Go to Post You definitely know you've overdosed on first when you wash the aluminum shavings off your hands AFTER you eat dinner. - Maxpower57 [more]
Unread 30-06-2005, 09:20
Andy Brockway Andy Brockway is online now
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: Drive-train shaft size
The IGUS bearings can stand quite a bit of abuse. We use them in many applications in my facility. The majority are used for linear motion in vertical and horizontal slides.
We use the G300 series with little wear on equipment that runs 24/7. We do not lube them as this picks up particles that then contribute to drag.
We have also experimented with the L1 in a vertical slide mechanism. Currently we have three years with no significant wear.
It is important that the bores for these bearings match the catalog. This provides the proper clearance for the shaft. This one of the reasons we have not installed any in our robots. You cannot produce those tolerances on a drill press : )
Read the recommendations carefully. Our experience concurs that a shaft without a high polish is best. We have shifted from Thomson ground shafting to stainless shafting with standard grind. The bearing has an initial wear that embeds its material into the shaft and that this increases longevity and reduces friction.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 06-07-2005, 13:46
Tom Miller Tom Miller is offline
Tom Miller is an unknown quantity at this point
Thumbs up Re: Drive-train shaft size
I've had great success in the past attaching sprockets to shafts using a keyless locking device known as a TranTorque Keyless Bushing. I've found them in MSC and they are produced by a company called Fenner Drives (www.FennerIndustrial.com)
The cool thing about them is that you don't need a keyway or setscrew and they come in a whole range of sizes in both english and metric. I think the smallest I saw they make fits an 1/8" shaft, but they go all the way up to something like a 3" shaft or so.
Just a thought...???
Unread 09-07-2005, 12:16
Dick Linn's Avatar
no team (Synergy)
Anyone have a good source for pillow block bearings with aluminum housings? Especially an economical one. Seem that most common ones have cast iron housings. Hopefully now that I'm setting up a lathe I can make my own bearing blocks, but sometimes it's less hassle to buy.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 09-07-2005, 17:35
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
One thing to take into consideration when looking at shaft selection is the support of the shaft. If your shaft-wheel is out there with no protection you'd better beef it right up. When you use a "protected" shaft(has two bearings/bushings/etc. on the two opposite sides of the wheel) you have to consider two things, the lenght of the shaft and the weight of the robot. The shorter the shaft the less flexx theyre will be and the smaller diameter you can get away. The longer that shaft gets the larger diameter you need to use to prevent the shaft from flexing/bending.
Another thing to consider is the material that the shaft is made out of. Aluminum would need to be a considerably thicker shaft than a steel shaft.
-Hope thats helpful and good luck
Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 09-07-2005, 21:43
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Here's the only ones I've found.
http://www.cncbotparts.com/bearing_blocks.htm
http://www.teamdelta.com/products/prod5.htm
Have you considered stamped steel ones like this http://robotcombat.com/images/drives...wblock2_lg.jpg instead of cast iron ones?
Also, I don't believe pillow blocks are made on a lathe, a mill would be more like it, and a CNC one if you would like to get fancy.
EDIT, omg CD censors your username when I quote you. lol
Unread 09-07-2005, 22:16
Gdeaver Gdeaver is online now
FRC #1640
Grainger and McMaster-Carr. Allot of times they are listed as die cast frame. Bronze bearings are more common but there are die cast ball bearing units. Stamped steel frames and flanges are also light. There are composite units that are extremely strong and light but the price is high.
In 2004 I bought some fiberglass rods in 1/2", 5/8", and 3/4" dia. to evaluate as shafts. Very strong and light. Just a slight deflection under impact. Our team decided against them but, I am certain they would have worked fine and the weight savings is substantial.
