Go to Post To offer an opinion is fine, to demand that others adhere to your opinion is laughable. - JVN [more]
Unread 26-06-2005, 12:52
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
Re: Question About 4-Wheel Drive
FYI: This isn't a competition robot design, it's going to be off-roading and other fun things.
I think that one CIM per side will still be enough if it was good in competition.
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
Unread 26-06-2005, 15:27
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Originally Posted by Quatitos
You could always just use one sprocket on the output shaft of the transmission and then send that directly to one of your wheels. On this wheel you would place another sprocket on the opposite side of the wheel from the chain coming from the tranny. If you ran a chain between the two wheels like that they would end up being inline. The only bad thing is you use more chain this way.
Another downside is that if you somehow manage to derail the chain from the output sprocket, you've lost power to all wheels, instead of just one.
2001-2004: Team 100
2006-Present: Team 254
Unread 26-06-2005, 16:19
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Not necessarily, for the last two years we have taken #35 chain from the transmissions to the back drive wheels and then from #25 chain to connect the front and back wheels.
We have only had a few problems with the #25 chain for example last year while climbing up the steps at an angle we snapped the #25 chain on one side, but we still made it up the step with 3 wheel drive!
Just make sure that the chain connection from the transmission to the back wheel is properly tensioned and correctly aligned. You should not have a problem if you do that right.
I have included a picture of this years drive-train, it is not the clearest picture, but it will do.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 26-06-2005, 23:26
Quatitos Quatitos is offline
lysdexic taquitos
AKA: Bill
FRC #0279 (Tech Fusion)
Quatitos has a spectacular aura aboutQuatitos has a spectacular aura about
Send a message via AIM to Quatitos
We never had a single problem with this chain set up at all this year, but just in case, tension was checked before each match and we color coded all the master links for very quick access in case of emergency. Attached are pictures of the front and back wheels. Ignore the little bit of damage to the back wheel, that post next to it took a very big hit. Can you say two robots accidentally backed up full speed into each other? And just for clarification, the back wheel is the smaller wheel.
ID:	3489  Click image for larger version
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 GLR Champs
2001 National Champs
Unread 26-06-2005, 23:38
Lisa Perez's Avatar
Lisa Perez Lisa Perez is offline
FRC #0573 (Mech Warriors)
Lisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond repute
If by any chance you choose to get rid of the second driver sprocket, you can still power both wheels on the one side by setting up the tensioners and/or idlers in just the right spots. We used the idler sprockets this year and had no problems whatsoever with our drive train.
Since you're concerned about space constraints, this method saves a few inches width-wise because the wheel sprockets are on the same side and there is only one driver sprocket.
Event Coordinator - Center Line District Event
Volunteer Coordinator - Michigan State Championship
Lead Mentor - Team 573, Mech Warriors
Former Mentor - Team 830, Rat Pack and Team 3182, Athena's Warriors
Proud Alumna - Team 573, Mech Warriors and Team 1, Juggernauts
Globe gear box Pat Roche Motors 9 25-05-2004 22:50
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Clamping wheel hubs sanddrag Technical Discussion 7 29-02-2004 00:20
XP Hard Drive Space Question Raven_Writer Chit-Chat 13 07-08-2003 16:38
