Go to Post I enjoy the brainstorming that's going on here, you guys out think me most of the time. Keep it up. - fnsnet [more]
Unread 24-07-2001, 19:46
mpking's Avatar
mpking mpking is offline
AKA: Mike
#0088 (TJ²)
mpking is an unknown quantity at this point
Send a message via AIM to mpking
Question Web Page Help
Ok, I've bashed my head for the last few hours.
I'm trying make a simple redirect script for a web page
If your IP address begins with 207.206
goto http://this site.com
else
goto http://that.site.com
I don't care how it's occomplished (php, server config, java, javascript,etc)
It's on a apache 1.3.19 server that I have complete control over. I've spent the last couple of hours trying to do it with javascript, and everything I've come up with is Netscape only. Arrg!
Can anyone help?
Please?
Mike King
Bridgewater Raynham Regional High School
Team 88 TJ²
The Home of Moe
Unread 24-07-2001, 23:44
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
heres some php
PHP Code:
<?php
if ( strstr($REMOTE_ADDR'207.206') ) {
header ("Location: http://this.site.com");
  exit;
} else {
header ("Location: http://that.site.com");
  exit;
I didn't test it out.
Let me know if it doesnt work, and I'll fix it.
Brandon Martus
e-mail
Unread 25-07-2001, 00:02
mpking's Avatar
AKA: Mike
#0088 (TJ²)
Um?
Um, how's this work.
I'm assuming the file has to be renamed from index.html to index.php?
Never dealt with PHP before?
Originally posted by Brandon Martus
heres some php
PHP Code:
<?php
header ("Location: [url]http://this.site.com[/url]");
  exit;
} else {
header ("Location: [url]http://that.site.com[/url]");
  exit;
Mike King
Team 88 TJ²
The Home of Moe
Unread 25-07-2001, 01:08
mpking's Avatar
AKA: Mike
#0088 (TJ²)
Re: Um?
Ok, I've enabled SSI on the server, turned on XBitHack, and made the page executable.
It was halfway working, but now it's not.
by halfway I mean this.
I should have been clearer in my example.
if 207.206
https://netreg.bridgew.edu/indexresnet.html
else
https://netreg.bridgew.edu/indexall.html
I had those two locations in there, and when it was partway working, it would redirect to the httpS, but it wouldn't pick up the document.
Mike King
Team 88 TJ²
The Home of Moe
Unread 25-07-2001, 21:22
Adrian Wong Adrian Wong is offline
#0596 (SciClones)
Adrian Wong is an unknown quantity at this point
Send a message via AIM to Adrian Wong
Do you have mod_rewrite setup on your Apache server?
Unread 25-07-2001, 22:42
mpking's Avatar
AKA: Mike
#0088 (TJ²)
Solution is Found
Ok, I called in one of the programming guru's at work, and in trying to explain it to him, I hit apon the solution.
The solution that I've discovered is a combination of Javascript and SSI includes.
<noscript><meta http-equiv="refresh" content="2; URL=indexresnet.html"></noscript>
<script language="JavaScript">
var resnetsTargetURL = "https://netreg.bridgew.edu/indexresnet.html";
var allsTargetURL = "https://netreg.bridgew.edu/indexall.html";
function doRedirect()
var ip = "REMOTE_ADDR";
if (ip.indexOf("192.168") >= -1)
        setTimeout( "window.location.href = resnetsTargetURL", 2*1000 );
else
        setTimeout( "window.location.href = allsTargetURL", 2*1000 );
</script>
<script language="JavaScript1.1">
   window.location.replace( resnetsTargetURL );
else
   window.location.replace( allsTargetURL );
doRedirect();
</script>
of course the <body onload="doRedirect()"> tag is in there too.
Thanks for all your suggestions, you guys at least got me started on the right road.
Mike King
Team 88 TJ²
The Home of Moe
Unread 26-07-2001, 22:24
mpking's Avatar
AKA: Mike
#0088 (TJ²)
Ok, just a small minor update. The previous script I posted don't work.
I did a google search on SSI redirects
Came up with this script. Keep in mind this is the entire webpage.
<!--#if expr="${REMOTE_ADDR} = /192.168.10/" -->
<!--#include file="indexresnet.html" -->
<!--#else -->
<!--#include file="indexall.html" -->
<!--#endif -->
Kinda neat, eh?
The pages I want displayed are completely contained in the .html files.
Too bad no one had mentioned server side includes to me before. (they've been suppored since both browsers verion 2.0)
Mike King
Team 88 TJ²
The Home of Moe
Unread 27-07-2001, 05:11
busy.
AKA: B. Slash Kamen
oh yea
i mainly use SSI for
including files
<!--#include virtual="/file/to/include/here.html"-->
and executing cgi's
<!--#exec cgi="/cgi/date.pl"-->
forgot about the scripting capabilities.
Brandon Martus
e-mail
Unread 27-07-2001, 10:48
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Using Flash 5
You can use Flash 5 to re-direct to any file. It is simple and most people have the plug-in for it.
A web page class in converting from PBasic to C JimWright949 Programming 1 21-09-2003 19:54
an error in SoCal event result in the FIRST web page archiver 2001 0 24-06-2002 02:35
What happend to the FIRST team web page directory? archiver 2001 1 24-06-2002 01:21
Web page upgrades archiver 1999 0 23-06-2002 23:04
