Go to Post This is what happens when a couple of whackos get an idea at 2 am. - Rich Kressly [more]
Unread 29-06-2005, 02:06
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: 3 speed concept - 1st gear
Originally Posted by David Guzman
I have always wonder about this kind of shifting, how long can a gear box like this last?
I had this idea a while ago but I didn't think it would work because of the gears hiting when shifting. What do you all think about using brass for one of the gears that meshes and steel for the other one. I think since brass is a softer metal it would start to take the shape needed to shift properly.
I know there was a team that use this method and had four speeds, i think it was team 33 but im not sure? someone please correct me if wrong.
Dave
Teams have been using this style of shifting for quite some time, and overall, when constructed properly, it seems to be extremely reliable. I suppose if you shift a whole lot, you may need to have extras of the meshing gears on hand, incase you happen to shear a tooth, or completely wear them down, but considering that a team who attends 4 events (2 regionals, nats, an offseason. Yes I know many teams go to more than this), with an average of 10 rounds per event, that's only 80 minutes of drive time, which should be well within the lifespan of most things built for FIRST.
2001-2004: Team 100
2006-Present: Team 254
Unread 29-06-2005, 03:04
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I would agree. It's like one of those things that shouldn't work but does. I will note that as SVR I know 254 was having a good bit of trouble with it (I think it was Friday evening), but I don't know what it was caused by. So it wouldn't be fair to say mesh shifters are inherently troublesome. I don't think the design is nearly as robust as a constant mesh dog shifter, but there is no evidence to suggest that a mesh shifter is not robust enough for it's use. I don't like how mesh shifters work, but you can't deny the fact that they do work, and seemingly pretty well.
I have a couple questions. Do mesh shifters prefer to be shifted under speed and load? I know the dog shifters just love it, but I'm thinking the mesh shifters might like a slower easier shift.
Can someone who has driven one enlighten us?
Unread 29-06-2005, 17:30
Bill Gold Bill Gold is offline
Retired -- 2006
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
Originally Posted by sanddrag
I wonder what teams like 254 or 60 do to their gearboxes to make them shift well. I've been looking at this one I wonder if they added c-c distance or beveled the gears or just left them.
In our 2005 drive transmissions we added a little in the center-to-center distance (off the top of my head I think it was 0.0015", but I can check on that if you'd want) and chamfered the shifting gears.
Also, we didn't care how fast we were running the transmissions when we shifted. Our problems on Friday at SVR weren't related to the gears themselves. There were minor problems within the transmission related to snap-rings. We had no other mechanical issues after fixing that problem (which originated in Sacramento) for the rest of the season.
pic: 2 speed shifty on the fly Lego Bot CD47-Bot Robot Showcase 9 31-01-2005 04:21
pic: Need an EDU Beval Gear CD47-Bot Robot Showcase 8 30-10-2003 14:03
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
pic: 716 single speed CD47-Bot Extra Discussion 2 09-09-2003 15:51
