Go to Post My brain is borderline mush, I don't have much of a voice, and I don't think I could be much happier. - Billfred [more]
Unread 07-07-2005, 12:30
ImmortalAres ImmortalAres is offline
ImmortalAres is an unknown quantity at this point
TTL port to a serial port on a demo board
i'm trying to communicate between the RC and a 2nd PIC on a demo board that has a serial port. I can get data off the demo board and onto my copmtuer so i know that the port works. my question is this: What is the best way to go about communicating between the TTL port and a serial port? It seems the best way would be to do it the same way they describe on page 163 of the PIC18F6520/8520/6620/8620/6720/8720 data sheet.
"The master controller (Processor 1)
initiates the data transfer by sending the SCK signal.
Data is shifted out of both shift registers on their programmed
clock edge and latched on the opposite edge
of the clock. Both processors should be programmed to
the same Clock Polarity (CKP), then both controllers
would send and receive data at the same time."
how do i go about sending an SCK signal?
Unread 07-07-2005, 14:40
fowlerm's Avatar
fowlerm fowlerm is offline
Bringing .NET to Robots
AKA: Matthew Fowler
FRC #0312 (Heatwave); FRC #1369 (Minotaur)
fowlerm has a spectacular aura aboutfowlerm has a spectacular aura aboutfowlerm has a spectacular aura about
Re: TTL port to a serial port on a demo board
You are talking about two different technologies. The interface method you are talking about is using one of the PICs USARTs to communicate with another PIC. The method that you referenced from the data sheet is using SPI and the PICs MSSP to communicate with another PIC.
To talk to the RC you will need to use the USART. I just want to be sure - are you trying to interface an RS-232 level port from your demo board with the TTL port on the RC or with the RS-232 level port (Program Port) on the RC? Unless you want to use a level shifter like a MAX232 you probably want to use the RC's Program Port to communicate with your demo board. Also, SPI communication with either of the PICs on the RC is not possible because IFI has used the SPI ports to link the Master with the User.
If you are using the C18 compiler you might want to take a look at the sample code that Kevin Watson did demonstrating serial communication with the RC. I think you'll have to modify the code if you are using a PIC that only has one USART (like the 452).
Unread 07-07-2005, 15:15
TTL port on the RC to an RS-232 on the demo board. I have a null modem TTL to serial cable already
Unread 07-07-2005, 16:07
if i use the new serial code from kevin's site is the following still valid?
printf("yaccel = %d\n",x_accel);
if not, which i have a feeling is the case as i didn't see any code defining that format how would i go about printf'ing the value of a variable such as the x_accel
thanks
Unread 08-07-2005, 06:10
Electrical Engineer
Rookie Year: 1995
Beware... A null modem cable usually handles the in/out pin swaps only and not level shifting...
Mike Betts
As easy as 355/113...
Unread 08-07-2005, 06:17
Electrical Engineer
Rookie Year: 1995
printf("yaccel = %dn",x_accel);
thanks
Huh? Your question is confusing...
You will be writing both the send and receive on both processors. The protocol is yours to define on both sides...
Mike Betts
Unread 08-07-2005, 10:24
1) what is level shifting?
2) my question was really how to i print a variables value, the printf fns look like string prints
Unread 08-07-2005, 11:32
actually i'm kinda lost as to how to get it to work at all. it gets hung up on the while loop
#ifdef ENABLE_SERIAL_PORT_TWO_TX
void Write_Serial_Port_Two(unsigned char byte)
	// if the queue is full, wait here until space is available
	while(Tx_2_Queue_Full); //<------it hangs here
	// put the byte on the circular queue
	Tx_2_Queue[Tx_2_Queue_Write_Index] = byte;
	// increment the queue byte count
	Tx_2_Queue_Byte_Count++;
	// increment the write pointer
	Tx_2_Queue_Write_Index++;
	// If the index pointer overflowed, cut-off the high-order bit. Doing this
	// every time is quicker than checking for overflow every time with an if()
	// statement and only then occasionally setting it back to zero. For this
	// to work, the queue size must be a power of 2 (e.g., 16,32,64,128...).
	Tx_2_Queue_Write_Index &= TX_2_QUEUE_INDEX_MASK;
i personally don't understand how it got there in the first place as the only call to write serial port is in the put_c function and i never called that nor did i see it get called in the tx_interrupt handler
any clarifications would be wonderful
Thanks
Unread 08-07-2005, 11:56
CapnBFG's Avatar
CapnBFG CapnBFG is offline
CapnBFG is an unknown quantity at this point
I'm working with ImmortalAres on this project and just want to clarify what the cable is. The cable we bought does have an integrated circuit to shift levels between TTL and RS232. However, the pin layout for the RS232 end is set up as a null modem.
