Go to Post Using my Little Orphan Annie Secret Decoder Ring, I have determined that the game hint reads: "Be sure to drink your Ovaltine" - Jill_ls101 [more]
Unread 11-07-2005, 14:35
ImmortalAres ImmortalAres is offline
ImmortalAres is an unknown quantity at this point
integer division
the following is part of kevins accelerometer code
#include "p18f452.h"
#include "accel.h"
unsigned int X_Axis_Total_Period = 2/1000; // x-axis total cycle time (T2 in the data sheet)
unsigned int X_Axis_Pulse_Period = 0; // x-axis amount of time the pulse is high (T1 in the data sheet)
unsigned int Y_Axis_Total_Period = 2/1000; // y-axis total cycle time (T2 in the data sheet)
unsigned int Y_Axis_Pulse_Period = 0; // y-axis amount of time the pulse is high (T1 in the data sheet)
my debugger says it loops in a file called 16 bit integer division leading me to think that it hangs on the 2/1000 definition of t2
any ideas?
Unread 11-07-2005, 15:01
Electrical Engineer
Rookie Year: 1995
Re: integer division
#include "accel.h"
any ideas?
Integer division: 2/1000 is equal to 0
In fact, 999/1000 = 0 unless your math routine does rounding...
Mike Betts
As easy as 355/113...
Unread 11-07-2005, 16:12
lovely
how do the programmers in FIRST usually get around things like that
(how do they express not whole numbers)
Unread 11-07-2005, 17:00
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Umm, you're wrong. In my original code I initialize X_Axis_Total_Period and Y_Axis_Total_Period to zero.
-Kevin
Kevin Watson
http://kevin.org
Unread 11-07-2005, 20:54
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
lovely
The easiest way would be to use floating point numbers. The more efficient way (because floating point takes more processor instructions) would be to multiply everything by some factor of 10. ie, your 2/1000 would be 2 if you multiplied everything that uses that number by 1000.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 11-07-2005, 21:19
FRC #2429
This is precisely how the code works. Those variables aren't in units of seconds, but in timer ticks. Each tick counts as 100 ns of elapsed time.
-Kevin
Kevin Watson
http://kevin.org
The awesome NON-INVITE FANTASY FIRST Draft Tim Delles Fantasy FIRST 73 29-04-2005 08:25
IRI popularity index Joe Ross Fantasy FIRST 5 03-07-2004 12:36
Fantasy FIRST Battlecry Division 3 Joe Ross Fantasy FIRST 76 23-06-2004 11:00
FF CW Division #2 Joshua May Fantasy FIRST 46 08-06-2004 00:45
Fantasy FIRST BtB, division #3 SilverStar Fantasy FIRST 46 21-05-2004 21:50
