Go to Post If poker is a sport, robotics is definitely a sport. - EricH [more]
Unread 20-07-2005, 19:24
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
pic: CVT drivetrain
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 20-07-2005, 19:27
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: pic: CVT drivetrain
yeah, Contiunously Variable Transmissions are great. You may want to check this white paper out, from the great team of 217. Do keep in mind its patent pending. I believe they were one of the first teams to try out a CVT, and they were very succesful with it, it's great to be able to have full horsepower at any speed.
Also, CVT's are starting to be used in cars too. The 2005 Ford Freestyle is running with a CVT transmission, pretty cool.
Unread 20-07-2005, 19:55
all right i came across this in How Stuff Works. the cool thing is that there are no specific ratio it changes how you want it to. its powered by a main motor and then the two servos (A and B) change the position of the two adjustable gears changing from a high to low ratio. note my arrows are slightly off so here's another pic
heres a link that explains more (http://auto.howstuffworks.com/cvt.htm) this type of transmission is more efficient than your standard gear change transmission. it even was in a couple cars for some time but just never got the publicity needed to make it in most cars. it has a smooth shift and you can have any gear ratio you want.
Unread 20-07-2005, 20:23
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
While the CCT was a very innovative transmission, it was not a CVT (if I remember correctly, the CCT was actually a single speed transmission for blending two motors).
Torroidal CVTs, such as the one in your pictures, were used by 190 in 2002 (and our 2003 bot was designed to use a 2nd Generation CVT, but we ran out of time). I know that plans were made available to the FIRST community at the time, but I don't know if a formal whitepaper was ever produced. I'll try to find out.
There are many other types of CVTs out there that would probably be easier to build (the toroidal transmission requires several parts that need to be done by CNC). The Freestyle that you mentioned, like most cars with CVTs, uses a chain that runs in between two sets of two conical pullies. I don't think anyone has tried this type of transmission on a FIRST robot.
Zan Hecht
Unread 20-07-2005, 20:29
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The big problem with CVT's made for FIRST is that they're horribly inefficient, and fairly complex.
I'm not sure you'd even have a reason to make one, rather than just making a auto shifting 4 speed like 33 did, other than for the coolness factor.
2001-2004: Team 100
2006-Present: Team 254
Unread 20-07-2005, 20:33
ahecht's Avatar
'Luzer'
AKA: Zan
^It's all about bragging rights, awards, and pushing the envelope, not necessarily winning or practicality.
Zan Hecht
Unread 20-07-2005, 20:42
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
What is it about inefficient design and operation that either pushes the envelope or deserves to be awarded?
--Madison--
...down at the Ozdust!
Unread 20-07-2005, 21:16
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I was talking with a team from Hawaii (368?) that made an autoshifting team 33 style 4 speed and they said as soon as it hit 2nd it went right to 3rd almost immediately after. So even 4 speeds is excessive for a traditional FIRST game.
Unread 20-07-2005, 21:25
actually a CVT is hardly ineficient all it means is nobody has created an efficient one. i once saw a race car with one... VERY COOL the car lost absolutly no RPM when shifting gears and you didnt have to wory about "shocking" your transmission when performing high speed gear shifts. the main benifit with this pertaining to FIRST is you can actually make them VERY simple (although with a few costom done parts) and you have a more complete control over a direct drive torque to speed ratio. i also looked at torque converters but they were too much of a hasle.
Unread 20-07-2005, 22:11
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
So someones read the hows things work on CV T's . While CV T's can be and are if well made more efficient then regular transmissions in order to make a efficient one many calculations are needed. Refer to Paul's white paper. Keep in mind as well that the design you have shown requires three motors or two servos and a motor if you wanted to use servos for the rotation of the inner disc's a lot to invest in one gearbox at least in my opinion. All I am saying is this is no cakewalk to produce something like this that is efficient.
I was interested so I added my comments after some research,
-Drew
team 1251
Tech tigers
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Unread 20-07-2005, 22:20
Gdeaver Gdeaver is offline
FRC #1640
Our team has had good success by following the KISS principle. We would consider a CVT a violation of the KISS principle.
Unread 20-07-2005, 23:52
santosh's Avatar
santosh santosh is offline
AKA: 2415
FRC #2415
santosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond repute
Send a message via AIM to santosh
The new Nissna Murano has one and the new Audi A4 have CVT's too. I <3 CVT's. Me and my friends were talking about the very low RPM running where as some engines get most of their power out at higher rpms. We were thinking that they could possibly move the cones on command of the driver so that the driver could control the rpm level.
We would love a CVT. We just want one that isn't entirely friction based, but still they are so awesome. Something that is dependable.
2004 - 2007 = 1002
2007 - 2011 = Founding Mentor of 2415
6 regional wins, 3 EIs, 3 Chairmans
kiddies kiddies kiddies
Unread 21-07-2005, 00:15
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
actually a CVT is hardly ineficient all it means is nobody has created an efficient one...
the problem with most current CVTs is that they're friction based, which causes losses in efficiency, and can limit the amount of power that you can put through the transmission before it slips. thats not saying that a friction based CVT is the only type of CVT; search the internet and you're bound to turn up some mechanical CVT. in fact, if you do some searching through the chiefdelphi gallery, i'm pretty confident that you'd find one (or more).
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 21-07-2005, 00:16
basically i would need a company that can make the gear to sponcer us to get these into first (i need four). even if they are given to us and counted as a tax right (i love being a nonprofit org) off it would still need to go into the budget and one of them could take up most of the budget. each gear would have to be cut from a block of aluminum. i have a way I'm sure i can run it off one servo. and what would be the point of giving up i would only be guaranteed failure. i like this design because gears are more reliable than chain. (please no personal stories it my opinion and i in no way claim it as a fact) besides a couple years back if you had said half the things we do now to anyone they would say its impractical or not even possible and yet we manage to get this far on stubbornness (and i say stubbornness because genius can only give man wings not teach him to fly). no smart retorts on that last line!
Unread 21-07-2005, 00:17
actually i planned to gear it not run it based on friction
pic: 461's Drivetrain: Dubbed "Fish &amp; Chips" Nikhil Bajaj Robot Showcase 16 23-02-2005 16:53
pic: Drivetrain Preview Nuttyman54 Extra Discussion 2 17-02-2005 21:47
pic: Team #461 Drivetrain CD47-Bot Robot Showcase 8 05-03-2003 08:07
