Go to Post Meh, that's nothing a freshman with a drill press and a dremel can't fix... - Chad987 [more]
Unread 30-06-2005, 13:13
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
FIRST contact database
Prompted by the Networking idea for FIRST teams through Gmail, I made a quick little database for contact information. Right now it's not very pretty and lacks some functionallity, but if we get enough teams in it, I'll work on that. At this point I've wasted 15 minutes of my life working on it; if I make it pretty, I may waste 30.
Anyways, if you can (make sure to check with parents or mentors or whomever), please put your team in the FIRST contact database.
Unread 30-06-2005, 15:27
Programming User
Re: FIRST contact database
Just in case it's interesting, there are currently 6 teams in the database. I'm going to say 20 teams and I'll clean it up some.
And the real reason for the post is the say: You can view a list of the teams in the database at http://traherom.homeunix.net/contacts/list.php.
Unread 30-06-2005, 16:59
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
If we can get more teams to sign up, this is pretty cool. Great Job.
Unread 30-06-2005, 17:46
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
This is cool, I'll check with our head mentor and add us later if he ok's it.
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
Unread 01-07-2005, 10:50
Programming User
Well, I had nothing better to do today because my current project (JFY) is in a state of possible desctruction because of competition, so I started working on the nicer version of the frontend which is up at http://traherom.homeunix.net/contacts2. Looks fairly nice, I guess, except for the corner rounding things in IE.
If you go there in IE, you'll see that the corners don't exactly position themselves correctly...
The divs which contain the corner image have a green border around them and the image itself has a red border. I gave the div which contains the rounder divs a black border, and as you can see it doesn't extend down to the images. The out divs are used to clip the corner image, which is just a circle:
Do you have any idea what's going on there? I would think IE just doesn't support multiple classes, but I've done it before...
--EDIT--
Oh, yeah, the borders are just for debugging. They're going away, don't worry.
Unread 01-07-2005, 10:54
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
It appears that there are issues with the edit page.
-Michael Dessingue
Programming User
Yep... I haven't done that yet.
Unread 01-07-2005, 11:59
Programming User
So, I worked some on it and, ignoring the IE problem, I'd recommend that you use the new version. It's pretty and has several new features, including editing!
Yep, go it working. If you had to enter a password when you added your team, then you can go to the "edit" page and change your teams information. If you're one of the 6 who didn't have to do that, PM me and I'll set you put a password. And no, the teams which don't have passwords can't be edited by anyone.
Unread 01-07-2005, 12:07
Parse error: parse error, expecting `')'' in D:\Apache2\htdocs\ryan\contacts2\add.php on line 13
while trying to access http://traherom.homeunix.net/contacts2/add.php
-Michael Dessingue
Unread 01-07-2005, 12:11
Programming User
Oops..
All better now. Thanks.
Unread 01-07-2005, 14:30
rufu5's Avatar
rufu5 rufu5 is offline
20something
FRC #6721 (Trailblazer Robotics)
rufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud of
Send a message via AIM to rufu5
awsome! i just added my team 447
have no fear of perfection, you will never reach it.
-Salvador Dali
Unread 02-07-2005, 13:12
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
What about instead just providing teams with other teams emails, why not have a PM kinda system set up. You could send another team a message, and when they logged into their account they could check their messages. Maybe email alerts for when teams get messages?
http://www.mikesorrenti.com/
Unread 02-07-2005, 13:27
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Why make the system more complex than it needs to be? An e-mail alert to check what's basically an e-mail?
Unread 02-07-2005, 13:28
Programming User
Hm... interesting. I might work on that sometime! (or in a little bit, whichever.)
Or maybe he's right.
Unread 18-07-2005, 07:09
Programming User
The FIRST Contact Database is now up to 31 teams (number updated)! What?!? You've never heard of the contact database? Well, check to see if your team is already in it and, if it isn't, add it (with a mentor/parent's permission)!)
Because of its huge () size, I'm willing to put in some more time on it. Anyone have any suggestions? The current list of suggestions/bug fixes I may do:
  • Add PM type functionality
  • Every single *nix browser I've viewed it on (even FF, which works fine on IE), displays the wrong quarter of the rounding circle on the right side, as well as pushing it some distance left... (Boy, that's a bad sentence.)
Last edited by Ryan M. : 18-07-2005 at 16:02. Reason: Changed number to represent the new interest
Introducing the Driver Strategy Database's Online Database impulse3D Rules/Strategy 17 17-03-2005 03:04
Teach Genia How to Program and Win a Prize Eugenia Gabrielov Chit-Chat 25 25-02-2005 13:31
Amount of contact this year Ben Mitchell Rules/Strategy 18 02-02-2004 21:02
We have to organize to win archiver 2001 18 24-06-2002 00:00