This is the cable we are using:
http://www.superdroidrobots.com/shop...d=130&catid=42
Wake up and smell the ashes.
Unread 08-07-2005, 12:06
Electrical Engineer
Rookie Year: 1995
In your code example, you are hanging because the queue is full. It will not empty unless there is communications established.
Level shifting: TTL is a 0V to 5V signal. RS232 is usually -12V to +12V. You can not just wire the two together without some sort of level shifter (see Fowlerm's post).
Printf: Indeed, printf statements output a string (the f in printf stands for formatted). I would avoid sending binary (unformatted) data until you have your system well established and debugged. Without a serial protocol analyzer, debugging unformatted communications is very difficult.
JMHO
Mike
Mike Betts
Unread 08-07-2005, 12:12
fowlerm's Avatar
AKA: Matthew Fowler
Are you using the 18F8520 on your demo board? I think from previous posts you said you were using the 18F452. If this is the case then you need to get rid of all of the functions and variables in Kevin's code that deal with USART2, and then change all of the remaining references to register aliases so they no longer include the 1. The 18F452 only has one USART.
If you haven't done so already, you will also need to add a low-priority interrupt handler and add Kevin's interrupt handler functions to the low-priority handler. You can look at the code he has written to see how to do this. Look at the readme file because it goes over how to use the serial driver to send/receive data.
That cable you got should work fine.
Unread 08-07-2005, 12:25
Electrical Engineer
Rookie Year: 1995
1. The cable you are using is intended to go to a PC. An RS232 link contains two ends. One end is called the Data Terminal Equipment (DTE). The other end is called Data Communications Equipment (DCE). PCs are DTE, while modems and most embedded controllers are DCE.
I do not think you want a null modem cable.
2. Following the links for your cable I find this which has a pinout very different from port 2 on a FRC controller.
I would look at your wiring more carefully...
Edit: Are you using a handshaking cable? The FRC controller does not support CTS/RTS handshaking.
Regards,
Mike
Mike Betts
Unread 08-07-2005, 12:33
i know about changing all the registers, i've been doing that to all the code our FIRST team already had so that i could migrate it over to the 2nd PIC and leave the RC for autonomous decision making. i've changed all the registers and the confusion that has started on the thread is due to the fact that there are two things happening here.
1) i'm trying ot get data of the board serially straight to the computer to make sure everything works
i tired printfing a straight string with no data variables and it still hung meaning no communication is getting established, i'm not sure why. i'll show my redone code for the 452 in the next post
2) THEN, i'm going to use the TTL line for the PIC to RC comms
so i will be looking into our choice of cables, thank you guys for pointing out that issue. i did not know about it.
CapnBFG's Avatar
Thanks for the info regarding the cable. I wasn't aware of the differences between RS232 connections. That's why I showed the link above to our mentor and let him decide whether it would work. He bought it, so I assumed he made the right choice since I hadn't even dealt with serial communication until this summer. Is there any type of adapter we can put on the RS232 end of the cable that will make it work as a DCE?
As for wiring the TTL end, I had already looked at that diagram and switched the pins around to correspond with the TTL port on the FRC, but thanks anyway for pointing that out
Yes our cable supports handshaking but no we are not using that feature. We got a cable that supported it just in case the team happens to need it in the future. Is not using the handshaking going to cause a problem for the adapter?
Unread 08-07-2005, 12:39
serial_ports.c
*	TITLE:		serial_ports.c
*	VERSION:	0.3 (Beta)
*	DATE:		05-Feb-2005
*	AUTHOR:		R. Kevin Watson
*				kevinw@jpl.nasa.gov
*	COMMENTS:	The source code in this file implements a fully buffered,
*				interrupt-driven serial port driver that can be used with
*				either or both on-board serial ports.
*				This source code will work with the Robovation (A/K/A EDU-RC)
*				robot controller and the FIRST Robotics robot controller.
*				By default, serial port one will operate at 115200 baud, which
*				is compatible with InnovationFIRST's terminal program, and
*				serial port two will operate at 9600 baud. These values can be
*				easily changed by modifying the	serial port initialization
*				functions mentioned below.
*               This file is best viewed with tabs set to four characters.
*				Nine things must be done before this software will work
*				correctly:
*				  1a) FRC-RC: As this software is intended to replace IFI's
*				  serial port driver, the call to Serial_Driver_Initialize()
*				  in user_routines.c / User_Initialization() should be
*				  removed or commented out.	In addition, all references to
*				  "user_Serialdrv.c" and "user_Serialdrv.h" must be removed
*				  from the project and all project source files.
