Go to Post For those of you that think the kit chassis is too weak... It is tough stuff. Those of you that say it is too weak, just do not know what you are talking about. - Paul Copioli [more]
Unread 16-07-2005, 09:24
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Bash: permission denied - Script error
I was just setting up a simple script to sync my project files with the ones I have stored at OSC, where I run into this error:
This happens when I run my super-simple script of: (with the working part cut out)
#!/bin/bash
# setup a couple of variables
# call to scp using the variables abover
The part which cause's the error seems to be the simple interpreter line at the top. If I run bash manually through bash <name of my file>, it works fine. If I try to run it with just ./<name of my file>, I get the permission denied error. If I run it as root (IE, sudo ./<name of my file>), it works fine.
I did check /bin/bash just for giggles and it is executable by all. What could be causing this?
Unread 16-07-2005, 14:23
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Re: Bash: permission denied - Script error
Have you made the script executable by all? If not, try
chmod 777 nameofscript.sh
Unread 16-07-2005, 14:59
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
The command chmod is needed, but 777 is always a bad idea, that gives everyone in the system full access to do whatever they want to the file. Not good chmod +x will add execution to its existing privileges, much more desirable.
chmod +x <name_of_file>
For example, if you as root create a file that does something simple, which you shouldn't do anyway but a lot of people do, and make it chmod'ed 777, any user could edit the file, and run it with root privileges via sudo, very messy.
Matt Krass
Unread 16-07-2005, 15:23
Programming User
Hm. Well, it works now. Why does it have to be world executable? (I did have it executable for me.)
Thanks!
Unread 18-07-2005, 11:52
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
What where the old permissions and what are the new ones?
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
guidelines for modifying the linker script??? gnormhurst Programming 2 06-03-2005 02:03
MPLink Error cloudago Programming 2 01-02-2005 23:00
