Go to Post Being a mentor doesn't have an age requirement. As long as you are positively influencing someone you could be called a mentor and a role model. - EricLeifermann [more]
Unread 22-07-2005, 21:15
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
In PBASIC, PWM vs PULSOUT
In PBASIC, what is the difference between PWM and PULSOUT? Which is better to use for sending signals to a speed control? If you use PWM, do you have to put a pause and a loop like when you use PULSOUT?
Unread 23-07-2005, 08:20
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: In PBASIC, PWM vs PULSOUT
Going from memory...
PWM gives a continuous set of pulses that AVERAGE the duty cycle set in the command.
PulseOut gives a single pulse of the length set in the command.
I do no think PWM will to do a good job for generating a hobbyist RC signal.
Joe J.
Team #88, TJ2
FYI about using PWM 13-16 with interrupts cabbagekid2 Programming 6 22-01-2005 00:54
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Limiting PWM in pbasic archiver 2001 4 24-06-2002 00:38
