Go to Post If it's not a sport, and it's not an art, it might as well be criminal behavior, because that's how you're going to be treated. - jasoni [more]
Unread 22-07-2005, 19:45
Andrew Blair's Avatar
FRC #0306 (CRT)
boolean problems
I'm attempting to make an I-beam, but whenever I attempt to boolean more than 1 cylinder out of my rectangle (or extruded shape) it doesn't fill in the insides of the rectangle. It just cuts a circle out of the inside of the box and thats it. help me please!!!!!
-Sir Francis Bacon
-Albert Einstein
Unread 22-07-2005, 23:21
kcy88's Avatar
kcy88 kcy88 is offline
Animator
AKA: Kevin
FRC #0075 (Roboraiders)
kcy88 is a jewel in the roughkcy88 is a jewel in the roughkcy88 is a jewel in the rough
Send a message via ICQ to kcy88 Send a message via AIM to kcy88
Re: boolean problems
Could you post a screenshot?
Team 75 - Roboraiders
Hillsborough High School Robotics
2006 Boston Regional Autodesk Visualization Award
2006 Boston Regional Engineering Inspiration Award
2006 New Jersey Regional Engineering Inspiration Award
2005 New Jersey Regional Autodesk Visualization Award
2005 Duel on the Delware champions
2005 Brunswick Eruption 4 champions
Unread 23-07-2005, 09:42
FRC #0306 (CRT)
This is what happens here. rather annoying, but i think it's because my box doesn't have enough segments.
-Sir Francis Bacon
-Albert Einstein
Unread 23-07-2005, 09:54
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
Simple solution: add a 2-sided material to the object. That will usually fix the problem.
This generally occurs because of the way you are doing the boolean. Try doing them in a different order, or grouping all the negatives into a single mesh.
Hope this helps..
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 23-07-2005, 13:06
rowe rowe is offline
Eric Rowe
FRC #1097 (Site 3 Engineering)
rowe has a spectacular aura aboutrowe has a spectacular aura about
Send a message via AIM to rowe Send a message via MSN to rowe Send a message via Yahoo to rowe
Are you using 3ds max 7? If so, there should be an option called bridge (by the extrude) on the editable poly options rollout. I tend to avoid booleans for making shapes because the are imprecise. How I would go about making your I beam would be to use the cylinder to cut -> refine the box (in the boolean options) instead of subtracting from it. Then I would convert the whole thing into a editable poly and use the bridge option to make the holes. If the cylinder doesn't come out smooth, use a polyselect modifier to select the polys in the cylinder and the smooth modifier smooth them out. Hope that helps
Eric Rowe | Alumn
Team 1097 | Site 3 Engineering
2005 Silicon Valley Regional Finalists
2005 Silicon Valley Regional Sportsmanship Award
2005 Sacramento Regional Finalists
2005 Sacramento Regional Sportsmanship Award
2004 Silicon Valley Regional Sportsmanship Award
2004 Sacramento Regional Visualization Award
2004 Sacramento Regional Engineering Inspiration Award
Unread 23-07-2005, 14:42
kcy88's Avatar
Animator
AKA: Kevin
Depending on the complexity of the object you want to put holes in, boolean can really be messy. However, if it's just putting holes in a simple rectangular cube, I'd use boolean.
Here's how:
1) Divide the polygons on each side of Operand A, the object you want holes in, so that each (in this case) cylinder will cut through a polygon and not all three cutting into one polygon. screenshot
In my scene, I selected the top and bottom edges on both side and used CONNECT to divide the polygon. Next I used Inset.
2) Create the cylinders and COPY and INSTANCE the number of cylidners you want. In my scene I set the height segment to 1 and SIDES to 20. Then, select all the cylinders and convert them to Editable Polygon. Select one of them and ATTACH the others. Now you have one object instead of three; this will create a cleaner cut in the cube.
3) Finally, select the cube and choose Boolean. Select the cylinders for your Operand B. and It should come out like this.
Another method of making holes is TESSELATING a polygon, COLLAPSING it, select the center vertex, CHAMFER it. Select the center polygon on both side and BRIDGE.
Here are some screenshots:
one
two
three
four
(ignore the three cubes below the main object )
-kevin
Unread 26-07-2005, 19:44
FRC #0306 (CRT)
Thanks guys. For what i'm doing right now, which is just working with IK, converting all the objects to an editable poly, then attaching them together & booleaning works just fine. thanks for the help. If I end up making a refined model, I may use bridge-smooth, etc.
-Sir Francis Bacon
-Albert Einstein
PC problems. . . opnickc IT / Communications 5 12-01-2005 16:53
Robot Rodeo - fixing control problems Gary Dillard Off-Season Events 7 26-10-2004 00:46
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Joystick problems archiver 2001 3 24-06-2002 02:40
