Go to Post Just a word of advise dont come running up to someone and say OMG OMG its just remember to introduce yourself first. - Mike Schroeder [more]
Unread 24-06-2005, 00:23
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Lawnmower Engine Starting Tips??
Today I picked up an old lawnmower (looks like the push type but has an engine) with a 3HP Briggs and Stratton Horizontal engine for free (score!) And it runs too, well, sort of. I had it running pretty good, I got it to rev really well (really high and smooth, punchy on the throttle too) but it would die when I let it idle for more than a few seconds. I knew it wasn't the idle stop because it was already idling pretty high. So I tried adjusting the mixture needle and then it wouldn't start so I tried putting it back and it still wouldn't start and now it is probably way out of adjustment.
I must have tried pulling the starter 100 times with different combinations of needle setting and choke and the only thing that could get it started was a little gas right into the carb.
Most of the times I had the engine running, it seemed like it wanted probably like 3/4 choke to keep it running well.
Anyway, now I really can't get it started at all and I'm not sure what choke and needle I need. I filled it with oil because it was pretty low.
The gas and spark plug are probably old, but as stated it was running okay (until I fiddled with it of course). I will try changing the spark plug (if it isn't seized in there) but I don't really have anywhere to put the old gas so I guess I can just put some new gas in to mix with it.
Anyway, does anyone have any tips to get this thing started easily and running like a champ? I'm afraid all pull out my arm if I pull that starter any more. I looked but I couldn't find any manual or starting procedures or needle setting or anything online.
Eventually, I want to do something cool with it like make a generator or a gokart (the mower already goes really fast as it is) or something of the sort.
Unread 24-06-2005, 00:33
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Re: Lawnmower Engine Starting Tips??
I don't have any tips, but did you possibly flood the engine? I would let it sit overnight and try again tomorrow.
Purdue Alumni
Cummins, Inc.
Unread 24-06-2005, 01:19
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Carb is first place I would check for blockage.
NO need to go crazy, just spray in some carb cleaner into it following the directions on the can.
About 5 bucks for a can or less.
Next I would check the muffler, or exhaust port. I had a snowblower that just would always stall out when I went up hills, and it was basically the way the little muffler was designed, that it had too much backpressure stuck in the muffler when It was in that position.
Try taking the muffler off completely.
Unread 24-06-2005, 01:33
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Sounds like you have a dirty carb. If you can take off the carp, just clean it up, put it back on. Wonders can be done by cleaning carbs... Using a carb cleaner will help, but if the clog is in the fuel lines in the carb (sometimes happens) it won't help too much. Just take it off and check it out.
Another thing that prolly isnt the main cause but will help: check out the air filter. If you flip a lawnmower over, it usually leaks oil out the air filter and cloggs it, depending on the design. If it is dirty, just leave it off and try to run it, make sure your not anywhere where it can suck up leaves or anything.
Hope that helps.
Unread 24-06-2005, 01:36
This was without the air filter.
Can WD-40 or Gunk Engine Bright be used to clean the carb or do I need a real carb cleaner?
Also, do you think I should replace the spark plug or do you think it is okay?
Unread 24-06-2005, 03:49
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
I would probably change the spark plug, chances are it is corroded if it has been sitting long.
Go all out and get can of carb cleaner, spray some WD40 in the carb first and see if that will get it running again.
Also did you check the spark plug wire/connectors for corrosion?
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 24-06-2005, 04:45
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
You should get real carb cleaner -- if the engine is sort of starting but sputters to death, try using some cold engine start/power start spray, the directions are on the bottle, but basically you'd spray it in the intake and it primes the air with fuel. You should be able to pick this up at any auto-supply store.
As for the spark plug, take it off and see what it looks like -- if its chipped and cracked then I'd change it. Also if its some funny color, please do tell us.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 24-06-2005, 05:50
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Sanddrag,
I agree with what others said about the carb problems. Get actual carb cleaner since it's designed to loosen up and remove any varnish or build up in the carb. If this has sat for some time then it's very possible that the carb is gummed up inside. Becareful of spraying other stuff in there as it may "eat" the gaskets. You have to have both the idle and choke adjusted properly for it to run. Even though you don't have any manuals for the mower try Googling the mower's make and model, and also the Briggs and Stratton's and see if you can find any info on them. Since you removed the air cleaner you know that lack of air isn't an issue, but if the choke is out of adjustment you may have too much air coming in and this can cause starting and idling problems by messing up the fuel/air mixture. At worst case if you can't find any info on adjusting the idle and choke then set everything in the center and work from there so you atleast have a point of reference.
