Go to Post The very fact that parts are rumored to be being re-used may be sufficient reason for the rule-makers to change a rule to prevent the re-use of that very part (not that they would ever be that devious!) - dlavery [more]
Unread 26-07-2005, 22:09
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
pic: Robo-one legs
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 26-07-2005, 22:11
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: pic: Robo-one legs
I must say that this is one of the coolest project I have seen around in this forum. But I do have questions for you...
In the picture you are using 11 servos... if you are adding a body with arm and a head, you would add atleast another 5 servos. How are you planning on powering 16 servos to work the same. What kind of controllers would you use and why? Do you think you will need more than one controller? what kind of battery are you going to use? Don't you think it will weigh a lot which may cause it to tip over?
The legs look cool. Great job man.
Unread 26-07-2005, 22:21
santosh's Avatar
santosh santosh is offline
AKA: 2415
FRC #2415
santosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond repute
Send a message via AIM to santosh
That looks pretty awesome. Nice job.
2004 - 2007 = 1002
2007 - 2011 = Founding Mentor of 2415
6 regional wins, 3 EIs, 3 Chairmans
kiddies kiddies kiddies
Unread 26-07-2005, 22:24
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
very nice!
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 26-07-2005, 22:57
spears312's Avatar
spears312 spears312 is offline
El Capitan
AKA: Ryan
FRC #0312 (Heatwave)
spears312 is just really nicespears312 is just really nicespears312 is just really nicespears312 is just really nicespears312 is just really nice
Send a message via AIM to spears312
Cool. I tried something like that once (but w/ Lego's, needless to say, it never really "worked", per say). Have you given it a test yet and will it have a gyro sensor to detect and compensate for balance? It really want to see this thing walk!
HEATWAVE 312
2004 FL Regional Chairman's Award Winners
2005 UCF & Palmetto Team Spirit Award Winners
2005 Championship Curie Division Semi - Finnalists (thx to 118 and 229)
FIRST
Under Construction
Unread 26-07-2005, 23:04
http://www.etek.chalmers.se/~almir/ this is also pretty cool and very similiar. i highly recomend the movie.
Unread 26-07-2005, 23:26
AKA: Ari
That is one cool robot. Definitely check out the video. It's one of the very intelligent robot I have encountered in my FIRST career. After watching the video all I could think or say was "I wanna make one of those."
Unread 27-07-2005, 09:33
[527]phil's Avatar
Alumni
AKA: Phil
We'll I've already tested it and it walks fine. I'm using a lynxmotion BASIC atom pro 24 pin module and their mini Atom bot board. I'm going to have to purchase their servo controller though because I need to control (ready for this) 19 servos. I didn't really design it to walk up stairs but it can. And I'm not using any gyros (yet), it just takes about 400,000,000,000,000,000 tries before I get the servo placements and timings right so it doesn't fall over. I plan on putting up a video of it walking, but first I have to program it. If you plan on building something like this DON"T but the BASIC atom pro + bot board, it can control 20 servos, but only 1 at a time. So lets say i want the legs to crouch and both motors need to move an equivalent of lets say 800, I have to divide it by a big number and then move each one back and forth.
IE.
SERVO 1, 5
SERVO 2, 5
SERVO 1, 5
SERVO 2, 5
etc.
O, and for the batteries, I'm just using a 9 volt battery because the BASIC atom board can take up to 9 volts and convert it to 5 volts for the micro controller and the servos.
Unread 27-07-2005, 18:29
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Ive seen videos of these kinda robots they are really impressive to watch move.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 27-07-2005, 18:34
yeah i was specifically impressed with the logic programming on that robot.
Unread 27-07-2005, 18:42
[527]phil's Avatar
Alumni
AKA: Phil
I'm having trouble with the programming though, if anyone knows how to put voltage through a pin in order to keep a servo from moving, or if you know how to make more than one servo move at a tine, OR if you know how to sue the pulsout command, please help!!
Unread 27-07-2005, 18:56
you tell the servo the angle you want it the potentiometer inside it will keep it at that angle and as long as power runs to the servo it will "lock" it at that angle. i recomend Robot DNA building Robot Drive Trains. its a must.
Unread 27-07-2005, 19:07
i did a sumo bot that ran on servos. keep in mind if the servos aren't quite up to the job you can get more power from the motors by giving them more juice than their rated for. note that this is actually safe as long as your careful. you can run a servo on up to 12 volts but the motor will get warm pretty fast and i would not recommend running them more than 4-6 min on a high voltage (and yes this will lower the milege of your motors but the speed and power increase is worth it).
Unread 27-07-2005, 19:47
tiffany34990 tiffany34990 is offline
tiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond repute
Send a message via AIM to tiffany34990
wow!! that's really nice!! great job... what exactly do you want this bot to do???
Unread 27-07-2005, 19:54
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I think that's a lot of load for those servos to handle at the top, but it does look like it will be cool once it gets moving. It will never outrun anything with wheels, but it definitely scores in the articulation category.
Programming a 2nd PIC ImmortalAres Programming 8 16-06-2005 12:13
Learning PIC C Adam Collet Programming 18 19-10-2003 19:36
PIC Programmers seanwitte Electrical 8 18-04-2003 17:04
pic: Team 522 Robo Wizards Mckee H.S. Staten Island N.Y. CD47-Bot Robot Showcase 18 17-04-2003 20:40