*				  1b) EDU-RC: As this software is intended to replace IFI's
*				  serial port driver, the call to Initialize_Serial_Comms()
*				  "printf_lib.c" and "printf_lib.h" must be removed from
*				  the project and all project source files.
*				  2) You must add the serial_ports.c/.h source files to
*				  your MPLAB project.
*				  3) A #include statement for the serial_ports.h header
*				  file must be included at the beginning of each source
*				  file that uses the serial ports. The statement should
*				  look like this: #include "serial_ports.h".
*				  4) If you intend to use the C18 output stream functions,
*				  A #include statement for the stdio.h header file must be
*				  included at the beginning of each source file that calls
*				  any of these functions. The statement should look like
*				  this: #include <serial_ports.h>.
*				  5) Init_Serial_Port_One() and/or Init_Serial_Port_Two()
*				  must be called from the User_Initialization() function
*				  located in the user_routines.c source file.
*				  6) The interrupt handler(s) must be installed in the
*				  InterruptHandlerLow() function located in the
*				  user_routines_fast.c source file. See the accompanying
*				  copy of user_routines_fast.c to see how this is done.
*				  7) Decide what functionality you need and comment out the
*				  #define ENABLE_SERIAL_PORT_xxx_yy entries in serial_ports.h
*				  as necessary. As an example, if you only need to send data
*				  using serial port one and would like to reclaim the resources
*				  used by serial port two and serial port one's receiver
*				  source code, the top of the serial_ports.h file would look
*				  like this:
*				  // comment out the next line to disable all serial port one
*				  // receive functionality
*				  // #define ENABLE_SERIAL_PORT_ONE_RX
*				  // transmit functionality
*				  #define ENABLE_SERIAL_PORT_ONE_TX
*				  // comment out the next line to disable all serial port two
*				  // #define ENABLE_SERIAL_PORT_TWO_RX
*				  // #define ENABLE_SERIAL_PORT_TWO_TX
*				  By default, both serial ports and their respective receive
*				  and transmit sections are enabled.
*				  8) As the default output device for C18's output stream
*				  functions is the null device, you'll presumably want to
*				  change the value of stdout_serial_port to "SERIAL_PORT_ONE"
*				  or "SERIAL_PORT_TWO" if you want to see printf()'s output.
*				  User_Initialization() is a good place to do this.
*				  9) To support terminal emulation software, \r\n should
*				  be used instead of just \n in the printf() format string.
*				This serial port driver can send output stream data to either
*				of the serial ports by setting the value of the global variable
*				stdout_serial_port before calling output stream	functions like
*				printf(). Setting the value	to "SERIAL_PORT_ONE" will send the
*				output to serial port one. Likewise, setting the value to
*				"SERIAL_PORT_TWO" will send the output to serial port two.
*				Setting the value to "NUL" will send the output to the null
*				device, meaning that the output is sent	nowhere. These values
*				are #define'd in serial_ports.h. As an example,
*				  stdout_serial_port = SERIAL_PORT_ONE;
*				  printf("Kernighan");
*				  stdout_serial_port = NUL;
*				  printf("and");
*				  stdout_serial_port = SERIAL_PORT_TWO;
*				  printf("Ritchie");
*				will send the text "Kernighan" to the peripheral device attached
*				to serial port one, the text "Ritchie" to the device attached to
*				serial port two and the text "and" won't be sent anywhere.
*				By default, output is sent to the null device, which is the only
*				output device guaranteed to be present.
*				You are free to use this source code for any non-commercial
*				use. Please do not make copies of this source code, modified
*				or un-modified, publicly available on the internet or
*				elsewhere without permission. Thanks.
*				Copyright ©2004-2005 R. Kevin Watson. All rights are reserved.
*	CHANGE LOG:
*	DATE         REV  DESCRIPTION
*	22-Dec-2004  0.1  RKW - Original code.
*	28-Dec-2004  0.2  RKW - Using preprocessor directives, added the ability
*	                  to enable/disable individual serial port receive and
*	                  transmit code. Updated documentation.
*	05-Feb-2005  0.3  RKW - Added _user_putc() interface to C18's new output
*	                  stream capabilities. Updated documentation.
