#16
Re: Alternate Controller
oops, sorry, dude. i meant a picture of the 'scope screen, though i guess if the signal's changing too fast that might not be possible. but it seems like it should be possible with a reasonably fast shutter speed. say 1/1000 sec, if your camera has a manual or shutter priority setting.
ah, lunch time's over. must get back to the grind... |
#17
No guarantees, but i'd guess this guy is describing what comes out of the r/c unit. He also describes a pic based circuit to generate the signal under the control of a pc. Unless you're dead set against programming the vex, though, i'd still say use the serial port.
| Speed controllers won't communicate w/robot controller | steven114 | Control System | 12 | 03-02-2005 21:26 |
| Program error after controller reset | randomperson | Programming | 6 | 04-01-2005 23:31 |
| not quite sure...speed controller...spike. | tophq | Programming | 8 | 26-03-2004 13:43 |
| Help On Coding 2K1 Controller | GregTheGreat | Programming | 9 | 05-12-2003 18:35 |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 19-03-2003 13:30 |