Unread 09-07-2005, 22:37
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
One problem with fiberglass shafts is that you really shouldnt make any cuts into them, only cut them lengthwise. If you are just running a wheel with bearings in the wheel and pillow blocks, sure. But if you want to cut a keyway into the fiberglass, you seriously weaken its strength. Fiberglass relies on the continuous glass fibers in it for its strength. If you cut the fibers, they lose their strength. If you can get a company to form the fiberglass into a keyed shaft, that would work very well. But... no cutting!
Unread 10-07-2005, 02:38
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Drive-train shaft size
How big should a drive shaft be on a FIRST Robot?
I think that this is an excellent question, since every robot I can think of is using wheels of some sort to carry it’s load. Unfortunately, of all the answers I’ve seen, I haven’t seen any math involved. Some students get inspired by seeing numbers (I know I did) so... here are some numbers.
Assumptions
To first quantify this question, you need to make a number of assumptions. I’ll try to go ahead and make some assumptions, and hopefully we’ll see if we can understand why some of these sizes that have been mentioned are okay, why some are too large, and why some might be a bit too small.
There are a number of considerations that need to be addressed, some that immediately come to mind are the following:
  • Will fatigue be a factor?
  • What is the typical load on the shaft?
  • What is the maximum torque transmitted by the shaft?
  • What will the maximum load on the shaft be?
The above questions all need to be addressed to answer the quetsion.
This is an interesting question. I’m going to say that from experience, a FIRST robot won’t see more than 10 hours of continuous run time. Assuming that the robot runs around on average at 2 ft/s with 6” diameter wheels, that gives us a life time of 72,000 feet traveled, or about 46,000 cycles (revolutions). In the scheme of steel shaft, I’m personally not too terribly worried about that, but it’s not negiligble. Whereas you should begin to start designing for infinite life around a million completely reversed bending cycles, depending on the assumptions you make above, you could possibly reach 100,000 cycles pretty quickly. Since there is actually a logarithmic relationship, 100,000 cycles is a lot closer to a million than to a static loading case. Whereas for inifinite life (million cycles+) you’d treat the allowable bending strength around 50.4% of the ultimate strength, I’d say in a situation like this, you’re going to not give a lot more leverage than say 70% the ultimate strength. What this means, in short, is that fatigue should probably be somewhat considered in situations where robots are heavily practiced with and demonstrated.
What are the forces on the shaft?
One should probably consider the average load of a full capacity robot, (read: holding maximum number of playing field objects).
Let’s assume that on the average game this is a nice round 150 pounds, and there’s a slight bias to one particular wheel of 33% of the weight of the robot. This would put a load of roughly 50 pounds on one shaft.
One often neglected factor is the fact that something is driving the shaft, and often times, this is a sprocket. For the sake of this sample calculation, we can probably assume that the sprocket is pulling in the orthogonal direction. This may actually be slightly less than conservative, but I’ll hope you’ll forgive me.
In a full fledged pushing match, assuming some super sticky tires with a coefficient of friction around 1.2, the chain will be pulling with roughly 60 lbs of force.
Also, you’ll have some torque about the shaft, equal to the 60 lbs times the radius of the wheel, and assuming a 6 inch diameter wheel, that’s 180 inch lbs of torque.
To sort of simplify some things, the critical elements, because the weight and chain pulling forces are orthogonal, are at the extreme fibers in perpendicular directions. Hence, you wouldn’t want to combine these force vectors, or you would get a critical element with bending stress that is higher than it actually is.
Because these stresses are in directions that are orthogonal (that is, the torsion is causing stress in the direction perpendicular to that of the robot weight on the shaft and the force the sprocket is pulling on the shaft) you need to combine these forces to get the total stress. Fortunately, you can combine these using von Mises or von Mises-Hencky theory, which is essentially just using distortion-energy theory.
It should be noted that this is not a particularly conservative estimate, so it should bring some answers to our question that can be somewhat reliable.