#include <stdio.h>
#include "p18f452.h"
// by default stdout stream output is sent to the null device,
// which is the only device guaranteed to be present.
unsigned char stdout_serial_port = NUL;
// Serial Port 2 Receive Variables:
#ifdef ENABLE_SERIAL_PORT_TWO_RX
volatile unsigned char Rx_2_Queue[RX_2_QUEUE_SIZE];	// serial port 2's receive circular queue
volatile unsigned char Rx_2_Queue_Full = FALSE;		// flag that indicates that serial port 2's
													// receive circular queue is full and cannot
													// accept any more data
unsigned char Rx_2_Queue_Empty = TRUE;				// flag that indicates that there is no more
													// data present in serial port 2's receive
													// circular queue
unsigned char Rx_2_Queue_Read_Index = 0;			// read index into serial port 2's receive
													// circular queue
volatile unsigned char Rx_2_Queue_Write_Index = 0;	// write index into serial port 2's receive
													// circular queue
volatile unsigned char Rx_2_Queue_Byte_Count = 0;	// number of bytes in serial port 2's receive
													// circular queue
volatile unsigned char RX_2_Overrun_Errors = 0;		// number of overrun errors that have occurred
													// in serial port 2's receive circuitry since
													// the last reset
volatile unsigned char RX_2_Framing_Errors = 0;		// number of framing errors that have occurred
													// the last reset
#endif
// Serial Port 2 Transmit Variables:
volatile unsigned char Tx_2_Queue[TX_2_QUEUE_SIZE];	// serial port 2's transmit circular queue
volatile unsigned char Tx_2_Queue_Full = FALSE;		// flag that indicates that serial port 2's
													// transmit circular queue is full and cannot
volatile unsigned char Tx_2_Queue_Empty = TRUE;		// flag that indicates that there is no more
													// data to send in serial port 2's transmit
													// circular queue
volatile unsigned char Tx_2_Queue_Read_Index = 0;	// read index into serial port 2's transmit
													// circular queue
unsigned char Tx_2_Queue_Write_Index = 0;			// write index into serial port 2's transmit
													// circular queue
volatile unsigned char Tx_2_Queue_Byte_Count = 0;	// number of bytes in serial port 2's transmit
													// circular queue
#endif
*	FUNCTION:		Init_Serial_Port_Two()
*	PURPOSE:		Initializes serial port two for asynchronous operation
*	CALLED FROM:	user_routines.c/User_Initialization()
*	PARAMETERS:		None
*	RETURNS:		Nothing
*	COMMENTS:		This function must be called before you try to use serial
*					port two.
*					By default, this serial port is set to 9600 baud with
*					the transmitter and receiver enabled.
*					The	serial port's baud rate is programmed by entering
*					a value into the SPBRG2 register and possibly changing
*					the value of the BRGH bit. Several example values are
*					included in the serial_ports.h file.
*					Numbers within brackets refer to the PIC18F8520	data
*					sheet page number where more information can be found.
*					This document can be found at microchip's website at
*					http://www.microchip.com or at the author's website at
*					http://www.kevin.org/frc
*					This function will not be included in the build unless
*					ENABLE_SERIAL_PORT_TWO_RX or ENABLE_SERIAL_PORT_TWO_TX
*					is #define'd in serial_ports.h
void Init_Serial_Port_Two(void)
	// Start by initializing the serial port with code
	// common to receive and transmit functions
	SPBRG = BAUD_19200;		// baud rate generator register [200]
	TXSTAbits.BRGH = 1;	// high baud rate select bit (asynchronous mode only) [198]
							//  0: low speed
							//  1: high speed
	PIE1bits.RCIE = 0;		// receive interrupt enable bit [95]
							//  0: disables received data interrupt
							//  1: enables received data interrupt
	PIE1bits.TXIE = 0;		// transmit interrupt enable bit [95]
							//  0: disables transmit register empty interrupt
							//  1: enables transmit register empty interrupt
	TXSTAbits.SYNC = 0;	// USART mode select bit [198]
							//  0: asynchronous mode
							//  1: synchronous mode
	TXSTAbits.CSRC = 0;	// clock source select bit (synchronous mode only) [198]
							//  0: Slave mode (clock generated by external source)
							//  1: Master mode (clock generated internally from BRG)
	// if receive functionality is to be included in the
	// software build, include code that is specific to
	// initializing the receiver
	TRISCbits.TRISC2 = 1;	// make sure the RG2/RX2/DT2 pin is configured as an input [120]
