Go to Post I read every darn page of this thread. - Paul Copioli [more]
  #31   Spotlight this post!
Unread 28-06-2005, 22:14
Hunter's Avatar
Hunter Hunter is offline
Wood is Good
AKA: Todd Willick
FRC #5184 (Titanics)
Hunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond repute
Re: Cool new ideas for FIRST Robots - who has them?
Originally Posted by mechanicalbrain
i got to get a picture because i know you people will love it. on our arm to extend it we used a simple cable and pulley system. the catch is that the cable was this special toothed cable (looks like a normal cable but with a second cable kind of spiraling up the length of it) that fit perfectly into toothed pulleys. the benefit you ask. absolutely no slippage so instead of a bulky pneumatic setup or motor rig we had this thin cable. it worked beautifully.
That sounds like synchromesh cable which is available from SDP-SI http://sdp-si.com
  #32   Spotlight this post!
Unread 28-06-2005, 23:08
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
yeah this is exactly what we used. it works like this.
  #33   Spotlight this post!
Unread 28-06-2005, 23:10
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Now that is some cool stuff. I had never seen it before. What keeps the black cord from unraveling and how much load can this stuff take? How is the black cord attached to the silver cord?
  #34   Spotlight this post!
Unread 28-06-2005, 23:18
the silver and black cord are bound together and coated with a clear plastic. they can hold alot of force but slack is REALLY bad its alot easier for the cord to come out of the pully then to put it back in. if their is no slack then your fine becuase its really a metal cable and really works smoothly with the pulley
  #35   Spotlight this post!
Unread 29-06-2005, 01:24
santosh's Avatar
santosh santosh is offline
AKA: 2415
FRC #2415
santosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond repute
Send a message via AIM to santosh
Originally Posted by sanddrag
Could you elaborate on that a little? Do you have a picture?
I don't have a picture. But this is how it worked. We built 4 drive modules that fit inside of our robot and could easily slide in and out of the fram of the bot.
The modules were all conected to a central point by hinging peices of metal together. There was one piston that ran up the center of out robot. When that piston expanded, it pushed on the central point causing the peices of metal to hinge outwards and expand the overall lenght of the 2 pieces connected to each other. Each module had its own 2 piece of metal that were hinged together that met up at a certain point. So when the piston pushed down, the drive module were pushe out of the fram of the bot.
Forgive me if the explanation is bad. I am too tired to think properly.
2004 - 2007 = 1002
2007 - 2011 = Founding Mentor of 2415
6 regional wins, 3 EIs, 3 Chairmans
kiddies kiddies kiddies
  #36   Spotlight this post!
Unread 29-06-2005, 01:41
i want to see what people did with electronics. we realized the control board and the power board were the exact same size and mounted them back to back. we also mounted neon tubes to the bottom of the bot and used a nylon mesh tubing that is used in PCs to bind our electrical..... oh yeah and used magnetic limit switches to determine the exact angle of our arm (im thinking of trying a potentiometer for next year but i think the magnets are more reliable).
  #37   Spotlight this post!
Unread 29-06-2005, 10:02
Erin Rapacki's Avatar
Erin Rapacki Erin Rapacki is offline
General Manager
Erin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond repute
Send a message via AIM to Erin Rapacki
Instead of "who has them" I should have said "post them"
I don't really care who has them, I just care about the ideas themselves.
LOL! remember my "soap box" thread about clear and concise titles?
http://www.linkedin.com/in/erapacki
BUZZ 175 (01, 02) - NUTRONS 125 (03, 04) - QUEEN 1975 (06)
Beantown Blitz Founder (04) - FIRST Robotics Conferences (04) - Boston Regional Volunteer Coordinator (06)
  #38   Spotlight this post!
Unread 03-07-2005, 19:08
CraigHickman
Posts: n/a
I personally have worked on this idea for a while- ever since I saw the 3 wheeled omni directional bot. I have been thinking, and I thought of a way to give the drivetrain pushing power- this has been the key problem in this design. All that I need is a game that would support the idea.
