Go to Post You can either suck up a lot of oxygen, or you can contribute to our communal knowledge. The choice is yours. - dlavery [more]
Unread 23-07-2005, 18:32
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: continuously variable transmissions VERY cool concept
The usual problem with CVTs is that they are friction based. You cant make those wheels out of gears, they have to be coated in some kind of traction. This means there will always be a limit to how much torque you can run through the system. I think that is the reason why CVTs never got around in the automotive world, they can only work well on small, low power cars. They were mostly used on cars like high fuel efficiency hybrids, which have lower powers anyway. But if you want a CVT on a big ol' SUV, youre gonna run into problems.
Unread 23-07-2005, 19:20
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
This discussion should probably be continued over in this identical thread.
Zan Hecht
what teams have a variable transmissions? Greg Perkins Technical Discussion 4 06-03-2002 06:10
