Go to Post Corn dogs for everyone! - DCA Fan [more]
Unread 04-07-2005, 20:17
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
hex file garbage?
There's two lines at the end of the hex files that I can't figure out. They're the 3rd and 2nd to last (the two before the last line).
:020000040030CA
:0E000000FFFEFEFCFFFEFBFFFFFFFFFFFFFF0A
I can't figure out exactly what they do. From what I understand, the first one
:020000040030CA
says to prepend 0x0030 to the address of any data records that come after it. That would mean however, the the next line
writes data to 0x00300000, which as far as I can tell, doesn't exist. The last address in the flash memory is 0x7FFF.
Any ideas?
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 04-07-2005, 20:58
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: hex file garbage?
No ideas, but I'm inpressed you understood all but two lines...
Wow... nice. I'm in awe.
Unread 04-07-2005, 23:04
fowlerm's Avatar
fowlerm fowlerm is offline
Bringing .NET to Robots
AKA: Matthew Fowler
FRC #0312 (Heatwave); FRC #1369 (Minotaur)
fowlerm has a spectacular aura aboutfowlerm has a spectacular aura aboutfowlerm has a spectacular aura about
The code memory space ends at 0x7FFF but the highest flash address on the 18F8520 is 0x3FFFFF. The memory addresses from 0x300000 - 0x30000D are used for the device's configuration settings such as clock source, code protect, etc. Addresses 0x3FFFFE and 0x3FFFFF are for the device ID bits.
IFI Loader problem - "Invalid HEX file" wun Programming 9 22-09-2004 12:35
Does anyone have the FIRST logo in 2D .dwg or .dxf file? Elgin Clock Inventor 5 11-03-2004 16:40
Dashv2.ocx dependency file now available archiver 2000 0 23-06-2002 22:00
Improving PBASIC: Request for Comments Greg Ross Programming 19 16-02-2002 22:14
