKA: Dark Ages
I just posted the exploded views, two are already approved, the other two should be shortly, I hope this clears up any questions.
Matt Krass
Unread 23-06-2005, 16:24
Engineer
This is the same as I see it. I missed the planets being fixed. Do you know what the ratio would be if the outer ring is fixed and the wheel is attached to the planets?
A very interesting design. The first of the summer season!
Andy Brockway
Unread 23-06-2005, 16:48
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Originally Posted by Matt Krass
It's not shown in the picture (yet) but six bolts will hold the ring gear to wheel, it's actually 1/8" thick, while the wheel has an 1/8" flange, total wheel thickness 1/4".....
are you sure about this gear thickness? are the planet and sun gears an equal thickness? and what DP are these gears? while i don't have any calculations (i'm in the library "studying" for a final), 1/8" seems a little thin to me.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 23-06-2005, 17:08
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
Very cool. That could be a very interesting design, not only for drive wheels, but for other devices.
Here's my question - What keeps the ring gear from moving cross-vehicle? I think there are a couple of ways to solve this, but I was wondering what you had in mind.
Brian Graham
Unread 23-06-2005, 18:38
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
what's going to support the side load of the wheel? . looks like all the weight of the robot is going to be forced onto the bottom planet gear and In all my experience gears don't like to be smashed together like that at all. , also if that wheel takes any side load it's going to come off. both of those things can be solved with a big bearing. but Where Re you going to get one? those big bearings are hard to find, not to mention expensive. Thats a cool design but if i was planing on making a robot i would use something much simpler and less expensive.
Unread 23-06-2005, 19:35
Matt Krass's Avatar
AKA: Dark Ages
The side load problem is the one next on my list, this is a completely new area for me, so I'm kind of winging it, I have a few ideas to prevent the carrier gear from slipping off, I'm not sure about the downward forces on the planets, I was thinking of rotating them 45 degrees to spread the load across the two bottom gears, this is all brand new territory for me, and as far as I know, FIRST in general, though I could be wrong about that. Does anyone know of any similar designs used in FIRST?
Matt Krass
Unread 23-06-2005, 22:15
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'm not an expert on gears by any means, but I think just spreading the load across the gears won't help that much. Gears are meant to operated at fixed distances on fixed shafts. 25 pounds of force pushing the gears into each other isn't going to make them happy. Even if you could get it down to 5 pounds, you'd still lose a lot of efficiency. I think your best bet is to figure some way to get a bearing supporting the wheel so you're not using the gears as a bearing sort of surface. This would help with the side loads too.
I'm thinking a big thin section ball bearing that goes around your array of bearings there and slips inside a rim on the wheel. At that diameter a brass bushing might work as well.
pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side Vince Extra Discussion 6 09-01-2008 19:17
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
pic: Wheel got dented during a match davelu Robot Showcase 24 05-04-2005 23:58
pic: "Omni Grenade" Wheel D.Fahringer Extra Discussion 20 11-12-2004 13:02
pic: Planetary Gearset CD47-Bot Robot Showcase 3 22-12-2003 01:55
