Re: pic: 3 speed concept - 1st gear
Of course you're going to have metal shavings in there--you're smashing two metal objects together at high speeds, which is going to wear down the teeth and leave shavings in there.
They seem to run pretty well, regardless of what is or isn't in em, so it doesn't seem like a real issue ![]() |
I have always wonder about this kind of shifting, how long can a gear box like this last?
I had this idea a while ago but I didn't think it would work because of the gears hiting when shifting. What do you all think about using brass for one of the gears that meshes and steel for the other one. I think since brass is a softer metal it would start to take the shape needed to shift properly. I know there was a team that use this method and had four speeds, i think it was team 33 but im not sure? someone please correct me if wrong. Dave |
The best way to do this is by beveling the gear teeth edges so it would mesh properly. Personally I would 20 dp gears. If you do use brass, I fear that the teeth will sheer off. Yes it was team 33 who has done the 4 speed back in 2004 and they used mesh shifting. It was very cool. Team 195 also used something like 33's 2004 tranmission this past season. |
I have a couple questions. Do mesh shifters prefer to be shifted under speed and load? I know the dog shifters just love it, but I'm thinking the mesh shifters might like a slower easier shift. Can someone who has driven one enlighten us? |
| pic: 2 speed shifty on the fly Lego Bot | CD47-Bot | Robot Showcase | 9 | 31-01-2005 04:21 |
| pic: Need an EDU Beval Gear | CD47-Bot | Robot Showcase | 8 | 30-10-2003 14:03 |
| pic: dual speed gearbox | CD47-Bot | Extra Discussion | 9 | 07-10-2003 15:04 |
| pic: 716 single speed | CD47-Bot | Extra Discussion | 2 | 09-09-2003 15:51 |
