Go to Post Grease your gearboxes folks! Gears need grease, otherwise they kerplode. - s_forbes [more]
Unread 13-07-2005, 14:40
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
capacitors on motors
i dont know if t his should be here or not but when ever i see a motor from a r/c car it has a couples of capacitors between the leads on the motor, and i was wonder what is the purpose of them?
Unread 13-07-2005, 15:02
Quatitos Quatitos is offline
lysdexic taquitos
AKA: Bill
FRC #0279 (Tech Fusion)
Quatitos has a spectacular aura aboutQuatitos has a spectacular aura about
Send a message via AIM to Quatitos
Re: capacitors on motors
Capacitors are usually used in dc motors to try and smooth out electrical "noise" created by the motors. This noise, if not smoothed out by the capacitors, could cause some of the other electronics hooked up to malfunction.
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 GLR Champs
2001 National Champs
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I believe that is a fair question.
Those little caps perform a very specific function, one that is important in the environment that those motors are used. They are filters. Their purpose is to suppress, or at least reduce, high frequency noise and RF interference generated by the making and breaking of the connections between the brushes and armature.
Considering that these are used on Radio Controlled vehicles, this is a good thing.
Unread 13-07-2005, 20:54
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
they also can be used to cover over momentary power drains in your system (like i used a camera and there were power drops but the capacitor covered it right up). speaking of which can WE use capacitors to smooth out noise
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 26-07-2005, 13:36
Hutch Hutch is offline
NOTAG
Hutch will become famous soon enoughHutch will become famous soon enough
Definitely - my team did it this past year because our rotary encoders were being stupid. They are also good for digital logic circuits (gate state changes can cause big current drops).
Unread 26-07-2005, 18:42
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
and they are also used in flashes in cameras
Important for pretty much everything really....
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 26-07-2005, 19:19
Andy A. Andy A. is offline
Getting old
FRC #0095
I am not entirely sure as to the legality of using capacitors on motors, since that could be construed as modifying an electrical component. My gut reaction is no, it is not legal.
Nor is it really necessary. Most of our motors probably already have capacitors mounted inside the case. Besides that, the Victors undoubtedly prevent any back emf from leaking into the rest of the bot, and unless the radio is right next to a badly arcing motor the radio noise produced won't be enough to interfere with the link. Motors can, and do interfere with sensors. But, capacitors probably won't cure your problem. It's much more effective to shield the sensor and/or move it away from the motor.
Also, the capacitors on motors will not in fact help with momentary power drops. Typically, the capacitors are in the range of .1 micro farads. Thats very, very tiny, not enough to even make a big motor twitch. It is possible to use capacitors that way, but it wouldn't be useful to us, nor legal.
The capacitors are important on R/C cars because the radios are A: relatively cheap AM/FM deals, and B: Are inches away from a motor that is designed to be powerful, not polite. On top of that, many motor manufactures never bothered to solder their own capacitors on, so it was up to the hobbyist. Thats changing though, and most motors now ship with presolderd caps.
-Andy A.
Unread 26-07-2005, 21:08
you misunderstand me not to power the motors to power sensors!
Unread 26-07-2005, 23:06
NOTAG
Yeah, when I said yes I was talking custom circuitry and sensors and the such - on motors it's completely unnecessary.
Drill Motors Removed? Illegal this year? Chris_Elston Motors 12 12-01-2005 09:04
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