	RCSTAbits.RX9 = 0;		// 9-bit receive enable bit [199]
							//  0: 8-bit reception mode
							//  1: 9-bit reception mode
	RCSTAbits.ADDEN = 0;	// address detect enable bit (9-bit asynchronous mode only) [199]
							//  0: disables address detection
							//  1: enables address detection
	RCSTAbits.SREN = 1;	// single receive enable bit (master synchronous mode only) [199]
							//  0: disables single receive mode
							//  1: enables single receive mode
	RCSTAbits.CREN = 1;	// continuous receive mode enable bit [199]
							// asynchronous mode:
							//  0: disables receiver
							//  1: enable receiver
							// synchronous mode:
							//  0: disables continuous receive
							//  1: enables continuous receive until CREN is cleared [199]
	IPR1bits.RCIP = 0;		// receive interrupt priority bit (must be 0 for IFI controllers) [98]
							//  0: low-priority
							//  1: high-priority
	PIE1bits.RCIE = 1;		// receive interrupt enable bit [95]
	#endif					//
	// if transmit functionality is to be included in the
	// initializing the serial port transmitter
	stdout = _H_USER;		// use this driver for output stream functions
	TRISCbits.TRISC1 = 0;	// make sure the RG1/TX2/CK2 pin is configured as an output [120] changed to trisC
	TXSTAbits.TX9 = 0;		// 9-bit transmit enable bit [198]
							//  0: 8-bit transmission mode
							//  1: 9-bit transmission mode
	IPR1bits.TXIP = 0;		// transmit interrupt priority bit (must be 0 for IFI controllers) [98]
							//  0: low-priority
							//  1: high-priority
	PIE1bits.TXIE = 1;		// transmit interrupt enable bit [95]
	TXSTAbits.TXEN = 1;  	// Enable transmitter [198]
							//  0: serial transmitter is disabled
							//  1: serial transmitter
	#endif					//
	// finally, turn on the serial port
	RCSTAbits.SPEN = 1;  	// Serial Port Enable [199]
							//  0: serial port is disabled
							//  1: serial port is enabled
*	FUNCTION:		Serial_Port_Two_Byte_Count()
*	PURPOSE:		Returns the number of bytes in serial port
*					two's received data queue.
*	CALLED FROM:
*	PARAMETERS:		none
*	RETURNS:		unsigned char
*	COMMENTS:		This function must be called to determine how much data,
*					if any, is present in serial port two's received data
*					queue. If the returned number is greater than zero, then
*					a call to Read_Serial_Port_Two() can be made to retrieve
*					the next byte.
*					ENABLE_SERIAL_PORT_TWO_RX is #define'd in serial_ports.h
unsigned char Serial_Port_Two_Byte_Count(void)
	unsigned char temp;
	// since we're about to use the Rx_1_Queue_Byte_Count variable,
	// which can also be modified in the interrupt service routine,
	// let's briefly disable the serial port interrupt to make sure
	// that Rx_1_Queue_Byte_Count doesn't get altered while we're
	// using it.
	PIE1bits.RCIE = 0;
	// now we can get a local copy of the byte count without fear
	// that we'll get corrupted data
	temp = Rx_2_Queue_Byte_Count;
	// okay, we have a local copy of the byte count, so turn the
	// serial port interrupt back on.
	PIE1bits.RCIE = 1;
	// return the byte count
	return(temp);
#endif
*	FUNCTION:		Read_Serial_Port_Two()
*	PURPOSE:
*	CALLED FROM:
*	PARAMETERS:		none
*	COMMENTS:		This function will not be included in the build unless
unsigned char Read_Serial_Port_Two(void)
	unsigned char byte;
	if(Rx_2_Queue_Empty)
		// error: no data to read
		return(0);
	else
		// get a byte from the circular queue and store it temporarily
		byte = Rx_2_Queue[Rx_2_Queue_Read_Index];
		// decrement the queue byte count
		Rx_2_Queue_Byte_Count--;
		// increment the read pointer
		Rx_2_Queue_Read_Index++;
		Rx_2_Queue_Read_Index &= RX_2_QUEUE_INDEX_MASK;
		// since we're about to use the Rx_2_Queue_Write_Index variable, which can
		// also be modified in the interrupt service routine, let's briefly disable
		// the serial port interrupt to make sure that Rx_2_Queue_Write_Index doesn't
		// get altered while we're using it.
		PIE1bits.RCIE = 0;
		// is the circular queue now empty?
		if(Rx_2_Queue_Read_Index == Rx_2_Queue_Write_Index)
		// okay, we're done using Rx_2_Queue_Write_Index, so turn the serial port
		// interrupt back on.
		PIE1bits.RCIE = 1;
 		// Since we've just removed a byte to the queue, it can't possibly be full.
		// Again, this is quicker than using an if() statement every time
		// return the data
		return(byte);
#endif
*	FUNCTION:		Write_Serial_Port_Two()
*	PURPOSE:		Sends a byte of data using serial port two.
