Go to Post Remember kids, it's not about the speed of your drive train, it's how you use it - Michael Corsetto [more]
Unread 23-07-2005, 23:23
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Arrow the best power regulator
what is the best power regulator for 5 volts to use with TTL? I know there are some good ones in the TO-220 package but idk what ones. any ideas? links?
Unread 24-07-2005, 00:13
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: the best power regulator
Regulating down from what? You might want to check out Maxim ICs (www.maxim-ic.com) level shifters, nice stuff and they'll usually give you free samples.
Matt Krass
Unread 24-07-2005, 12:55
Electrical Engineer
Rookie Year: 1995
Without more information as to exactly what your specifications are, the 7805 is the industry standard for TTL applications.
The 7805 is made by many manufacturers. Here is National's implementation.
Mike
Mike Betts
As easy as 355/113...
Unread 25-07-2005, 14:42
Hutch Hutch is offline
NOTAG
Hutch will become famous soon enoughHutch will become famous soon enough
Ugh, sorry about the Puzzler post... Definitely left logged in and I didn't notice.
Anyhow, I'd say the best solution would be the regulator but if you don't have one, another (possibly cheaper) solution could be made with appropriately rated zener diodes.
EDIT: Found some decent diagrams and an explanation of how to do things the zener diode way, as well as how to do it with regulators (just keep hitting next slide):
http://www.mines.edu/Academic/course...t11/sld005.htm
Unread 27-07-2005, 01:30
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
down from 12 volts
Unread 27-07-2005, 02:08
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
so if i used a 12 volt in put and get +5volts as an output then what do i use as ground?
Unread 27-07-2005, 09:54
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
On a 7805, and most regulators, the grounds are tied togeather. on a TO-220 package, the metal tab is usually internally connected to the ground as well (so make sure you don't short anything out on it).
Unread 28-07-2005, 00:22
NOTAG
Yep voltage is all relative, so it's output 5 volts relative to the wire the chip's ground is attached to.
Unread 28-07-2005, 21:04
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
so i use the output ground as the input ground, and i have seen schematics of 7805's that hav non-polarized capacitors between the leads and i was wondering if those are neccessary, if they are what size should I use? and if not should i use somthing else
Unread 28-07-2005, 22:19
NOTAG
They aren't completely necessary, but they will prevent current spikes. When logic gates change states, they draw a lot of current (relatively), and the capacitors across the leads will keep the the current drawn from spiking as much.
Unread 29-07-2005, 18:48
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Yes, the caps are necessary. The stabilize the regulator and keep it from oscillating. Larger caps however, will help out with current spikes. Larger caps in addition to the small ones, not instead of.
2005 Philly #1 seeded team, highest average points, and semi-finalists
Thanks to 103 and 484 for being alliance mates.
Unread 29-07-2005, 21:37
NOTAG
Hmmm I didn't recall them being necessary. But I at least am 99% sure that you can have the large ones instead of small ones since, after all, parallel capacitors are like one bigger capacitor (hooray for narrow, worthless AP physics knowledge ).
Unread 29-07-2005, 22:17
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
so for the ground i use, do i use the same ground as what i use for the transister or the one on the part on the back?
what size caps? should it be greater than a certain size or will the supply just be more stable if i use bigger ones? what is the max size i should use? any recommendations on sizes?
and are there any other transistors that can be used the same way, i think maybe the 7804, the 7803 and 7806, i am not sure so someone please correct me
also should i use a small heat sink with it? it is required or should i used one just for insurance?
thx
-john-
Unread 30-07-2005, 01:19
The exact size of the capacitors is absolutely necessary for ensuring stability (unless you really know what you are doing). Unfortunately, the real world doesn't always work like AP Physics. The datasheet for your regulator will tell you what size capacitor and any other requirements like type (tantalum, ceramic, etc), locations, etc *.
The datasheet for the 7805/LM340 is available here: http://www.national.com/ds.cgi/LM/LM340.pdf. If the part you get is not manufactured by national, you should get the datasheet from that manufacturer. There may be a few subtle differences (not likely for the 7805, but you'll probably run across a difference in some other chip before too long).
As far as heatsinks, it depends on how much current you plan to draw and the package of the regulator. Looking at the national datasheet, at 25 degrees C, the TO-220 can dissipate about 2 watts, although for safety, lets use 1 watt. The equation for power dissipation can be approximated by Pdis~=(Vin-Vout)*Iin. Since Vin is 12v and vout is 5v, you can solve for Iin of 1/7 of an amp. Since that's Iin, your output current (Iout) could actually be 350ma. I have a feeling that's more then enough for your application.
All of the grounds should be hooked together, the ground from your source, the ground from your regulator (middle pin of the TO-220 as well as the case), and the ground of whatever the load or loads are (IE your TTL chips and anything else).
Note that I've never designed a regulator circuit (other then a bridge rectifier), so you'll be a step ahead of me. I have worked with a bunch, though.
* I've seen a person with an EE degree and several years industry experience that designed a regulator circuit that didn't quite work because he didn't follow the requirements listed in the datasheet.
Unread 30-07-2005, 02:32
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Joe,
Voltage regulators are not transformers, unfortunately. The regulation is obtained by means of power dissipation, as you pointed out. I agree I_{in} (is this LaTeX? ) is 1/7 of an amp, but Iout must be essentially the same, minus some small leakage to ground. To make 1/7 of an amp at the input become 350 mA at the output you considered that the input power is equal to the output power, as in an ideal transformer (Vin*Iin = Vout*Iout), but that contradicts your first statement about power dissipation and thus, Iout is not 350 mA.
1/7 of an amp is approximately 142 mA, which is still a good number for sparksandtabs's use (digital logic circuits).
Manoel Flores da Cunha
Brazilian Machine
Team # 383
portable controls w/o using tether halomaster69 Control System 22 16-10-2005 02:18
Operator Interface power ISSUE kacz100 Technical Discussion 11 27-02-2004 13:46
URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! kmcclary Electrical 8 10-10-2002 10:56
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
