Go to Post For what it's worth, while they may or may not be legal as safety glasses, Steampunk goggles are perfectly legal as forehead protectors. - Nuttyman54 [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 09-07-2005, 16:26
Ron Ron is offline
Ron is an unknown quantity at this point
PartitionMagic 7 vs Sony Vaio
I am unable to get back into the Windows xp Home Edidion on my Sony PCV-MXS20 computer after using PartitionMagic 7 and trying to remove the partition between drives C and D. My bootup disk will not work nor will the PartitionMagic Rescue Disk. The only option I presently seem to have is to use my Sony System Recovery disk which will erase some of my important files.
Am I doomed?
Ron
Unread 09-07-2005, 16:47
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Re: PartitionMagic 7 vs Sony Vaio
Before doing that, see if anyone you know has an External Hard Drive Enclosure. If the data on there is worth around $20 to you, buy one from NewEgg.com. With it you can remove the hard drive and plug it in via USB to another computer, copy out your data, and then reformat the hard drive.
Perhaps someone else may know a way around your problem, but if you are at the last resort stage, consider the enclosure to recover important data.
Most likely something involved with acutally booting Windows got screwed up and not the file structure. If this is the case, data should be recoverable.
Unread 09-07-2005, 19:43
Bharat Nain's Avatar
The exact same thing happen to me, but luckily I backed up my data just before I did that. Try using one of the bootable Linux CDs to backup the important files onto a CD or something.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Sony PSP, who's getting one? bombadier337 Chit-Chat 19 15-06-2005 14:53
Sony Vaio Laptops? J Flex 188 Chit-Chat 25 27-01-2004 11:45
