Go to Post However, the best responses come with patience. It might be a couple of days before you get a good answer or it could be 10 minutes. - Molten [more]
Unread 09-07-2005, 12:41
Dick Linn's Avatar
no team (Synergy)
Re: Smaller Cheaper Robots
cHECK OUT
www.sozbots.com/
http://cws.gateway.tec.wi.us/program...h/sumobots.htm
AND
http://www.parallax.com/html_pages/r...comparison.asp
AND i JUST FOUND THIS LIST OF DIFFERENT ROBOTICS-RELATED COMPETITIONS:
http://robots.net/rcfaq.html
And there's BattlebotsIQ http://www.battlebotsiq.com/
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 09-07-2005, 13:05
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
Lightbulb Re: Smaller Cheaper Robots
Try micro mouse competitions. They use a "neural net" so theres no programming required. I've competed when i was younger and it's actually quite fun, but if you really wanna go overboard some guys use ultrasonic sensors and stuff. Another cool competition is Beam drag racing. I've built 2, accept for a capacitor array for the motor and solar panel, there aren't any electronics. If you want a guide i suggest the book "junkbots, bugbots, and bots on wheels", the first couple of chapters are for people who have never soldered or don't know how to use transistors, capacitors, etc. but it gives you many schematics and instructions for Beam robots. It gives detailed instructions for mini sumo, solar rollers, bicore headbots, etc. Who knows maybe we can even have mini competitions at regionals and at the nationals. O and about sozbots, I'm building a robo-one robot and so far I've spent about 400-500 dollars, but thats nothing to what sozbots are charging for their khr-1 kit ($1,650). So if anyone is planning on competing in Robo one, i suggest that you build your own.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 11-07-2005, 11:26
Originally Posted by [527]phil
Try micro mouse competitions. They use a "neural net" so theres no programming required...
A lab technician I knew about 15 years ago inisisted that his favorite programming language was solder.
Unread 11-07-2005, 18:48
[527]phil's Avatar
Alumni
AKA: Phil
ROFL!! I'll use Solder over anything out there now. theres always a mechanical way to make things. Like the "night rider" LED thing i made for my team's robot. It was pretty much a servo which turned a metal arm which came into contact with metal pins which completed a circuit, and then turned on a certain LED. No relays or circuit boards necessary.
Unread 13-07-2005, 06:13
MikeJ675's Avatar
MikeJ675 MikeJ675 is offline
Near Chaos Robotics
AKA: Mike Jeffries
no team (Near Chaos Robotics)
MikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to all
Send a message via AIM to MikeJ675
Smaller robots can be really fun. Here's a 1lb combat bot I'm making for the RoboNexus expo in October.
It uses 60:1 copal gearmotors ran at 14.8v off of two LiPoly packs in series, and a micro reciever from The Robot Marketplace
The speed control is an Ant-100 from Barello.net
The chassis is a milled block of UHMW
The tires are from a local Slotcar Track
Beyond that, all you need is a transmitter(75mhz, normally) and it's ready to go.
Note: this was milled on a mill from harborfrieght, and all the dimensions were figured out on the spot, so it is a bit sloppy, but perfectly fine for it's purpose
Team 675-Alumni
Near Chaos Robotics
Unread 13-07-2005, 08:45
[527]phil's Avatar
Alumni
AKA: Phil
Hmmm, i wish there was a robotics convention in NY. Robonexus is just too far away to go to.
Unread 18-07-2005, 12:14
MikeJ675's Avatar
Near Chaos Robotics
AKA: Mike Jeffries
Bit of a follow up on my last post, here's the thing in action, but with one dead motor.
Angry Little Person drivetest
Team 675-Alumni
Near Chaos Robotics
coolest robots Solace General Forum 92 14-06-2004 13:18
Robots compete in first match (FitN) Clark Gilbert FIRST In the News... 0 24-03-2004 18:11
Robots prepped for competition Brandon Martus FIRST In the News... 0 24-03-2004 17:06
How are robots lowered? Yan Wang Rules/Strategy 5 22-02-2004 22:10
Smaller robots patrickrd General Forum 23 14-09-2001 16:25
