Go to Post mabye this is a case of I AM JVN to the Extreme! - Tytus Gerrish [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 27-06-2005, 22:53
robot180's Avatar
robot180 robot180 is offline
Webmaster, spamrobotics.com
AKA: Jon
FRC #0180 (S.P.A.M.)
robot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to all
Send a message via AIM to robot180
Re: Web Design Tools?
(This is a real tip!)
If you think that validating your code is time consuming, try the Firefox web designers toolbar plugin. It has a lot of very useful features for web designers. One menu allows you to easily validate your html, css, WAI standards, and a few others. I use it all the time. All you have to do is click the menu, click the type of validation, and it pops up in a new tab, or new window if you want.
I think everyone should validate code, especially when it is that easy. I suggest validating it constantly while coding for two reasons. The first is that if you wait until you are done and find out that there are tons of mistakes, you may give up fixing them. The second is that I found that after making a few websites while constantly validating them, you start to write more valid code by default. Now, I can write code and never get errors.
The only problem I run into is when I copy and paste text to post on the site and it has appostraphies in it ('). That produces an error in the html validation. I always have to go back and fix that.
-Jon
Computer Science Major
Georgia Tech
Former Team Leader
FRC Team 180
Unread 28-06-2005, 13:21
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
To people that are having the same problem, use this table as reference.
Another reference: CSS Properties to JavaScript references
http://www.mikesorrenti.com/
Unread 28-06-2005, 13:42
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Originally Posted by Mike
Hey! Now that's useful... now I just have to learn JS.
Unread 28-06-2005, 17:35
robot180's Avatar
AKA: Jon
I thought about that problem that I just mentioned. Does anyone have an idea of how I could have the php convert any apostraphies into the code for an apostraphy? The text is inputed directly into the code and uploaded using ftp. Is there a way that when a page is downloaded, the php could first check for html entities and convert them into the code for the entity?
-Jon
Georgia Tech
Former Team Leader
FRC Team 180
Unread 28-06-2005, 17:55
Programming User
I'm not sure exactly how you want it applied, but htmlspecialchars might help you.
Unread 28-06-2005, 20:21
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I would also like to suggest the idea of a CMS. It is an easy way to quickly make a very good looking and well organized site. I too would not recommend PHP-Nuke but Mambo and also e107 look really good. You can check them all out and do a demo of the admin interface too at http://www.opensourcecms.com/
If you are looking to do some coding/customizing but don't want to make a whole site, you can go with a CMS and then make your own plugins, themes, images, etc for it.
Unread 29-06-2005, 02:22
Mike's Avatar
AKA: Mike Sorrenti
In addition, if you want the text to be executed as HTML when you view it, check out htmlspecialchars_decode Only works in PHP5.
Unread 29-06-2005, 13:19
robot180's Avatar
AKA: Jon
Ok. I will use the htmlentities function instead. Thanks for pointing that out. What I will do is write a program where I can paste text into a box and hit a button that converts everything. Then, I will copy and paste it again into the code. It is an extra step, but it is easier then going through hundreds of lines of text to find them. lol (I'm lazy)
-Jon
Georgia Tech
Former Team Leader
FRC Team 180
Unread 29-06-2005, 13:26
roboticsguy1988's Avatar
roboticsguy1988 roboticsguy1988 is offline
Larry Johnston
AKA: Larry Boy
FRC #1501 (Team THRUST)
Team Role: Electrical
roboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud of
Send a message via ICQ to roboticsguy1988 Send a message via AIM to roboticsguy1988 Send a message via MSN to roboticsguy1988 Send a message via Yahoo to roboticsguy1988
Eh, we all our lazy at some point. Like me, instead of making a whole website purely out of code, i use a CMS, << now thats lazy, even though i modify the code a lot.
Larry Johnston, Team THRUST, Team #1501, Team THRUST webpage
2005 IRI - Imagery and Design Award
2005 - 2006 BMR - Professional Grade Award
2006 BMR - Delphi Driving Tomorrow's Technology Award
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~ RogerR
~Da team that uses all tha rivets, Team #1501~
The FIRST Software Repository ~ Chief Admin
openFIRST ~ Project Supporter (Former editor)
DMOZ.org - FIRST - US Teams Section ~ Chief Editor
Favorite web design forums? Ryan M. Website Design/Showcase 9 07-06-2005 18:28
Design Sharing Rod General Forum 32 14-01-2004 22:00
a web design trivia question robot180 Website Design/Showcase 5 17-10-2003 19:46
FREE web design, php, and 3ds max classes Jeremy_Mc General Forum 0 31-01-2003 15:42
