Go to Post Man, what's the point of teaser videos if nobody looks closely at them. - Knufire [more]
Unread 19-07-2005, 21:04
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
robo-computer
i was look at things on the internet of how some people have built there own robot out of an old computer, and i was just wondering how to do this, like how would you program it and everything, it would be awesome to beable to do but i just dont see how they would program it and everything because of the overall complexity of the system and sub system
Unread 19-07-2005, 21:27
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: robo-computer
you think that was impressive look up white box robotics. their entire robot is literally a PC VERY well done. looks kind of like R2D2..... anyhew that is also one of the most impressive robots Ive ever seen (because of the price). sorry not exactly what you asked. you need to integrate a PC with some type of motor control board. you could do it with the FIRST board. the programming is no different.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
Re: robo-computer
We'll from what I've learned you have to use PC cards and certain ports. Check out http://www.xrobots.co.uk/modules/news/ . this guys build android style robots a few that use PC's. Also you might need to get/make a special chip that plugs into the serial port on the computer board. you also need special programs to connect to the external chips.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 19-07-2005, 21:29
Re: robo-computer
^ not necisarily you could even use a basic STAMP board and plug into a serial port.
Unread 19-07-2005, 23:16
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Re: robo-computer
Actually its not hard at all. This summer I've been retro fitting a small gas powered vehical to be controlled by an x86 PC. The PC is controlled by another PC over a wifi card. The networking stuff is kinda complex, however the parallel port is great for controlling realys and reading data from sensors like limit switches. The code for that is very simple and not hard to learn. If you are adventurous then there are pretty cool microcontrollers that can be connected to usb. Also, there are many serial options like the basic stamps. For my robot I have designed my own realys because I did'nt have the cash for Spikes. Also I am using a microcontroller that connects to the usb port that way I can connect many microcontrollers and therefore have countless sensors and motors. If you want to see code I would suggest reading the following, all of my code is in C and C++, also I am using Linux but Window$ could probably allow you to do much of the same things. All bets are off when it comes to Macs, not really but options become limited by the ports on them.
http://www.phrack.org/phrack/50/P50-11
http://www.epanorama.net/circuits/parallel_output.html
My parallel port test program(Very messy)
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 20-07-2005, 13:05
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: robo-computer
no i mean like how do they get them to run, so that you just can control it from sumthing, if you have to intergate th r/c with it or a basic stamp the only thing ur doing is making the basic stamp complex wit the comp, like do the comps has an os on them? and the programing that they have do they have to do sumthing special so when it starts(if it does have an os) to run the program, i know how to do wireless and how to interface wit stuff i mena like how do they do it programming wise?
Unread 20-07-2005, 13:34
Re: robo-computer
i cant say that i know exactly how to do it but i recomend insulating the motors from the PC if you run them on the same electrical system.
Unread 20-07-2005, 14:46
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Re: robo-computer
That is cool. What kind of gas powered vehicle?
Check this out!
Its not gas powered, but it is basically a stripped down E-maxx.
http://66.221.222.55/proddetail.asp?prod=Robot3&cat=17 (robot)
www.traxxas.com (E-maxx)
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 22-07-2005, 18:25
half geek's Avatar
half geek half geek is offline
For an extremely large value of 1/2
AKA: Greg R
None #0294 (Beach Cities Robotics)
Team Role: Student
half geek will become famous soon enough
Send a message via AIM to half geek
Re: robo-computer
http://gumstix.com
Very nifty little ARM-based, low power, and high capability things. They run linux 2.6.1, can have integrated bluetooth, comes with SSH server installed, has the capability of being a web server, and on and on.
I have never tried them, but I hear very good things.
My birthday is in November....
73 de W6DXN k
Parse this:
g r e g a ``n o s p a m" r o b i ``a t" d e v ``d o t" j a v a ``d o t" n e t
Unread 22-07-2005, 18:39
Re: robo-computer
yeah their very nice and networkable!
Unread 23-07-2005, 00:34
AKA: Alan Meekins
Re: robo-computer
Its a riding lawn mower which hopefully I can make fully autonomous by next summer.... I really hate to cut the grass on hot Virgina summer days.
Unread 23-07-2005, 02:36
Jizvonius's Avatar
Jizvonius Jizvonius is offline
AKA: Jevawn Roberts
FRC #1002 (CircuitRunners)
Jizvonius is just really niceJizvonius is just really niceJizvonius is just really niceJizvonius is just really nice
Send a message via AIM to Jizvonius
Re: robo-computer
What would you be attempting to do with this robot?
If you use a computer (laptop or desktop) for the processing and control, I would hope that it would be relatively calculation/memory intensive. (ie. autonomous nav using image processing) Otherwise the system will be very overpowered in the processing/memory department.
The only low level programming that would really have to be done is to output the control signal's for your actuators. This would reqired motor drivers which can use anything from a pwm signal to a binary number to pass values to control your actuators. As far as I know, computers do not put out pwm signals by themselves so if you were to go that route, external circuitry would be required in addition to the motor drivers. If your motor drivers were to use a pin based x-bit (x is variable) signal, they would be able to take sets of pin values from your serial port to control the motors. Either option is viable and actually just changes the clocks for your motor controllers to either a central one or separate ones.
All more complex calculations could actually use a higher level software package such as MATLab, which if I remember correctly has a serial output function of its own.
(and yes motor power supplies etc. need to be isolated from the comp which is generaly the case with good, high current motor drivers anyway)
Disclaimer: any errors in this post may be attributed to me being an ME major and not fully understanding the intricacies of magic smoke.
Jevawn Roberts
Georgia Tech Mechanical Engineering Senior
Co-Leader - GT FIRST
gtfirst@robojackets.org
1997-2007 w00t for robots!
108-132-408-832-1002
5 teams worth of head scratching
Unread 23-07-2005, 21:00
[527]phil's Avatar
Alumni
AKA: Phil
Re: robo-computer
I suggest getting the book "robot builders bonanza" it gives detailed instructions on how to use a computer as a robot brain. Your best bet is to make a 2 motor robot and control it using the printer port.
Unread 23-07-2005, 22:22
Re: robo-computer
i agree with ^. i have personally read this and its good for that however i found it really better at building from scratch and i do not do that so i only read it at the book store and never went into depth. however its still a good book. i also recommend using the joy stick port for your sensors. (however this kind of limits you )
Unread 24-07-2005, 00:17
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: robo-computer
how does the joystick port limit you, doesnt it have analog and digital inputs
Computer Horror Stories Pat McCarthy Chit-Chat 24 29-11-2005 13:46
Computer Stupidity sanddrag Chit-Chat 1 10-07-2005 17:50
Who's on FIRST: An ode to triple play Daniel Brim General Forum 8 13-04-2005 17:51
List of UTC Hartford Teams archiver 2001 3 24-06-2002 01:09
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
