Go to Post Sure, it's just a robotics competition, but some of us actually care about the robots... - Karthik [more]
Unread 27-06-2005, 11:19
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: pic: 3 speed concept - 1st gear
57 uses a tranny like this but with just 2 gears.
You could make it smaller if you went with a rather counter intuitive shifting pattern. Call 1 the biggest gear on your shifter. If you arrange the gears on the shifter as 2-1-3 instead of 3-2-1 then you could have all 3 gears next to each other. Then your whole assembly would just need to be 7 times the width of a gear plus some tolerances. Downside of course is that you'd have to go through your high gear to get between your two low gears. Or low between two highs depending on which side of that is driving. Either way it's bad news if you're planning on using it like an automatic transmission in a car.
Also, beveling both meshing gears actually doesn't help a bit. Beveling just one helps a little. Actually rounding or beveling the sides of each tooth helps the most and hurts your tooth face width the least. Of course it requires a good hand with a dremel and a lot of patience.
Shifting wise, we use a brass bushing with a shaft press fit inside of it that's threaded on one end and attaches to a pneumatic. The two gears are welded together and free spinning on the shaft on some needle bearings. I can post a section view if that's incredibly confusing.
Unread 27-06-2005, 11:37
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Lots of teams use a tranny like this with only two gears. That's where I got the idea. But my idea was to expand it to make it a 3 speed.
As for beveling the teeth, why would you dremel each one as opposed to chucking it up in a lathe and filing it or even making a light cut?
Unread 27-06-2005, 12:11
dubious elise's Avatar
dubious elise dubious elise is offline
Gone to school, back in 2016
FRC #0269 (Cooney Robotics); FLL #1855 (Cooney Tech/St. Jerome)
dubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond repute
I think it will be more powerful than the three-speed in my car...
"We can't guarantee success...but we can do something better, we can deserve it." ~John Adams
"The harder you work, the luckier you are." ~Gerald Ford
Notre Dame '10
Unread 27-06-2005, 17:04
Given the way we build gearboxes you might be correct. but not really, I think if a first robot used all the motors combined you'd still be under 5HP.
I'd have to make a drawing to show you what I'm talking about, I think. Lathing the gear would get you something looking exactly like if you'd done the same thing with a rod or other cylinder. I'm talking about beveling each individual edge of each tooth.
The point of this is to reduce the cross-section that has to mesh.
I know exactly what you mean now. That's probably not a bad idea. I've seen a lot of meshing transmissions out there and they all seem to work okay. I wonder what teams like 254 or 60 do to their gearboxes to make them shift well. I've been looking at this one I wonder if they added c-c distance or beveled the gears or just left them.
I like mesh shifters because they are easier to construct, but what I don't like is that in every single one I've seen there are metal shavings inside it like this. The gears themselves have always looked fine, but metal shavings in gearboxes make me uncomfortable.
Anyway, I thought about a dog shifting 3 speed, but determined that there is not good way to do it, where there is a pretty good way with mesh shifting.
Unread 27-06-2005, 18:13
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Of course you're going to have metal shavings in there--you're smashing two metal objects together at high speeds, which is going to wear down the teeth and leave shavings in there.
They seem to run pretty well, regardless of what is or isn't in em, so it doesn't seem like a real issue
2001-2004: Team 100
2006-Present: Team 254
Unread 29-06-2005, 01:20
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
I have always wonder about this kind of shifting, how long can a gear box like this last?
I had this idea a while ago but I didn't think it would work because of the gears hiting when shifting. What do you all think about using brass for one of the gears that meshes and steel for the other one. I think since brass is a softer metal it would start to take the shape needed to shift properly.
I know there was a team that use this method and had four speeds, i think it was team 33 but im not sure? someone please correct me if wrong.
Dave
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 29-06-2005, 01:29
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Dave
When you build a robot for FIRST you really want the gearbox to last the season. There has been mesh gearbox made before and used in FIRST which lasted longer.
The best way to do this is by beveling the gear teeth edges so it would mesh properly. Personally I would 20 dp gears. If you do use brass, I fear that the teeth will sheer off.
Yes it was team 33 who has done the 4 speed back in 2004 and they used mesh shifting. It was very cool. Team 195 also used something like 33's 2004 tranmission this past season.
Unread 29-06-2005, 02:06
Cory's Avatar
AKA: Cory McBride
Dave
Teams have been using this style of shifting for quite some time, and overall, when constructed properly, it seems to be extremely reliable. I suppose if you shift a whole lot, you may need to have extras of the meshing gears on hand, incase you happen to shear a tooth, or completely wear them down, but considering that a team who attends 4 events (2 regionals, nats, an offseason. Yes I know many teams go to more than this), with an average of 10 rounds per event, that's only 80 minutes of drive time, which should be well within the lifespan of most things built for FIRST.
2001-2004: Team 100
Unread 29-06-2005, 03:04
I would agree. It's like one of those things that shouldn't work but does. I will note that as SVR I know 254 was having a good bit of trouble with it (I think it was Friday evening), but I don't know what it was caused by. So it wouldn't be fair to say mesh shifters are inherently troublesome. I don't think the design is nearly as robust as a constant mesh dog shifter, but there is no evidence to suggest that a mesh shifter is not robust enough for it's use. I don't like how mesh shifters work, but you can't deny the fact that they do work, and seemingly pretty well.
I have a couple questions. Do mesh shifters prefer to be shifted under speed and load? I know the dog shifters just love it, but I'm thinking the mesh shifters might like a slower easier shift.
Can someone who has driven one enlighten us?
Unread 29-06-2005, 17:30
Bill Gold Bill Gold is offline
Retired -- 2006
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
In our 2005 drive transmissions we added a little in the center-to-center distance (off the top of my head I think it was 0.0015", but I can check on that if you'd want) and chamfered the shifting gears.
Also, we didn't care how fast we were running the transmissions when we shifted. Our problems on Friday at SVR weren't related to the gears themselves. There were minor problems within the transmission related to snap-rings. We had no other mechanical issues after fixing that problem (which originated in Sacramento) for the rest of the season.
Unread 27-06-2005, 12:51
The point of this is to reduce the cross-section that has to mesh. If you bevel both gears, then it's pretty must the exact same cross section that has to mesh and line up. If you bevel each edge like I'm talking about, then initially it's like meshing two gears with much smaller teeth with lots of space between them.
pic: 2 speed shifty on the fly Lego Bot CD47-Bot Robot Showcase 9 31-01-2005 04:21
pic: Need an EDU Beval Gear CD47-Bot Robot Showcase 8 30-10-2003 14:03
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
pic: 716 single speed CD47-Bot Extra Discussion 2 09-09-2003 15:51