Taking out and looking at the sparkplug may reveal flooding if it's wet after trying to start the mower. A good clean sparkplug will definitely help it start quicker and run better. If you can find any info on the motor then also see if it has the correct sparkplug installed and that it's gapped correctly as both can also cause problems. Since it has older gas in it putting in fresh gas and checking the fuel filter (if equipped) is also something you want to do before trying to start again.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 24-06-2005, 07:17
DUCKIE's Avatar
DUCKIE DUCKIE is offline
Duckie THE Duct Tape Enthusiast
AKA: Andrea Tribo
FRC #0365 (Miracle Workerz)
DUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant future
Send a message via AIM to DUCKIE
If the other suggestions don't work...You could try what one of my older brothers did when he was 9.
My mom went out to find him and he had completely taken apart and cleaned each piece of my dad's lawnboy lawmower... and had the pieced lined up all across the garage floor. Somehow he managed to get it back together correctly before my dad got home, and it ended up running better than it did when they bought it. It still runs great even though it's +25 years old.
We can lick gravity, but sometimes the paperwork is overwhelming. - Werner von Braun
Unread 24-06-2005, 08:28
Sandrag,
Common Briggs problems start at the carb fuel interface. If yours is one of the carb on top of the fuel tank, check for leakage in the rubber gasket or a blocked relief valve in the fuel tank gasket. Most small engine places will sell you a carb kit for a few bucks that replaces all the usual suspects. A clean spark plug is essential and I wouldn't overlook the choke operation. If it starts fine after sitting but cuts out when warm, suspect the choke. If it runs high at idle suspect a really rich mixture caused by one of the leaks from worn parts mentioned above.
Unread 24-06-2005, 12:34
you might be able to find a service manual for the engine at your local (main branch) library
it would tell you how to re-set the needle valves - if not screw the one you were messing with all the way in (gently) then back it out 1 full turn and try to start it. if it wont fire crank it out another 1/4 turn and keep doing this till it starts
usually these engines will hunt (speed up and slow down) if the needle is screwed in too far, and will bog down and then quit if its screwed out too far (too much fuel)
definately check the plug - if the motor was running rich its probabally fouled out (covered with carbon and shorting itself).
Unread 24-06-2005, 13:44
Thanks for all the tips. I'll give them a try. It is the type of briggs with the carb above the gas tank.
If I buy a new Briggs lawnmower spark plug, will it come already gapped or will I have to do that?
Unread 24-06-2005, 13:52
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Well by the sound of it its pretty old mower. So it probably is a compound problem. So you may want to try cleaning up more than just the carb, it probably has years of dirt accumulated in way too many areas. If that doesn't fix it, at least you'll have a cleaner and more efficient engine when your done. Also did you empty all of the oil out?
Unread 24-06-2005, 18:03
AKA: Jason Hartmann
Most likely you will get a Champion or a competitor to Champion since Briggs doesn't make thier own spark plugs that I know of.
Some plugs do come pregapped but I would still check it. You never know if it got knocked around in shipping or what not but there's a possibility that the gap could've closed up or that it was never set correctly to begin with. You can get a good feeler gauge for under $10 and it's worth it.
If the gap is closed more than it should be the motor will still run but you won't have as much power. It will start up and run but it won't be making as much power and torque as it could, and at worst case, as soon as you start putting it under load it will stall out. It would be like trying to compete in a match with your robot while it has a half dead battery.
Of course if the gap is totally closed the engine will never start or run because there won't be any spark to ignite the compressed mixture. Same is true if it's too wide, since the spark won't be able to jump the wider gap.
Unread 24-06-2005, 23:46
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
[quote=sanddrag]
as probably mentioned in other posts don't mix old gas with new gas just in case theres water in the old gas from built up moisture. make sure you buy the correct sparkplug, change the oil and air filter if any.
Like i said someone probably already posted this but i know that once you do a regular tuneup it should work fine and like others have also mentioned maybe you flooded it and should just let it sit
the spark plug will come already gapped just make sure you bring the old one to a sears store they have a seperate section for lawnmower supplies and might even have a repair shop just for mowers i know the one out by me repairs mowers and has many parts for them =) good luck
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Weedwhacker Engine Project sanddrag Technical Discussion 9 25-02-2005 23:58
Travel Tips KathieK General Forum 5 13-12-2004 12:47
post your Chairman's Award tips Ryan Foley Chairman's Award 3 31-08-2003 22:54
I need tips on Starting a New Team. Rook Starting New Teams 6 25-03-2003 11:19
advice on starting a team.. archiver 2001 1 24-06-2002 03:20