For those of you unfamiliar with von Mises, for a plane stress, it is essentially:
TotalStress = SQRT(stressX² + stressX*stressY + stressY² + 3*Torsion²)
In our case, we only have 1 stress in the bending direction, it simplifies to:
TotalStress = SQRT(stressX² + 3*Torsion²)
Now there are a few more questions to ask:
Where is the shaft loaded?
How long is the shaft?
How is the shaft supported?
Is the shaft notched?
What is the shaft material?
How does that whole fatigue thing come into play?
I’ll answer these with the following assumptions:
I’ll assume that the shaft is loaded in the center, which is a conservative assumption.
I’m going to assume a typical FIRST robot has an inside shafts length of 5” long.
I’ll assume the shaft is supported by fixed bearings on either end.
I’ll also say that the ends will be turned down to fit into some bearing blocks, but with some pretty sharp edges because a lot of teams don’t have the tooling to put good round corners in. (Stress concentration factor ~2)
Let’s do a steel shaft, say just like McMaster-Carr keyed shaft, of ANSI 1045 with a Rockwell Hardness (B Scale) of about 90. That hardness translates over to about 91 kpsi from a chart that I found here: http://www.gordonengland.co.uk/hardn...version_1c.htm
In a textbook I have (Mechanical Engineering Design, 8th edition, Shigley et al) it actually places the ultimate tensile strength of 1045 steel at exactly 91 kpsi, so I feel comfortable also using it’s yield strength of 77 kpsi for calculations involving static (or nearly static) loading.
Up above I said that we ought to use a working strength of about 70% of the ultimate strength when we do design for fatigue, which means I’d use about 63 kpsi.
What I haven’t done very well so far is explain that I’m going to be determining basically 3 calculations:
  • The size of the shaft to support maximum static loads
  • The size of the shaft to withstand the fatigue of reversible bending cycles.
  • The size of the keyway that is needed in the shaft to ensure the wheel or sprocket stays in place.
The first calculation for a maximum total stress due to chain pull (60 lbs) involves the following calculations:
Bending Stress:
D = Diameter of shaft
Z = Section Modulus (Moment of inertia I over extreme fiber distance y (y = D/2)
L = length of shaft
F = force on shaft
My Machinery’s handbook tells me:
Z for a round shaft = pi * D³ / 32
Stress at extremes ends, center = (F * L) / (8 * Z) = (4 * F * L) / (pi * D³)
Torsional Stress
T = Torque applied
R= Radius of shaft
J = polar moment of inertia (for a round shaft, D^4/32)
Torsion = T * R / J
Now, I started to cheat and did some work in excel.
Here’s the numbers:
Wheel Diameter 6.00 in
Shaft Length 5.00 in
Allowable Stress 77,000 lbs / in²
Weight of Robot (max) 150 lbs
% Weight on Wheel (max) 33.3%
Coefficient of Friction 1.2
Shaft Load 60.0 lbs
Moment of Inertia 0.000192 in^4
Section Modulus 0.00153 in³
Modulus of Elasticity 30,000,000 psi
Shaft Estimated Max Stress 24,444 psi
Shaft Estimated Max Torsion 58,665 psi
von Mises 177,684 psi
Shaft Diameter 1/4 in
Shaft Deflection 0.007 in
Deflection as percent of length 0.14%
Factor of Safety 0.43
Key Width 3/32 in
Key Length 1/2 in
Key Allowable Torsion 45,000 psi
Key Applied Stress 30,717 psi
Key Factor of Safety 1.46
Shaft Load 60.0 lbs
Moment of Inertia 0.000971 in^4
Section Modulus 0.00518 in³
Shaft Estimated Max Stress 7,243 psi
Shaft Estimated Max Torsion 17,382 psi
von Mises 52,647 psi
Shaft Diameter 3/8 in
Shaft Deflection 0.001 in
Deflection as percent of length 0.03%
Key Width 3/32 in
Key Length 1/2 in
Key Applied Stress 20,478 psi
Key Factor of Safety 2.20
Shaft Load 60.0 lbs
Moment of Inertia 0.003068 in^4
Section Modulus 0.01227 in³
Shaft Estimated Max Stress 3,055 psi
Shaft Estimated Max Torsion 7,333 psi
von Mises 22,211 psi
Shaft Diameter 1/2 in
Shaft Deflection 0.000 in
Deflection as percent of length 0.01%
Factor of Safety 3.47
Key Width 1/8 in
Key Length 1/2 in
Key Applied Stress 11,519 psi
Key Factor of Safety 3.91
Now, there were a lot of assumptions made, but I think that this sort of tells the story pretty well in terms of what the shaft diameter needs to be in order to be reliable.