And also- The design is very secret... so I may not share it until it has been tested.
  #39   Spotlight this post!
Unread 27-07-2005, 00:46
Karthik1's Avatar
Karthik1 Karthik1 is offline
830 Alumni
AKA: Karthik Chokkaram
FRC #1504 (Desperate Penguins)
Karthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to all
I have a cool idea its basically holonomic with treads. Think omni treads.
Something ...... like this
"freedom is voluntary self control” Mahatma Gandhi
  #40   Spotlight this post!
Unread 27-07-2005, 03:07
Santosh and i have been on IM allot and have been throwing around a cool design (among other cool ideas) for a treaded crab drive. I'm keeping the details to myself Santosh can share if he wants but its nice!
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
  #41   Spotlight this post!
Unread 27-07-2005, 03:33
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
I do!
My A&P and other bio and life science classes have given me several interesting ideas.
Wetzel
Viva Olancho!
  #42   Spotlight this post!
Unread 27-07-2005, 20:59
Jizvonius's Avatar
Jizvonius Jizvonius is offline
AKA: Jevawn Roberts
FRC #1002 (CircuitRunners)
Jizvonius is just really niceJizvonius is just really niceJizvonius is just really niceJizvonius is just really nice
Send a message via AIM to Jizvonius
Nice, the circuitrunners were considering that, but not only omni-treads, but also...TREAD-OMNIS.
Hope that was forboding enough. We thought, we can put rollers on a tread, or replace the rollers on an omniwheel with treads thus creating something that resembles a barrel made of treads. you could drive a robot with one of these if you wanted, but two would give you tank treads and traction in on direction, and omni-wheel drive and traction in the other. The weight and complexity of the design that i came up with made it very impractical, but it was still very cool.
Jevawn Roberts
Georgia Tech Mechanical Engineering Senior
Co-Leader - GT FIRST
gtfirst@robojackets.org
1997-2007 w00t for robots!
108-132-408-832-1002
5 teams worth of head scratching
  #43   Spotlight this post!
Unread 04-08-2005, 12:22
cbudrecki's Avatar
cbudrecki cbudrecki is offline
AKA: Carl Budrecki (buh-dre'-key)
FRC #0222 (Tigertrons)
cbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to all
Lightbulb Re: Cool new ideas for FIRST Robots - who has them?
here's something that I thought of last night... I don't really think it'd be possible, and if it were, the programming would be an absolute nightmare but anyway... instead of joystick controls, have the robot navigate by coordinates that correspond to a computer drawing tablet( that could easily be painted or marked to match the field) and the robot would be moving in relation to the stylus. a step up would to even use a mini-mouse (with my thoughts, wireless would be best) instead of the stylus and then the buttons on the mouse could be used for robot functions, and here's where the wireless would come in handy, to make steering easier, make the robot rotate in conjuction with the mouse (front of mouse = front of robot) obviously, some type of omnidrive system(crab, macadam, or otherwise) would be ideal.
Again, probably would never be possible, and if it were, it'd prob. take years to program, but wouldn't it be neat?!?
  #44   Spotlight this post!
Unread 04-08-2005, 12:54
Re: I do!
Wetzel
Whats the term for copying living organisms - copying the way living things accomplish a task?
biomimicry?
  #45   Spotlight this post!
Unread 04-08-2005, 15:02
Yes. Why what creature were you planning on mimicing?
Students design robots, beneficial technology Billfred FIRST In the News... 0 07-02-2005 01:32
Driving Robots under/into the Goals ... allowed? erniep Rules/Strategy 8 11-01-2005 22:32
Robots really are nuclear powered suneel112 Electrical 14 25-04-2004 12:25
What about prettiest robots? archiver 2000 8 23-06-2002 23:09