*	CALLED FROM:
*	PARAMETERS:		unsigned char
*	RETURNS:		nothing
*	COMMENTS:		If you don't initialize the serial port before calling
*					this function, the robot controller will stop functioning
*					and you'll get the much dreaded red-light-of-death. This
*					is because the while() statement below is waiting for the
*					transmit circuitry to send another byte, but if the serial
*					port hasn't been configured, nothing will be transmitted
*					and we'll be stuck in the while() loop.
*					ENABLE_SERIAL_PORT_TWO_TX is #define'd in serial_ports.h
	// since we're about to use the Tx_2_Queue_Write_Index variable, which can
	// the serial port interrupt to make sure that Tx_2_Queue_Write_Index doesn't
	PIE1bits.TXIE = 0;
	// is the circular queue now full?
	if(Tx_2_Queue_Read_Index == Tx_2_Queue_Write_Index)
		Tx_2_Queue_Full = TRUE;
	// okay, we're done using Tx_2_Queue_Write_Index, so turn the serial port
	PIE1bits.TXIE = 1;
	// Since we've just added a byte to the queue, it can't possibly be empty.
	Tx_2_Queue_Empty = FALSE;
#endif
*	FUNCTION:		Rx_2_Int_Handler()
*	PURPOSE:		Serial port two new data interrupt handler.
*	CALLED FROM:	user_routines_fast()
*	PARAMETERS:		None
*	RETURNS:		Nothing
*	COMMENTS:		If the interrupt handler was installed correctly, this
*					function will be called every time a new byte of data
*					is received by serial port two.
void Rx_2_Int_Handler(void)
	if(Rx_2_Queue_Full)
		// just turn off the serial port interrupt if we can't store any more data.
		// the interrupt will be re-enabled within the Receive_Byte() function when
		// more data is read.
		PIE1bits.RCIE = 0;
	else
		Rx_2_Queue[Rx_2_Queue_Write_Index] = RCREG;
		// if the interrupt handler was disabled while data was being received,
		// data may have backed-up in the receiver circuitry, causing an overrun
		// condition. So let's check the OERR bit to see if this has happened
		// and if it has, we'll need to reset the serial port receiver circuitry
		// to get data flowing again.
		if(RCSTAbits.OERR)
			// reset by turning off the receiver circuitry, then...
			RCSTAbits.CREN = 0;
			// ...turn it back on
			RCSTAbits.CREN = 1;
			// indicate that we've had an error
			RX_2_Overrun_Errors++;
		// if incoming data gets misaligned and the receiver doesn't receive a
		// stop bit where it expects to detect it, the receiver circuitry will
		// set the FERR bit to indicate that it's received corrupted data. The
		// likely reason for this is an incorrectly set baud rate on either the
		// receiver or transmitter end.
		if(RCSTAbits.FERR)
			RX_2_Framing_Errors++;
		Rx_2_Queue_Byte_Count++;
		Rx_2_Queue_Write_Index++;
		Rx_2_Queue_Write_Index &= RX_2_QUEUE_INDEX_MASK;
			Rx_2_Queue_Full = TRUE;
		Rx_2_Queue_Empty = FALSE;
#endif
*	FUNCTION:		Tx_2_Int_Handler()
*	PURPOSE:		Serial port two empty transmit buffer interrupt handler.
*	PARAMETERS:		None
*	RETURNS:		Nothing
*					function will be called every time serial port two is
*					ready to start sending a byte of data.
void Tx_2_Int_Handler(void)
	if(Tx_2_Queue_Empty)
		// just turn off the serial port interrupt if we don't have data to send.
		// the interrupt will be re-enabled within the Send_Byte() function when
		// more data is sent.
		PIE1bits.TXIE = 0;
	else
		// get a byte from the circular queue and send it to the USART
		TXREG = Tx_2_Queue[Tx_2_Queue_Read_Index];
		Tx_2_Queue_Byte_Count--;
		Tx_2_Queue_Read_Index++;
		Tx_2_Queue_Read_Index &= TX_2_QUEUE_INDEX_MASK;
 		// Since we've just removed a byte from the queue, it can't possibly be full.