I’m not going to paste the numbers for fatigue, but the short story is that when you be more realistic about the loading for fatigue conditions (less weight and more evenly distributed) it sort of cancels out the slightly lower allowable stress, .
When I look at these numbers,and then consider the real world factors of roughness that tends to occur (setting the robot down too rough, flipping, etc) my humble opinion is that half inch shaft is probably a pretty safe bet, and three eights isn’t terribly risky either.
Keyway Calculations:
It should also be noted that if you choose to use a keyway, calculating their strength is important as well. If you decide to use some super strong keys, they’ll have an ultimate tensile strength of around 90,000 psi, (and a shear strength of roughly half that). If you assume that you have a 3/32 keyway for less than a half inch shaft and a 1/8 inch keyway for over a half inch, you can do some calculations in this respect as well, which I did in the colored text above.
Basically, you find the torque on the wheel, divide it by the radius of the shaft and divide that force by the area of your keyway. That will be the shear stress on your key. If the shear stress is less than the shear strength, you’re good to go.
I hope that this helps answer your questions. I've attached the quick spreadsheet for those who want to play along or check my quick math.
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 13-07-2005, 01:59
wilshire's Avatar
wilshire wilshire is offline
OSNAP. a gear flew out of the robot
wilshire is just really nicewilshire is just really nicewilshire is just really nicewilshire is just really nice
Send a message via AIM to wilshire
yeah Matt busted out some crazy ME skills there and back in January during the begining stages of our drivetrain. It really did inspire me to get more involved knowing that i had numerical data and formulas there to back those numbers up.
AIM: wilshire461
Purdue FIRST Teams
Team 461 -http://www.boilerinvasion.org/
Team 1646 - http://www.precisionguessworks.org/
Team 1747 - www.harrisonboilerrobotics.org
Unread 14-07-2005, 01:38
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
Matt: What about the movement of the bearing blocks and the subsequent additional "cantilever" effect (that's EE speak for something that seems to be mechanically bad)?
Unread 15-07-2005, 00:29
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
Question Re: Drive-train shaft size
Could you describe in more detail what you're refering to? What do you mean by movement of the bearing blocks? I've assumed that they are fixed in my calculations here.
Mayhaps some mad MS paint skillz to clarify?
Matt
Unread 15-07-2005, 00:33
AKA: aXvXiA
Matt
I'm thinking about when a bearing block shifts in its channel, causing the shaft to no longer be perpendicular to the bearings, etc.
Unread 27-07-2005, 15:41
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
Arrow Re: Drive-train shaft size
To cut a long story short, this won't affect the shaft and it's life nearly as much as it will affect the life of the bearings. Bearings are much more sensitive to misalignment, and will cause your bearings to fail well before you'd worry about your shaft life.
Sorry it took me so long to reply,
Matt
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
229 Drive Train Adrienne E. Robot Showcase 32 09-09-2005 21:51
pic: Tribotec Brazil - Drive Train tribotec_ca88 Robot Showcase 5 07-02-2005 03:48
pic: A proposed drive train idea. Elgin Clock Extra Discussion 10 16-01-2005 23:29
pic: Team 980 "Thunder Bot" drive train CD47-Bot Robot Showcase 12 25-02-2003 14:02
