Go to Post IRI seeks to invite the very best robots to play the FIRST game, achieving the highest level of play, while keeping in place the FIRST atmosphere. - Nathan Streeter [more]
Unread 24-07-2005, 21:01
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
Accessing paralel port
Ok so I started on a small robot that i'm going to control using an old toshiba satalite laptop. I know how to use the parallel port to hook it up. I'm trying to program it in BASIC but i don't know how to send information through the parallel port. What I DO know is that i have to send data bits, eight in total. If I send a 0 it will trigger something off, if I send a 1 it will trigger it on. But how do I send data through a particular port using BASIC language?
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 24-07-2005, 22:46
Timothy D. Ginn's Avatar
Timothy D. Ginn Timothy D. Ginn is offline
I check here maybe once a year.
Timothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to all
Send a message via ICQ to Timothy D. Ginn Send a message via AIM to Timothy D. Ginn Send a message via MSN to Timothy D. Ginn Send a message via Yahoo to Timothy D. Ginn
Re: Accessing paralel port
See: http://ourworld.compuserve.com/homep...wden/page6.htm (it's got some QBASIC code for reading from the parallel port, and does have some mention of using the OUT command for sending data rather than the INP command for reading it.
Alumni of FRC Team 1006
Former mentor of Full Lego Alchemist (FLL 5621) - Sempar School / Computing Students' Association of Queen's University
Unread 25-07-2005, 00:38
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
What's the operating system of the laptop? In DOS-based operating systems (e.g. MS-DOS 6.22, Windows 95, Windows Me) you can access the parallel port directly using the language's I/O port routines (I know, for example, that Pascal allows you to write to Port[$387] for LPT1, or to run inline assembly routines). With Windows NT-based operating systems (e.g. Windows NT 4.0, Windows 2000, Windows XP), you need to use some driver that provides the appropriate access routines—it's more difficult, but also more robust. If it's not Windows or DOS, I wouldn't know.
Try this for some information on parallel ports under a DOS-based system (in Pascal, but easy to understand).
Unread 25-07-2005, 07:56
[527]phil's Avatar
Alumni
AKA: Phil
The laptop is running windows 98 SE. But the first page helped and right now I have 6 LED's chasing each other when I let go of a micro switch.
Unread 25-07-2005, 08:01
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
This Kit from kitsrus.com (available here) uses the parallel port on a PC as a cheap "Data Acquistion"
The interesting bit for the purposes of this thread is that this document has a discussion of IO via the printer port (addresses, which pins do what, how to read from the port, how to write to it, etc.) . It has BASIC code examples (though they are specific to the particular IO box, if you know a bit about the chips used on the board, you can pretty much follow what is going on).
Good luck.
Joe J.
Team #88, TJ2
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
Questions about DNS, URL Forwarding, and Cloaking sanddrag Website Design/Showcase 7 22-10-2004 21:32
Change to Initializing Inputs and Outputs Jferrante Programming 4 07-01-2003 11:36
