Go to Post Successful teams - in almost any aspect of life (i.e. not just robotics) - don't make excuses and assign blame when something goes wrong. They improvise. They adapt. They overcome. They correct the problem and move on. - dlavery [more]
Unread 23-06-2005, 21:25
Re: pic: Planetary Wheel - Exploded View 4
Matt,
I like it! It has potential for reducing weight and keeping CG low, etc.
Andy, what if you changed the bearing plate, increased the surface area of the inside diameter of the hub and added a second plate on the outside so that you could use radial needle bearings on both sides of the wheel? That would take some pretty good side loads. The weight of the robot would be distributed to the bearings on the planetary set, right?
pic: Right Side view CD47-Bot Robot Showcase 2 03-03-2003 15:26
pic: 141's Robot stacking side view CD47-Bot Robot Showcase 7 28-02-2003 12:16
pic: 857 rear view programming CD47-Bot Robot Showcase 1 25-02-2003 22:24
pic: ROBOT FRONT VIEW CD47-Bot Robot Showcase 4 25-02-2003 13:34
pic: Bobcat CAD view CD47-Bot Robot Showcase 2 25-02-2003 11:26
