Go to Post Dave Lavery, Lou Rosanio and Karthik are all Woodie Flowers winners this year. So mentors it seems like if ya want the WFA it might be a good idea to put on a kilt :) - Kyle [more]
Unread 27-06-2005, 22:50
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
new wheel design
(i dont know if i posted the image correctly or not but i hope it shows if not it looks like an X with omniwheels on each end connected by chain to an outer center shaft and an inner shaft connected directly to the X)
hey im looking for advice. it was one in the morning and this idea hit me and i had to draw it. the little wheels are omniwheels and are rotated by the outer shaft and are connected to the outer shaft by bike chain. this would hapen during normal movement giving the robot a smooth motion. when the inner shaft is rotated it rotates the whole assembly rotates allowing it to
overcome heavy obstacles like stairs with no sweat. the rotation betwean inner and outer shaft would be switched by a gearbox. this means one motor can control each assembly. my only real concern is weight. i would have to experiment with making as much as possible out of plastics. any comments or ideas. note this design would kick $@#$@#$@# on stairs and other rugged terrain.
Unread 27-06-2005, 22:54
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: new wheel design
A picture is worth a thousand words. Maybe you can post a link to it or upload it into the gallery? I'd really like to see, sounds interesting.
Unread 27-06-2005, 23:56
A team did something similar in I believe 2004. http://www.firstrobotics.uwaterloo.c...s/wheels09.jpg
Unread 28-06-2005, 00:13
yes that is very similar i guess the main difference is the omni directional wheels.
Unread 28-06-2005, 00:19
Would you plan to have four of these on a robot? How big would the overall diameter (or distance across X) be and what would be the diameter of the little wheels?
Also, instead of bicycle chain, consider using standard roller chain. Easier to get sprockets for.
Unread 28-06-2005, 00:52
first of all: im curious what team that was in the picture. second: keep in mind its just a concept so far so i guess the wheels would be 2" omni wheels and eack X if i do a X would be 8" or so in diameter. im still trying to figure out how to control the axles independently or how to handle the weight. the origonial reason i thought it up was becuase omniwheels are very small and i was trying to figure a way to overcome obstacles.
Unread 28-06-2005, 01:07
mgreenley
Posts: n/a
The team in the picture was 1218, Cha-Bots. If you haven't gotten a chance to see their robot, (www.SOAP108.com generally has, well, everything), it was amazing to see. Their implementation of the idea was par excellence.
Last edited by mgreenley : 28-06-2005 at 01:20. Reason: Adding a tad, and rectifying a grammatical error
Unread 28-06-2005, 11:14
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
and if my memory serves me right it twas spam in '04 who used the same omni directional type of drive and was in the top 5 at nats too.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 28-06-2005, 13:08
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
SPAM used a holonomic drive in 2004, along with 1083, but it was nothing like 1218's tri wheels.
2001-2004: Team 100
2006-Present: Team 254
Unread 28-06-2005, 14:25
any advice on how to make the outer wheels and the whole thing move seperately i was thinking a gear box of some kind similar to the type that would change speed.
Unread 28-06-2005, 14:31
FRC #1405
what i saw on the pic was the 4 wheels at 45 deg. am i seeing that correctly?
Unread 28-06-2005, 14:41
yes four wheels at 90 degrees and each one would rotate independently for going over normal surfaces and then the entire thing rotates for going over rough terrian like stairs.
Unread 28-06-2005, 14:42
each seperate wheel would be an omni wheel and so the whole assembly would act as an omni wheel too.
Unread 28-06-2005, 14:48
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
The leftmost picture is an elevation, not a plan view.
--Madison--
...down at the Ozdust!
Unread 28-06-2005, 15:05
i dont know if this will clear anything up or not but here is an updated picture (just a little clarification) like i said im not sure how to switch (the mechanism not the actual rotation) between small wheels and large wheel
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
Collaborative Robot Design Project coreyjon General Forum 11 10-03-2005 16:00
pic: Team 60 Wheel Design CD47-Bot Extra Discussion 6 18-11-2004 19:57
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
