Go to Post Oh great, look what you just did. The GDC will probably find ways to use this to torture teams in 2011. I hope you're happy now. - synth3tk [more]
Unread 21-01-2005, 13:30
Ryan Collings Ryan Collings is offline
None #0313 (Bionic Zebras)
Ryan Collings is an unknown quantity at this point
Re: CMUcam setup
ok, my computer, which is an amd +2800, I guarantee you it is fast enough, is the only thing hooked the the camera, I am feeding it 12 volts which is in the specifications of the camera.
I get the response but I can not send anything to the camera, I am totally ignorant on using a terminal emulator.
Unread 21-01-2005, 13:35
RIgnazio RIgnazio is offline
Team Role: Webmaster
RIgnazio will become famous soon enough
Re: CMUcam setup
OK. Here is the best thing to do:
Use an EDU controller, or if you do not have that then use the FRC controller. Use a PWM cable to get the power from the controller to the cam. You do not need to set pwmXX = 254 to do this; it is already putting out power. What makes it work is the SIG pin, which in this case you don't need anyway. So camera is hooked up to any PWM_out you want it to be...Power on the controller and Camera. (Be sure to have the serial cable plugged in as well). Now, turn it on and you will see the LED's come to life. Now run the GUI, making sure you are setting it to the correct COM number, by the way, Serial is typically COM1 but it varies by computer. Try that out, and PM me if you still need help.
Unread 21-01-2005, 16:48
Capt. Slash's Avatar
Capt. Slash Capt. Slash is offline
Animation Captain
AKA: Kyle Budd
FRC #0935 (RaileRobotics)
Team Role: Animator
Capt. Slash is an unknown quantity at this point
Re: CMUcam setup
We have our camera up and running but if we don't have enough lighting and turn on a light we get a funny feed from the camera. The only way we have found to fix this problem is to close the program and relaunch it.
Does anyone know of a different way to fix this and if so what did you do?
Finalist- St. Louis Regional- 2005
Winner- Denver Regional- 2005
Winner- Denver Regional- 2006
Motorola Quality Award- Denver Regional- 2006
Autodesk Visualization Award- Kansas City Regional- 2007
Motorola Quality Award- Kansas City Regional- 2007
Winner- Kansas City Regional- 2007
Unread 22-01-2005, 13:12
Re: CMUcam setup
I found the problem, it was the serial cable I was using. thankyou for all the advice though. I also figured out how to configure Hyper Terminal so I can see what i am typing.
Unread 22-01-2005, 16:07
roboticsjenkins's Avatar
roboticsjenkins roboticsjenkins is offline
robotics_jenkins
AKA: Andrew
#0616 (Southampton Indian Robotics)
Team Role: Electrical
roboticsjenkins can only hope to improve
Send a message via AIM to roboticsjenkins Send a message via Yahoo to roboticsjenkins
Re: CMUcam setup
Could anyone tell me how they mounted the servo motors to the camera ?
Unread 22-01-2005, 17:56
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: CMUcam setup
We mounted them exactly as documented in the "Start Here" .pdf provided by Innovation First and it worked perfectly. You can find the document on Innovation First's website.
Unread 28-06-2005, 09:46
brijkalani brijkalani is offline
brijkalani is an unknown quantity at this point
Re: CMUcam setup
hi,
i connected cmu cam-2 to the pc by serial port com-1 according to the instructions in the manual. on startin the hyperterminal i shows " cmucam2 v1.01 c6" but after that on typing :gv it returns :ck
Also the cmucam gui does not detect the cam at all.
m quite new to hyperterminal, dont know how to use its commands and cmu cam as well. it wud be great if anyone can help me out.
thnks Brij
Unread 28-06-2005, 16:52
Electrical Engineer
Rookie Year: 1995
Re: CMUcam setup
Originally Posted by brijkalani
hi,
thnks Brij
Brij,
Since you are missing the "A" in "ACK", I am guessing that you have a buffering issue...
I had a very difficult time trying to get hyperterminal to work with another device recently and ending up abandoning it for another communications package (I used VBTerm) which worked fine... HT has issues...
However, since the gui is not working either, I would check both the port settings and advanced port settings on the com ports. Also, check for hardware and/or software conflicts.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 29-06-2005, 11:24
Re: CMUcam setup
Thnks mike,
although i could hyperterminal could not return commands properly my cam has started working now! well one advice for others who are facing problems installing is always run cmu gui after closing the hyperterminal window.
would surely like to know how to solve this problems in hyperterminal/
regards,
Brij
Originally Posted by Mike Betts
Brij,
Regards,
Mike
Unread 29-06-2005, 17:19
Electrical Engineer
Rookie Year: 1995
Re: CMUcam setup
Brij,
As I said, I was unable to get HT to work (you will find my "adventures" embedded in this thread). I suggest that you use another communications package.
Good Luck,
Mike
Mike Betts
Unread 12-01-2006, 21:02
CarpeDiem CarpeDiem is offline
FRC #0135
CarpeDiem is an unknown quantity at this point
Re: CMUcam setup
we tried to get the cam working and cant get any power to it from the RC or the computer what am i mising? also does the ttl chip go on the RC?
Unread 13-01-2006, 01:00
b_mallerd b_mallerd is offline
Programmer
FRC #1346 (Trobotics)
b_mallerd is on a distinguished road
Send a message via MSN to b_mallerd
Re: CMUcam setup
Make sure you plug in the main power to the RC so that it has a 12v battery and the 7v backup. Don't connect the ttl if you are using the serial port to the computer. We had this problem for the entire day today and didn't figure it out till the end. Now we having some pan/tilt problems...but oh wells....plenty of time still right? =)
CMUCam for drivers patTeam241 Technical Discussion 22 16-01-2005 01:21
Dual monitor Display setup.... BrianJennings Inventor 6 12-01-2005 20:35
Problems with Autonomous due to motor setup xxlshortys Programming 10 16-03-2004 14:38
Competition IR Beacon - how does its physical setup compare to our beacons? DanL Electrical 2 25-01-2004 18:05
Official California Robot Games announcement! Ken Leung Off-Season Events 9 01-10-2003 03:37
