Go to Post Breaking a rule just because you think it is meant to be broken is not good advice. - Andy Baker [more]
View Poll Results: Which method of revolution counting is the best?
Encoders 23 79.31%
Hall Effect Sensors 1 3.45%
Banner Optical Sensors 5 17.24%
Other (please explain) 0 0%
Voters: 29. You may not vote on this poll
Unread 14-06-2005, 09:03
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Encoders vs. Hall Effect vs. Banner Sensors
After seeing some of the ideas people gave me in this thread, I decided to post a poll. Which do you feel works best for counting wheel revolutions: shaft encoders, hall effect sensors, or the Banner optical sensors (with some kind of pattern on the wheel)? If you could post your reasons why, too, I would appreciate it. Thanks!
Jeff Waegelin
Unread 14-06-2005, 09:28
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
Re: Encoders vs. Hall Effect vs. Banner Sensors
We used encoders on our robot because they were easier to use/install/program and seemed to give better results than the standard Hall Effect sensors in the kit.
Unread 14-06-2005, 10:39
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
We used our own quadrature hall-effects, but we wished we hadn't. The resolution wasn't good enough, and the counts were limited by the number of magnets we could squeeze into the wheel without cancelling the net charge.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 14-06-2005, 11:39
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Our solution may be a little bit of overkill, but it worked very well.
We used 64 pulse Bourn Optical Ecoders geared about 6:1 to the wheel speed. We wired these into a custome circuit box that had 2 COTS chips. I can get the technical details if anyone wants them. I'm a mechanical guy so I don't know myself. I do know that the first chip took the quadrature signals and turned them into one pulsetrain at 4 times the frequency and a digital signal for forward or reverse. The 4 times frequency pulsetrain was then sent into another chip that was an digital to analog converter. We read the analog output from that chip into the RC as wheel speed. No interupts required.
Matt B.
Unread 12-07-2005, 22:28
Umm Errr...
if you search there have been NUMEROUS threads on this issue
1139 Alumni
Unread 12-07-2005, 22:51
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
i like optical sensors bcuase they are easy and less likely to generate errors like the hall effects
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 03-08-2005, 01:16
John Wanninger's Avatar
John Wanninger John Wanninger is offline
FRC #1732 (Hilltoppers)
John Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond repute
Has anyone checked out the VEX pamphlets lying around their local Radio Shack? According to the brochures, among the inexpensive new sensors coming out for their VEX robots wil be a 100 pulse/rev optical encoder(#276-2156) good for up to 1020 rpm, or about 1700 pulses/sec. While 100 ppr isn't great, it should be good for 1/8" resolution even on the fastest robots if geared correctly. At $20 for a pack of 2, they're certainly worth a look. They have some other interesting sensors (ultrasonic, line follower kit, etc.) as well. (No, I don't work there, but as a kid, all my paper route money ended up there! )
"A hundred times every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving..."
--Albert Einstein
2001: FLL852 |2002: FLL20/FLL21 |2003: FLL23/FLL25 |2004: FLL14/FLL16 |2005: FVC22/FLL124 |2006: FLL3/FLL2986/FVC22/FRC1732 |2007:FLL3/FLL34/FLL56/FRC1732
2008: FLL3/FLL18/FRC1732 |2009: FLL101/FLL8963/FRC1732 ...(etc.!)
Unread 03-08-2005, 10:55
Hutch Hutch is offline
NOTAG
Hutch will become famous soon enoughHutch will become famous soon enough
We used rotary encoders, and they worked... They were just a PAIN. I definitely would say that you should try to avoid having to count rotations in general (linear accelerometer anyone?) but rotary encoders are probably a good bet if you need to.
Encoder code with hall effect sensors help brownster Programming 10 19-02-2005 09:23
How to program Hall Effect sensors. chantilly_team Programming 1 17-02-2005 14:08
Hall Effect Sensors GAT-X105 STRIKE Programming 2 15-02-2005 23:25
Accelerometer and hall effect sensors brownster Programming 1 13-02-2005 13:36
Where to place Hall Effect Sensors. Moloch Electrical 10 11-02-2005 16:47
