Go to Post The robot uprising has begun. - SpoonMechanic [more]
Unread 25-06-2005, 17:00
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
Question About 4-Wheel Drive
I'm doing some robot designing in my free time over the summer, and I came to a question.
I'm making a 4-wheel drive chassis using the Kit transmission. To do this you can do it with two sprockets on the output of the gearbox, as seen in the attached picture.
Now to make a very reliable drivetrain with this, I think the wheel's sprocket should be aligned with its corresponding sprocket on the output shaft of the gearbox. Doing this would need me to stagger the wheels one way or the other.
The question is:
Which way is most beneficial to stagger them?
Front wheels inward and rear wheels outward or visa versa?
Does it even make a difference?
Name:	4-wheel Tranny.jpg
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
Unread 25-06-2005, 17:08
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Question About 4-Wheel Drive
Why not just put the sprocket on the other side of the wheel and keep the wheels pretty close to being inline? So you have two wheels with the sprocket outside and two with the sprocket inside.
Unread 25-06-2005, 17:31
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Not the kit-transmission, but this photo illustrates Sanddrag's point pretty well.
http://www.firstrobotics.uwaterloo.c...etrains111.jpg
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 25-06-2005, 17:50
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
You don't want your wheels to not be inline. Go with what Sanddrag said, or get two separate sprockets so that you can slide them on the output shaft to align them with the wheels, instead of being stuck with the double sprocket you've pictured.
2001-2004: Team 100
2006-Present: Team 254
Unread 25-06-2005, 17:58
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
What's shown in that illustration is not a 'double-sprocket', but two 21 tooth sprockets placed back to back. This arrangement was suggested for the 2005 Kitbot as an easy way of implementing four-wheel drive, but results in the wheels at one end being offset from those at the other. The picture Karthik linked to is effectively the same thing. The offset will vary with the length through bore of each sprocket.
The difficulty in customizing the spacing of chain on the provided transmissions comes simply from the limited length of the custom-made output shaft. The arrangement shown in the first illustration will probably do the best at getting the wheels as close to flush with one another as is possible without facing off some of one sprocket.
I don't think you'll see much benefit in placing one set of wheels closer together over an another, as we probably spend equal amounts of time going in each direction throughout the course of a match.
--Madison--
...down at the Ozdust!
Unread 25-06-2005, 19:18
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
That is exactly how 1147 did their drive train this year. Attached is a shot I just took of it to illustrate that the wheels are in alignment and the drive chains are straight.
Unread 25-06-2005, 20:02
Cory's Avatar
AKA: Cory McBride
Oops. That's what you get for looking at it without opening it
you could also use spacers between the wheel and sprocket to get them in line, if removing material off the hub isn't an option.
2001-2004: Team 100
Unread 25-06-2005, 20:19
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Wow! You mean the sprocket spacing on the output shaft is such that when a drive is configured like yours... the wheels are already in-line???
You'd think it was designed that way...
Unread 25-06-2005, 20:40
billbo911's Avatar
Funny how things turn out when they are designed well, and then used as designed!
Unread 25-06-2005, 22:04
Gdeaver Gdeaver is offline
FRC #1640
Don't forget to implement some type of chain adjustment or tensioning in your design. This year for time and simplicity we didn't do this and had one of the longer chains stretch allot. There was never time between matches to deal with it. We where lucky it didn't get bad enough to derail. Next year we will deal with it. A commercial chain tensioner isn't cheap. However it's not too hard to make your own.
Unread 25-06-2005, 22:59
Meyerman Meyerman is offline
Meyers #37, Pink Petunia's!
AKA: Meyers
FRC #0056 (RoBBE Xtreme)
Meyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to behold
Send a message via AIM to Meyerman Send a message via Yahoo to Meyerman
we made a longer output shaft thingy for out kit tranny if u can u should try that out and have fun!
Unread 26-06-2005, 10:04
FiM Volunteer
Thanks for all the input guys! I'm taking from this that inline is the best way to do things. However, this again poses a slight problem to me.
I should have mentioned that I won't be using those narrow wheels from the kit too. I'm going to be using something closer to 8" diameter, 2" wide pneumatic wheels. That is why I was having a rough time working with the two 21 tooth sprockets on the output shaft of the kit tranny. Their spacing doesn't quite allow for such a simple solution.
I suppose that the best way to solve this problem may be a simple use of spacing on the wheel shafts, leaving the sprockets at different positions on the shafts, but the wheels inline. I'll probably use keyed wheel shafts to make things a little easier.
Unread 26-06-2005, 11:15
Quatitos Quatitos is offline
lysdexic taquitos
AKA: Bill
FRC #0279 (Tech Fusion)
Quatitos has a spectacular aura aboutQuatitos has a spectacular aura about
Send a message via AIM to Quatitos
You could always just use one sprocket on the output shaft of the transmission and then send that directly to one of your wheels. On this wheel you would place another sprocket on the opposite side of the wheel from the chain coming from the tranny. If you ran a chain between the two wheels like that they would end up being inline. The only bad thing is you use more chain this way.
Now if your comfortable with using smaller chain, which I know some people would yell at you never to use smaller chain in the drivetrain, but we succesfully use the set up I just described on our robot this year without a single problem.
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 GLR Champs
2001 National Champs
Unread 26-06-2005, 11:30
FiM Volunteer
My current design only left 6 inches in between the gearboxes. Whoops.
If I use only one CIM in each Kit tranny, would a set up as pictured in the attachment cause any problems?
I'm limited in the dimensions of the chassis to very close to what it currently is.
22" wide, 24" long. So I can't make it wide enough to fit two CIMs in each tranny.
Unread 26-06-2005, 11:56
billbo911's Avatar
In the picture of our bot, even though you can't see it, there is only one CIM per side. We were going to run two per side, then we did some rough calculations and decided 2 HP to run the bot was overkill. Running one per side was just fine. We never drained a battery in competition and had plenty of speed and power.
Globe gear box Pat Roche Motors 9 25-05-2004 22:50
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Clamping wheel hubs sanddrag Technical Discussion 7 29-02-2004 00:20
XP Hard Drive Space Question Raven_Writer Chit-Chat 13 07-08-2003 16:38