#endif
*	FUNCTION:		_user_putc()
*	PURPOSE:		putc() interface to C18 2.4 output stream functions
*	CALLED FROM:
*	PARAMETERS:		None
*	RETURNS:		Nothing
*	COMMENTS:
void _user_putc(unsigned char byte)
	if(stdout_serial_port == NUL)
		// send the data to the bit bucket
	#ifdef ENABLE_SERIAL_PORT_ONE_TX
	else if(stdout_serial_port == SERIAL_PORT_ONE)
		// send the data to serial port one
		Write_Serial_Port_One(byte);
	#endif
	else if(stdout_serial_port == SERIAL_PORT_TWO)
		// send the data to serial port two
		Write_Serial_Port_Two(byte);
	#endif
serial_ports.h
*	TITLE:		serial_ports.h
*	DATE:		05-Feb-2005
*	COMMENTS:	You are free to use this source code for any non-commercial
*				or un-modified, publicly available on the internet or elsewhere
*				without permission. Thanks.
*	CHANGE LOG:
#ifndef _SERIAL_PORTS_H
#define _SERIAL_PORTS_H
// comment out the next line to disable serial port one
//#define ENABLE_SERIAL_PORT_ONE_RX
//#define ENABLE_SERIAL_PORT_ONE_TX
// comment out the next line to disable serial port two
// Sample values that can be plugged into the SPBRGx register to program the
// baud rate generator for a specific baud rate. Make sure to also set the BRGH
// bit accordingly. See the Init_Serial_Port_One() and Init_Serial_Port_Two()
// functions in the serial_ports.c source file for more information.
#define BAUD_4800  129	// set BRGH = 0
#define BAUD_9600 	64	// set BRGH = 0
#define BAUD_14400  42	// set BRGH = 0
#define BAUD_19200 129	// set BRGH = 1
#define BAUD_38400  64 	// set BRGH = 1
#define BAUD_57600  42	// set BRGH = 1
#define BAUD_115200 21	// set BRGH = 1
#define BAUD_230400 10  // set BRGH = 1
// These values define the size, in bytes, of the four circular queues used to
// buffer incoming and outgoing serial port data. The size of the receive queue
// is critical to prevent data loss. As an example, if you're continuously
// receiving data at 38,400 baud and only call Read_Serial_Port_xxx() in the
// Process_Data_From_Master_uP() loop, which is called every 26.2ms, you'll
// need to size the queue to accept all of the data you expect to receive in
// those 26.2ms. To do this, multiply the rate at which bytes of data are being
// received times the amount of time between calls to Read_Serial_Port_xxx().
// In the above example, we're receiving data at a rate of 3840 bytes per second
// (8 bits of data plus 2 bits of overhead per byte transferred) and we need to
// store at least 26.2ms-worth of that data for a calculated queue size of 101
// bytes. Because the queue size must be a power of two, we'll need to round-up
// to a queue size of 128. Another solution is to check for received serial data
// at a higher rate by putting the call to Read_Serial_Port_xxx() in the much
// faster Process_Data_From_Local_IO() loop. As mentioned above, these values
// must be a power of two (i.e.,8,16,32,64,128) for the circular queue algorithm
// to function correctly.
#define RX_1_QUEUE_SIZE 32
#define TX_1_QUEUE_SIZE 16
#define RX_2_QUEUE_SIZE 32
#define TX_2_QUEUE_SIZE 16
// The circular queue algorithm will break if these values are altered.
#define RX_1_QUEUE_INDEX_MASK RX_1_QUEUE_SIZE-1
#define TX_1_QUEUE_INDEX_MASK TX_1_QUEUE_SIZE-1
#define RX_2_QUEUE_INDEX_MASK RX_2_QUEUE_SIZE-1
#define TX_2_QUEUE_INDEX_MASK TX_2_QUEUE_SIZE-1
#ifndef FALSE
#define TRUE 1
#define FALSE 0
#endif
// #defines used with the stdout_serial_port global variable
#define NUL 0
#define SERIAL_PORT_ONE 1
#define SERIAL_PORT_TWO 2
// if needed, declare functions and global variables that
// are specific to serial port one receiver functionality
#ifdef ENABLE_SERIAL_PORT_ONE_RX
void Init_Serial_Port_One(void);
unsigned char Serial_Port_One_Byte_Count(void);
unsigned char Read_Serial_Port_One(void);
void Rx_1_Int_Handler(void);
extern volatile unsigned char RX_1_Framing_Errors;
extern volatile unsigned char RX_1_Overrun_Errors;
#endif
// if needed, declare functions that are specific to serial
// port one transmit functionality
extern unsigned char stdout_serial_port;
void _user_putc(unsigned char);
void Write_Serial_Port_One(unsigned char);
void Tx_1_Int_Handler(void);
#endif
// are specific to serial port two receiver functionality
void Init_Serial_Port_Two(void);
unsigned char Serial_Port_Two_Byte_Count(void);
unsigned char Read_Serial_Port_Two(void);
void Rx_2_Int_Handler(void);
extern volatile unsigned char RX_2_Framing_Errors;
extern volatile unsigned char RX_2_Overrun_Errors;
#endif
// port two transmit functionality
void Write_Serial_Port_Two(unsigned char);
void Tx_2_Int_Handler(void);
#endif
#endif
user_routines.c
#include <stdio.h>
#include "user_routines.h"
#include "accel.h"
#include "default.h"
#include "interrupts.h"
#include "encoders.h"
#include "ifi_utilities.h"
* FUNCTION NAME: User_Initialization
* PURPOSE:       This routine is called first (and only once) in the Main function.
