#16
Re: Question About 4-Wheel Drive
FYI: This isn't a competition robot design, it's going to be off-roading and other fun things.
![]() I think that one CIM per side will still be enough if it was good in competition. |
#17
We have only had a few problems with the #25 chain for example last year while climbing up the steps at an angle we snapped the #25 chain on one side, but we still made it up the step with 3 wheel drive! Just make sure that the chain connection from the transmission to the back wheel is properly tensioned and correctly aligned. You should not have a problem if you do that right. I have included a picture of this years drive-train, it is not the clearest picture, but it will do. Last edited by team222badbrad : 26-06-2005 at 16:23. |
#19
#20
If by any chance you choose to get rid of the second driver sprocket, you can still power both wheels on the one side by setting up the tensioners and/or idlers in just the right spots. We used the idler sprockets this year and had no problems whatsoever with our drive train.
Since you're concerned about space constraints, this method saves a few inches width-wise because the wheel sprockets are on the same side and there is only one driver sprocket. Last edited by Lisa Perez : 26-06-2005 at 23:54. |
| Globe gear box | Pat Roche | Motors | 9 | 25-05-2004 22:50 |
| Four Wheel, all steering, non-omniwheel, ONE power/motor source drive | FizMan | Technical Discussion | 31 | 27-04-2004 12:12 |
| Clamping wheel hubs | sanddrag | Technical Discussion | 7 | 29-02-2004 00:20 |
| XP Hard Drive Space Question | Raven_Writer | Chit-Chat | 13 | 07-08-2003 16:38 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
