Go to Post I'm not basing success on winning a regional. Success is learning by building the best system you can. In the engineering industries, the best system is the one chosen. - AdamHeard [more]
Unread 07-07-2005, 02:17
Joe Clohessy's Avatar
Joe Clohessy Joe Clohessy is offline
#0522 (RoboWizards)
Joe Clohessy will become famous soon enough
Send a message via AIM to Joe Clohessy
Final drive torque
I would like to know if someone would be able to help me. I want to find out the ammount of torque at the output shaft on my transmission. Is there a way of taking the motor torque and doing some math with the gear reduction in the transmission? Given I know the RPM of the transmission output shaft. If someone could make a Excel sheet not just for me but for everyone that would be helpful to most. Thankyou
--2004 NYC Regional Winners
--2004 NYC DaimlerChrysler Team Spirit Award
--2004 NYC GM Industrial Design Award
--2003 NYC Regional Winners
--2003 NYC Motorola Quality Award Winner
--2003 Philadelphia Eliminations With Team 365 MOE and Team 341 Miss Daisy
--2003 8th seed Championship Curie
--2003 Eliminations With Team Hammond the 2002 Championship Winners and Team 223 Xtreme Heat
Unread 07-07-2005, 02:20
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: Final drive torque
I believe this is what you're looking for: JVN's FIRST Mechanical Design Calculator
I made my own version of it, but same concept. Very useful tool.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 07-07-2005, 02:25
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
If you know the Output RPM and the motor RPM, you have your overall ratio. Speed is inversly proportional to torque. That means, when your speed goes down, the torque goes up. If the speed is cut in half, the torque is doubled.
Say you have a motor that is 5000 RPM with 2 N-m (newton-meters) of torque. It is put through a 12:1 reduction (or 1:12 depending on how you look at it) which makes the transmission output shaft speed (5000/12) 417 RPM. The torque on the output shaft will be 2*12 which is 24 N-m. Other common units of torque are pound-feet (called foot-pounds by some) represented by lb-ft and ounce-inches represented by oz-in.
I hope this helps.
If you have any more questions, just ask and I'll be back here to answer them.
Unread 10-07-2005, 19:50
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
That all works in theory... and you have to know the theory to understand the rest. But in real like efficiency of the gears really messes with things. We had a gearing for our arm that should have worked, but it didn't because efficiency of the gears.
So don't rely on something that *should* be right on at the limit, could very well lose a lot of torque to inefficiencies in the gears, and not work.
2005 Philly #1 seeded team, highest average points, and semi-finalists
Thanks to 103 and 484 for being alliance mates.
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
Gear Woes Simon G Technical Discussion 14 24-01-2002 16:31
Traction Limited, rather than torque Simon G Technical Discussion 6 23-01-2002 07:08