*                You may modify and add to this function.
* CALLED FROM:   main.c
* ARGUMENTS:     none
* RETURNS:       void
void User_Initialization(void)
/* FIRST: Set up the I/O pins you want to use as digital INPUTS. */
/* SECOND: Set up the I/O pins you want to use as digital OUTPUTS. */
/* THIRD: Initialize the values on the digital outputs. */
  /* Add any other initialization code here. */
  Initialize_Accel();
  Initialize_Interrupts();
  Initialize_Timer_0();
  Initialize_Timer_1();
  Initialize_Timer_2();
  Initialize_Timer_3();
  Initialize_Encoder();
  Init_Serial_Port_Two();
* FUNCTION NAME: Process_Data
* PURPOSE:       duh, processes all the data
* ARGUMENTS:     none
* RETURNS:       void
void Process_Data(void)
  static unsigned char i;
  static unsigned char delay;
  int leftencode;
  int rightencode;
  int x_accel;
  int y_accel;
leftencode=Get_Left_Encoder_Count();
rightencode=Get_Right_Encoder_Count();
x_accel=get_x_accel();
y_accel=get_y_accel();
//printf("lefte = %d\n",leftencode);
//printf("righte = %d\n",rightencode);
//printf("yaccel = %d\n",x_accel);
//printf("xaccel = %d\n",y_accel);
printf("matt's a noob\r\n");
//the following used to be in a seperate file but it was unecessary for my purposes
* FUNCTION NAME: InterruptVectorLow
* PURPOSE:       Low priority interrupt vector
* CALLED FROM:   nowhere by default
* ARGUMENTS:     none
* RETURNS:       void
* DO NOT MODIFY OR DELETE THIS FUNCTION
#pragma code InterruptVectorLow = LOW_INT_VECTOR
void InterruptVectorLow (void)
  _asm
    goto InterruptHandlerLow  /*jump to interrupt routine*/
  _endasm
* FUNCTION NAME: InterruptHandlerLow
* PURPOSE:       Low priority interrupt handler
* If you want to use these external low priority interrupts or any of the
* peripheral interrupts then you must enable them in your initialization
* routine.
* CALLED FROM:   this file, InterruptVectorLow routine
* ARGUMENTS:     none
* RETURNS:       void
void InterruptHandlerLow()
	if(PIR1bits.CCP1IF && PIE1bits.CCP1IE) // CCP1 Interrupt?
		PIR1bits.CCP1IF = 0;
		CCP_1_ISR(); // call the CCP1 ISR (in accel.c)
	else if (PIR2bits.CCP2IF && PIE2bits.CCP2IE) // CCP2 Interrupt?
		PIR2bits.CCP2IF = 0;
		CCP_2_ISR(); // call the CCP2 ISR (in accel.c)
	else if (INTCONbits.RBIF && INTCONbits.RBIE) // external interrupts 3 through 6?
		//Port_B = PORTB; // remove the "mismatch condition" by reading port b
		INTCONbits.RBIF = 0; // clear the interrupt flag [89]
		EncoderTask(PORTB);
	else if (PIR1bits.RCIF && PIE1bits.RCIE) // rx2 interrupt?
		Rx_2_Int_Handler(); // call the rx2 interrupt handler (in serial_ports.c)
		#endif
	else if (PIR1bits.TXIF && PIE1bits.TXIE) // tx2 interrupt?
		Tx_2_Int_Handler(); // call the tx2 interrupt handler (in serial_ports.c)
		#endif
those 3 files together should at least put out a printf string but as i said it hangs. all i'm doing is connecting the demo boar dserial port straight to my copmuters serial port, nothing fancy going on there. so jsut wondering if there's somehting obvious i missed in the code
thanks
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
TTL Serial Port and PS2 Mouse Interface cbolin Electrical 8 29-12-2004 15:00
Using the TTL port Max Lobovsky Programming 6 25-06-2004 12:44
