Go to Post You don't need to be on a team to be involved with FIRST. - Koko Ed [more]
Unread 11-07-2005, 17:14
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Re: Lawnmower Engine Starting Tips??
Ok, I have an Update and a question
Do you know how a spark plug wire is constructed? (whether it has a 2 wires for + and - or just one wire)
The reason why I am asking is because on the older mower I have the following issue:
Problem: I cannot turn the mower off when I release the brake handle the mower continues to run
Cause: The Brake is worn out ( i mean after almost 15 + yrs I would be worn out to) and the Engine Zone Cable is stretched (Attaches one end at the brake and the other end to the handle)
I have bought the newer model parts and did a pre-assembly and found that the Engine Zone Cable is to long and the brake even though can be installed the same way is made for right side mounting only where as its a left mount currently installed.
What I am attempting to do is to make / attach either a dip switch or a standard house holdlight switch spliced between the starter and the spark plug - what this will do is when i flick the switch it will cut the power going to the spark plug and turn the motor off.
So if any of you happen to know alot about cars or mowers or spark plugs in general any and all help is appreciated b/c at this current moment the mower cannot be operated safely with out a way to turn it off.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Weedwhacker Engine Project sanddrag Technical Discussion 9 25-02-2005 23:58
Travel Tips KathieK General Forum 5 13-12-2004 12:47
post your Chairman's Award tips Ryan Foley Chairman's Award 3 31-08-2003 22:54
I need tips on Starting a New Team. Rook Starting New Teams 6 25-03-2003 11:19
advice on starting a team.. archiver 2001 1 24-06-2002 03:20
