Go to Post I predict someone has to eat a hat! :D - FiMFanatic [more]
Unread 26-06-2005, 19:48
Best Available Data
FRC #1778 (Chill Out!)
Video Cameras
Disclaimer: I searched and found nothing...
I'm looking into buying a video camera for next year to make a video of the full FIRST season and my local Lego League tournament (that I'm now too old for ) Anyways, I'm looking for a camera for under 350 dollars and preferably closer to 300. Right now I'm looking at this! camera. It has a 24x zoom that I figured would help get close up shots from afar. Any advice/what do you use as a video camera?
Unread 26-06-2005, 22:13
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Re: Video Cameras
That seems to be a pretty good camcorder for the price. Try Buydig.com to see if you can get a better price.
One thing about a MiniDV camcorder that is annoying is the media that is uses. Different tape manufactures uses different lubricants in their tapes, and some camcorders heads do not write well to some media. It is best to check reviews to see if the heads are sensitive to one particular type of tape or not.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 26-06-2005, 22:35
Bharat Nain's Avatar
Re: Video Cameras
Yup, he said it absolutely right. If you do go looking around for other cameras
Look at optical zoom, not digital. Try to fit a tripod in the deal - it's worth it.
Study user reviews carefully and beware that all are not true.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 26-06-2005, 22:39
JonBell JonBell is offline
None #0546 (Technotics)
JonBell is just really niceJonBell is just really niceJonBell is just really niceJonBell is just really niceJonBell is just really nice
Send a message via AIM to JonBell
Re: Video Cameras
What about battery life?
Seems to me like it should be a key factor (Or at least, availability of very long life batteries)
Unread 26-06-2005, 23:31
GET IT ON!!
Re: Video Cameras
Most camcorders have removable batteries, and a lot of the manufactures only give the consumer a starter battery.
Here are a couple of key factors, in my opinion, when purchasing a camcorder is:
1. The CCD. If a camcorder has tri-CCD you will get much better color then you would with just a mono-CCD. Also look at the size of the CCD's, bigger ones can give you more resolution.
2. The Optical Zoom, the bigger the better. Digital Zoom is absolutely nothing, and if you have to magnify something beyond the optical zoom, a piece of editing software will probably give you better results.
3. Analog Video IN port, and External Mike. These might be insignificant to the casual user, but they come in very handy. If you have some old analog tapes, you can convert them using a Video IN. An external mike is also good because the onboard microphones usually pick-up the noise of the heads while they are writing to the tape. In the case of a robotics completion, it is not much of an issue, because the sound around you is much louder then the DV heads writing.
4. Like I stated above try to see if they are sensitive to one type of tape or not. I have found that some people who bought cheap camcorders only to find out that they have to buy expensive tapes to get the best quality. Also when you make your purchase, make sure that you buy a cleaner tape that the manufacture recommends.
5. Also check out what type of light requirements the camcorder needs. Some camcorders function very well in low light conditions, while others are very bad at it.
6. Just a note, If you are thinking of buying a camcorder to act like a camera, you will be seriously disappointed. Even though they are getting better, they will only be marginally better than camera phone in terms of quality
Rhode Warriors
Unread 27-06-2005, 01:11
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: Video Cameras
Also a big thing to watch is the type of tape or media the camcorder takes. And also watch for availability in your area and cost. You might get one camera really cheap but the tapes cost a fortune and viceaversa.
-Mike
Unread 27-06-2005, 02:32
D.J. Fluck
Posts: n/a
Re: Video Cameras
I have the exact model of that camera from 2003 and that series has been pretty reliable in general. The compact size is great for me, since I don't have a very steady hand. The only downfall is that it doesn't shoot well in low light situations. The back light and light is alright, but if you are in a somewhat dark room, it is kinda hard to see. If that is going to be a problem for you, I'd recommend a Sony. Their "Night Shot" is an excellent feature for shooting at night or in low light situations.
If you are going to be digitizing footage, stick with a digital camcorder like that with the Mini-DV tapes.
Unread 27-06-2005, 12:11
Enterprize's Avatar
Enterprize Enterprize is offline
Ubergeek
AKA: Joshua
#0269 (Cooney Robotics)
Enterprize has a spectacular aura aboutEnterprize has a spectacular aura aboutEnterprize has a spectacular aura about
Send a message via AIM to Enterprize
Re: Video Cameras
They have excellent reviews over at Camcorder info.com. Definately worth checking out the reviews before you go out and buy something ^^
I have [a buncha] gmail invites, if you want one PM/Email me ^^
Eat donuts - Save the Planet. Do your Civic Duty.
Help: Need VHS tape or DVD of "TriplePlay" video dhitchco Rules/Strategy 4 07-04-2005 18:26
Video: Cyber Blue 234 Late Night Programming Video JAH Robot Showcase 6 13-03-2005 00:34
ANDY BAKER SURVIVOR VIDEO - DONE D.J. Fluck General Forum 69 25-10-2004 16:48
GizMOE Revealed - NEW VIDEO from team 365!! SuperJake Robot Showcase 14 25-03-2004 22:35
Good video footage miketwalker General Forum 0 28-03-2002 17:14
