Re: Lawnmower Engine Starting Tips??
EAsy - Bad headgasket like I said earlier.
I don't have a torque wrench (should probably get one) but to me the bolts seemed a little loose (especially the two by the exhaust) so I tried tightening them up a bit but it didn't do anything.
I haven't been able to spend much time on this thing lately because it is only cool enough to work outside before 7 in the morning or after 8 in the evening. I still have to pull the carb off again and see if there is anything wrong (like the ball-check valve you mentioned) in the little yellow plastic fuel tubes. Maybe one of these days the weather will be cooler and it will give me break so I can work on it. I would take it to the service center but since they are the only one around here they said they are 10 weeks out ( ) on doing any repairs or service for anyone (I guess partly because they service chain saws for the forest service so they are probably very busy).So, maybe one day I can tear into this thing myself. They aren't especially complicated are they? Where do you start (or what are the basic steps) and what do I need to look out for in the disassembly process? Also, what should I be looking for that might be a sign of the trouble (besides the head gasket)? Last, I noticed that the top of the piston is very black and oily and nasty looking. Does that indicate anything? Once again, thanks to everyone for the help! |
pull the mixture screw out of the carb, check the little rubber gasket. If you ask me briggs' Vacu-jet and pulsa-jet and pulsa-prime carbs are the worst designed pieces of plastic junk that I have ever seen. Did I mention I hate them? The day that briggs starts using Mikuni Roundslide carbs is the day when all is right with the world. And should you need parts let me know my shed looks like sanford and son organized and on steroids. ![]() |
Ooooh blackness.... you're flooding it and your rings might be gone. Or it's probably just 20 years of carbon build up. Get a putty knife and scrape it off, use sand paper too but don't damage the mating surfaces. Get a can of PB Blaster and use that while cleaning it. Smells like moth balls and diesel but worth it's weight in gold.
Look down the cylinder wall if there are deep marks, don't even bother. If there are deep marks just forget it Essentially it's the second most easiest engine to fiddle with. Let me know and send some pics along of this bad larry. If you want to get deep into it I'll give ya a hand.....from waaayyyy ovah heah!! |
Well final update
I have now attached a switch that i bought from autozone and lemme tell you this 20 yr old mower purrs like a kitten and turns off perfectly when i turn the switch on =) thanks for all tips guys |
| Weedwhacker Engine Project | sanddrag | Technical Discussion | 9 | 25-02-2005 23:58 |
| Travel Tips | KathieK | General Forum | 5 | 13-12-2004 12:47 |
| post your Chairman's Award tips | Ryan Foley | Chairman's Award | 3 | 31-08-2003 22:54 |
| I need tips on Starting a New Team. | Rook | Starting New Teams | 6 | 25-03-2003 11:19 |
| advice on starting a team.. | archiver | 2001 | 1 | 24-06-2002 03:20 |
